(2023-07-10, 18:56)Roadrunners Wrote: [ -> ]Thanks. Any advice on procedures for installing this skin, i.e. does and don’ts
Install using the same repository that works on Matrix as well which is linked on the first page of this thread. Just remember to have Kodi set to install updates from “Any Repositories” in Kodi Settings > System > Addons and it should install just fine.
Thanks for your swift response.
(2023-07-10, 18:20)SoulReaver Wrote: [ -> ] (2023-07-10, 17:13)AchillesPunks Wrote: [ -> ] (2023-07-10, 15:58)SoulReaver Wrote: [ -> ]Thank you for your quick response.
I am aware of this option you refer to which lets you use an image for the splash screen, but I do not wish to have any kind of splash screen at all which is why I edit the .xml file at the moment.
Then just put a black image for it it's there to let the skin load the widgets
Okay, I guess I just prefer no image and actually see it loading the widgets instantly instead of just staring at a black image for a while, but I’ll try and see if there is any speed difference between using an image or not.
It would still be more simple and user friendly with an off switch instead of the user having to find a black image somewhere to use for this.
Thanks again for your work on this cool skin
I just sent you a link. Just replace the files with the ones I sent you... Let me know if it works... Your setting is in the same area as the others
Was really excited to install this skin. Running into some issues. I'm running Kodi 20.2, which I believe I saw in the forum says its running great. Here is what I'm up against. I downloaded zip for Titan Bingie 2.1.0. When I tried to install from zip it stated I needed the following versions of dependencies: resources.image.skinicons.wide-1.0.5, script.skinshortcuts-2.1.0, script.module.arrow-1.1.0. I got the zip files for those and got them installed. I got to resource.images.languageflags.colour-version 0.0.5(which is showing in the github addon.xml as being the one it should try to install) but the only zip I'm finding is for 0.0.1. So I'm stuck. Any help on this would be appreciated!
(2023-07-11, 14:30)davelee77 Wrote: [ -> ]Was really excited to install this skin. Running into some issues. I'm running Kodi 20.2, which I believe I saw in the forum says its running great. Here is what I'm up against. I downloaded zip for Titan Bingie 2.1.0. When I tried to install from zip it stated I needed the following versions of dependencies: resources.image.skinicons.wide-1.0.5, script.skinshortcuts-2.1.0, script.module.arrow-1.1.0. I got the zip files for those and got them installed. I got to resource.images.languageflags.colour-version 0.0.5(which is showing in the github addon.xml as being the one it should try to install) but the only zip I'm finding is for 0.0.1. So I'm stuck. Any help on this would be appreciated!
Read my post on the top of this page. Did you do what that said in order to install properly?
1st Page instructions:
Install repository in Kodi Matrix & Kodi Nexus (all you need)
https://achillespunks.github.io/reposito...ingie.mod/
Matrix Skin Link Below(for manual update)
Titan Bingie Mod Matrix
When installing KODI 19 it must be a fresh install. You can not upgrade from KODI 18 all files must be removed or you get a dependency error
*Fresh install of Kodi 20.2 as you stated in a more recent post Titan Bingie ran fine on 20.2.
Additional Add-ons:
*(not required) did not install these
- Artwork Beef (Matrix) : (Available on Titan Bingie Mod Repository)
- Artwork Dump (Matrix) : (Get from Rector Stuff Repository)
- Up Next - is integrated and is used to watch next episode.
*You're more recent statement: Yes and it works great also on Kodi 20.2
Roadrunners asked "Thanks. Any advice on procedures for installing this skin, i.e. does and don’ts"
Your reply: "Install using the same repository that works on Matrix as well which is linked on the first page of this thread. Just remember to have Kodi set to install updates from “Any Repositories” in Kodi Settings > System > Addons and it should install just fine."
*I made sure Kodi was set to update from "unknown sources" as there is nothing in Kodi Settings>System>Addons that indicates "Any Repositories."
I installed from the link under title: "Install repository in Kodi Matrix & Kodi Nexus (all you need)" as I am running Kodi Nexus(20.2)
*You sent a link for SOMETHING to Roadrunners but I don't know what that is
The only thing I can think of that I may have done "WRONG" from your first post is you meant for us to install from Matrix Skin Link Below(for manual update) instead of Install repository in Kodi Matrix & Kodi Nexus (all you need). If this is the case then you may want to provide a slightly different clarification as it appears if I'm running Kodi 20.2(NEXUS) that I should unzip and install the one I did.
If there is something else I'm missing here, like the link you sent to Roadrunners, then by all means I'd love to have it. Otherwise, I'm at a loss as to what else I need to do as these were all the instructions. I'm very analytical. So I try and follow everything to the letter.
Thank you for your help on this. It appears from all the screenshots I see, you do in fact have a great skin. I would just enjoy the opportunity to use it! lol
My bad, I see the link you were referring to was to someone else about images. Please disregard that part So then, I would have to say yes, I followed instructions. Unless I was supposed to NOT use the link for Nexus??
SoulReaver Okay, I think I'm tracking what you are doing here. You have the repository zip and then the skin mod zip? install both and they take care of each other?
(2023-07-11, 16:05)davelee77 Wrote: [ -> ]@SoulReaver Okay, I think I'm tracking what you are doing here. You have the repository zip and then the skin mod zip? install both and they take care of each other?
I just did a fresh install everything is working as it should.
1. Add the repo into Kodi from the first page
2. Install the ZIP in Kodi
3. Install the repo Skin
4. if something doesn't install hit install skin again
(2023-07-11, 15:46)davelee77 Wrote: [ -> ]1st Page instructions:
I understand why you really want to get this skin up and running because it’s great! The setting is like I said located in Kodi settings > System > Addons after you turned on unknown sources beneath that setting is the setting to update official addons from: Set this to “Any Repositories” before installing the skin. “All you need” was the key phrase here btw
Enjoy the skin
10-4. When I'm off work, I'll try it out tonight. I'm sure it will work. Thank you!!
Well, I don't know how but I just came home from work and tried it and it worked!! Thank you!!
(2023-07-11, 23:51)davelee77 Wrote: [ -> ]Well, I don't know how but I just came home from work and tried it and it worked!! Thank you!!
That’s great man! Enjoy the skin, it’s really fun to set it all up the way you like it
Definitely!! My daughter and Son-in-law love it! I am truly stunned and in awe at how good this is!! Keep up the great work!!
