(2022-09-16, 17:00)loko5626 Wrote: [ -> ]I have AuraMod as a skin. And I ran upon this Titan Bingie Mod, which is amazing.
No way of simply copy and paste.
Stuff like this must implemented so answer to all your questions is NO it can't be copied
AchillesPunks first of thanks for the great workk, I really do appreciate the effort and I truly love your skin.
I have one question. How can I add sorting conditions to Hub Widgets that I add manually, for example for Movies? With other skins I need to choose between the sorting method (by date, random...) when adding widgets to the homescreen by adding a directory and selecting "Use as widget". Bingie on the other hand "just" adds the source without asking. I did some digging and I'm able to set the sorting condidition within the xml directly by adding "...sort=random..." and it works fine but unfortunatly I dont know where the Homescreen widget lists are stored locally.
Id love to hear back from you.
AchillesPunks I made it work to increase the Widget Limit within a Hub by editing the "bingie_custom_hub_items" in IncludesHubs.xml 👍
Unfortunately, the skin keeps crashing multiple times for me. Anyone else have this problem?
Im not using any extra addons except trakt.
I rly love the skin, keep up the good work
key83
We do not have more because people will start to complain about the skin lagging...
AchillesPunks how can I define the content-sorting of each source I'm adding to hubs or widgets? If you would add this feature then your Skin would be perfect!
(2022-09-23, 11:08)key83 Wrote: [ -> ]@AchillesPunks how can I define the content-sorting of each source I'm adding to hubs or widgets? If you would add this feature then your Skin would be perfect!
For home widgets Skin settings/configure shortcut/edit menu shortcuts
For the hubs, you will have to manually change xsp file.
matke Awesome. Would you mind help me with the Hubs sorting. This is basically the interesting part for me
How and which xsp do I have to edit?
Thanks so much bro ✌️
(2022-09-23, 11:42)key83 Wrote: [ -> ]@matke Awesome. Would you mind help me with the Hubs sorting. This is basically the interesting part for me
If you use a local library then you can create your own lists of your choice.
https://kodi.wiki/view/Smart_playlists/XSP_Method
Smart lists in tbm are located in the playlists folder, so you can change them or see how they look and make your own.
key83
You would need to edit any xsp you're intending on using. It's a very simple change and here are some ideas for you.
<order direction="ascending">random</order>
<order direction="descending">dateadded</order>
<order direction="ascending">sorttitle</order>
<order direction="descending">votes</order>
<order direction="descending">year</order>
Hi all,
I tried to install this Titan skin on nvidia shield pro (v9.1.0) and Kodi Matrix v19.3 and the following message appears : the dependency on xbmc.python version 2.2.4.0 could not be satisfied.
an idea to solve it ?
thks
Your installing the wrong repo. Install the matrix version
Tried to install from Matrix repository or skin Matrix zip file : same error !
Hey,
I would like to change the main menu's highlight color on the left. I tried to customize colors in the skin settings but nothing seems to change that.
How can I modify that? It's so hard to distinguish on which menu item is active at the moment.
