AchillesPunks
So is there a way to add Movie-Genre widget
To the home menu section? ..
(2022-08-14, 01:46)Launcher Wrote: [ -> ] (2022-08-14, 01:45)Launcher Wrote: [ -> ]@AchillesPunks
https://i.imgur.com/Z5KoFPK.jpg
https://i.imgur.com/GiD5MPT.jpg
That can be found in the skin helper service
widget addon
Addon>video addon>skin helper service widget>movies>genres
Of if you just wanted to add a specific genre you can find the list in
Video libary>movies>genres
Hi AchillesPunk
I noticed on post 5105 and 5106 there is mention of an issue in relation to ratings. I am also seeing that problem. I am using script.module.thetvdb-1.0.29 plus script.module.metadatautils-1.0.50. The issue happens on the dashboard with my widgets, mostly related to tv shows. One minute it shows all the ratings for the tv shows/episodes, but when I watch something and come back to the dashboard most of the ratings are missing for tv shows that show up on widget, like in screenshot on post 5106. Ratings for movies are ok. It only shows the IMDB rating for tv show. The other ratings for TVDB, metacritic, etc all seem to disappear. If I reboot my Kodi box then the ratings reappear, but disappear the next minute I play something.
Try deleting the simplecache
Hi AchillesPunks
I have tried that a few times. It rebuilds the ratings but still disappears for TV Shows that appear on widgets once I watch something. If I go into my tv shows folder to see all tv shows, all the ratings are their apart from the ones that appear on my widgets. The widget I have setup on my dashboard is to show the last 30 recently added tv episodes.
Hi AchillesPunks
Please find attached pics. First two links show the dashboard plus direct access into all my tv shows which shows the TV show Loot with all the ratings. After playing a movie/tv show and I go back to the dashboard the 3rd link shows only the IMDB rating, the rest of the ratings are missing. This happens on the dashboard plus when I go view all my TV shows. I reboot my Kodi box and the ratings reappear.
https://imgur.com/vIK6RWK
https://imgur.com/XeU6ALd
https://imgur.com/jPLMcIG
Please see attached log file below
https://paste.kodi.tv/ijelanapaf.kodi
Hopefully the log file helps. This is my first time trying to generate a log file.
Basically, I had to go into my tv shows folder and go through the tv shows that appear on dashboard widget so that the ratings would appear. I then rebooted my Kodi box but this time just went through each episode on dashboard widget instead of going to my main location with all tv shows. All it would show is the imdv rating.
Do you have multiple systems you run Kodi on? and if so is it doing this with the other systems like you bedroom?
