(2023-01-05, 19:35)Merc33 Wrote: [ -> ]In the SETTINGS>Skin Config>Homescreen layout> Widget section. I have AUTO rotate all Widgets set to ALL widgets to rotate. I also have Pause rotate if Widget is Focused.
What that would do is rotate to the NEXT tile after 5 seconds and then Auto Play the Trailer on the next Tile Automatically WITHOUT ME selecting it. When its done playing the trailer it would Rotate to the next tile on the list and then Autoplay the trailer without me selecting it. In this update it just randomly stops after the trailer and when it rotates to the next tile it does nothing and the trailer does not autoplay.
I do have my trailers autoplaying correctly and they do work, but its the automated way of letting the skin just browse itself without user input based on the the auto rotation. I have tried all day comparing Cartmans skin to this update and narrowed it down to those 3 files I mentioned in previous post. The older settings look similar to this new update except that it will not Autoplay when set to Rotation or if the tiles refresh it won't autoplay. It will just sit there on the fanart.
Thanks for helping.
No, it doesn't work as you say. I will try to explain.
When you are focused on a movie, an alarm starts, and says skin rotate widget. The widgets rotate depending on the interval you set.
Widget rotation stops when you turn on the Pause rotate if Widget is Focused option or the trailer starts. In fact, at that moment, the alarm is canceled and doesn't rotate anymore. There is no way to tell the widget to rotate again when the trailer ends.
I hope it is now a little clearer to you how they work.
I have a question possible request. The highlight widget is very cool however I dont normally have auto trailers enabled in widgets I find it annoying except for in the new highlight widget is there a way to have it enabled without all the other widgets playing auto trailers or am I just shit out of luck and have to pick one or the other?
Thanks again for this update, the skin is stable and runs smoothly, I know that the skin is focused around Movies and TV Shows, but the PVR Hub is a really great addition, and I have a few suggestions to consider for PVR OSD to make it even better: - Adding last played channel button, - Up Next pop up, and - PVR artwork to show along with info.
one more question has the backdoor to using Artwork Beef to select artwork from the sideplane menu been removed or did I set something up wrong?
(2023-01-05, 23:54)cscott1 Wrote: [ -> ]one more question has the backdoor to using Artwork Beef to select artwork from the sideplane menu been removed or did I set something up wrong?
If I understand you correctly, you are missing the artfork beef from the context menu? That should depend from addon not skin. I certainly didn't throw anything out from context menu and artwork beef integration was introduced with this update so nothing could be removed. You certainly have an option in the skin settings to replace the standard choose art with artwork beef if you want.
(2023-01-05, 23:04)cscott1 Wrote: [ -> ]I have a question possible request. The highlight widget is very cool however I dont normally have auto trailers enabled in widgets I find it annoying except for in the new highlight widget is there a way to have it enabled without all the other widgets playing auto trailers or am I just shit out of luck and have to pick one or the other?
This is not a bad idea. I think this will be easy to implement.
(2023-01-05, 23:11)psbguy Wrote: [ -> ]Thanks again for this update, the skin is stable and runs smoothly, I know that the skin is focused around Movies and TV Shows, but the PVR Hub is a really great addition, and I have a few suggestions to consider for PVR OSD to make it even better: - Adding last played channel button, - Up Next pop up, and - PVR artwork to show along with info.
It is not currently planned. With this latest version, a lot of things have been improved in that regard, but the focus is definitely on movies and tv shows.
You mentioned "There is no way to tell the widget to rotate again when the trailer ends."
Actually the older skin version would know to rotate to the next tile after the trailer ended. I think one of the XML files I mentioned earlier some the Cartman build resets it back to play trailer unpon finished rotating. It seems your current script update broke that and it just plays the trailer and gets STUCK on rotating because its not playing the next tile trailer automatically.
Can you look into this and help me find a solution? To be honest I don't want to go back to Kodi Leia 18.9 using the older skin. I seriously want to use this skin to Rotate when the trailer ends and shuffle to next tile and autoplay that trailer to the end and so on.
I suspect script-skinshortcuts-includes.xml, includesFunction.xml and includes.xml
Those files from the older skin will reset it back to Rotate to next tile after Trailer Ends.
@AchillePunks
Hello.
In xml/IncludesVariables.xml, you should modify this in order to localize strings for categories (about lines 1502 to 1520) instead of default english categories. This is useful for the left border color in front of a category, however this border is white (default) when default language is not english and strings are translated in strings.po . I did not change "fantasy" because it's a universal world nowadays.
<variable name="CategoriesColors">
<value condition="String.IsEqual(Container.ListItem.Label,$LOCALIZE[320102]) | String.IsEqual(Container.ListItem.Label,$LOCALIZE[320108]) | String.IsEqual(Container.ListItem.Label,sci-fi) | String.IsEqual(Container.ListItem.Label,$LOCALIZE[320119]) | String.IsEqual(Container.ListItem.Label,$LOCALIZE[320123]) | String.IsEqual(Container.ListItem.Label,$LOCALIZE[320124])">FFFFA10B</value>
<value condition="String.IsEqual(Container.ListItem.Label,$LOCALIZE[320103]) | String.IsEqual(Container.ListItem.Label,$LOCALIZE[320115]) | String.IsEqual(Container.ListItem.Label,$LOCALIZE[320127]) | String.IsEqual(Container.ListItem.Label,$LOCALIZE[320120])">FFCE3A00</value>
<value condition="String.IsEqual(Container.ListItem.Label,$LOCALIZE[320101]) | String.IsEqual(Container.ListItem.Label,fantasy) | String.IsEqual(Container.ListItem.Label,thriller) | String.IsEqual(Container.ListItem.Label,$LOCALIZE[320118])">FFA60A5E</value>
<value condition="String.IsEqual(Container.ListItem.Label,$LOCALIZE[320104]) | String.IsEqual(Container.ListItem.Label,$LOCALIZE[320110]) | String.IsEqual(Container.ListItem.Label,$LOCALIZE[320125]) | String.IsEqual(Container.ListItem.Label,$LOCALIZE[320121])">FFE50914</value>
<value condition="String.IsEqual(Container.ListItem.Label,$LOCALIZE[320105]) | String.IsEqual(Container.ListItem.Label,$LOCALIZE[31049])">FF7D2889</value>
<value condition="String.IsEqual(Container.ListItem.Label,$LOCALIZE[31159]) | String.IsEqual(Container.ListItem.Label,$LOCALIZE[320111]) | String.IsEqual(Container.ListItem.Label,$LOCALIZE[320122]) | String.IsEqual(Container.ListItem.Label,$LOCALIZE[320126])">FF3F54FF</value>
<value condition="String.IsEqual(Container.ListItem.Label,$LOCALIZE[31046]) | String.IsEqual(Container.ListItem.Label,$LOCALIZE[320117]) | String.IsEqual(Container.ListItem.Label,romance) | String.IsEqual(Container.ListItem.Label,$LOCALIZE[320128])">FF007A63</value>
</variable>
<variable name="CategoriesColors2">
<value condition="String.IsEqual(Window(Home).Property(category),$LOCALIZE[320102]) | String.IsEqual(Window(Home).Property(category),$LOCALIZE[320108]) | String.IsEqual(Window(Home).Property(category),sci-fi) | String.IsEqual(Window(Home).Property(category),$LOCALIZE[320119]) | String.IsEqual(Window(Home).Property(category),$LOCALIZE[320123]) | String.IsEqual(Window(Home).Property(category),$LOCALIZE[320124])">FFFFA10B</value>
<value condition="String.IsEqual(Window(Home).Property(category),$LOCALIZE[320103]) | String.IsEqual(Window(Home).Property(category),$LOCALIZE[320115]) | String.IsEqual(Window(Home).Property(category),$LOCALIZE[320127]) | String.IsEqual(Window(Home).Property(category),$LOCALIZE[320120])">FFCE3A00</value>
<value condition="String.IsEqual(Window(Home).Property(category),$LOCALIZE[320101]) | String.IsEqual(Window(Home).Property(category),fantasy) | String.IsEqual(Window(Home).Property(category),thriller) | String.IsEqual(Window(Home).Property(category),TV $LOCALIZE[320101])">FFA60A5E</value>
<value condition="String.IsEqual(Window(Home).Property(category),$LOCALIZE[320104]) | String.IsEqual(Window(Home).Property(category),$LOCALIZE[320110]) | String.IsEqual(Window(Home).Property(category),$LOCALIZE[320125]) | String.IsEqual(Window(Home).Property(category),$LOCALIZE[320121])">FFE50914</value>
<value condition="String.IsEqual(Window(Home).Property(category),$LOCALIZE[320105]) | String.IsEqual(Window(Home).Property(category),$LOCALIZE[31049])">FF7D2889</value>
<value condition="String.IsEqual(Window(Home).Property(category),$LOCALIZE[31159]) | String.IsEqual(Window(Home).Property(category),$LOCALIZE[320111]) | String.IsEqual(Window(Home).Property(category),$LOCALIZE[320122]) | String.IsEqual(Window(Home).Property(category),$LOCALIZE[320126])">FF3F54FF</value>
<value condition="String.IsEqual(Window(Home).Property(category),$LOCALIZE[31046]) | String.IsEqual(Window(Home).Property(category),$LOCALIZE[320117]) | String.IsEqual(Window(Home).Property(category),romance) | String.IsEqual(Window(Home).Property(category),$LOCALIZE[320128])">FF007A63</value>
</variable>
(2023-01-06, 11:06)roitheoden Wrote: [ -> ]@AchillePunks
Hello.
</variable>
</variable>
Thanks for the note. As I told you, there are some places where the string is skipped. If you notice somewhere else, let me know.
(2023-01-06, 12:23)matke Wrote: [ -> ] (2023-01-06, 11:06)roitheoden Wrote: [ -> ]@AchillePunks
Hello.
</variable>
</variable>
Of course; with great pleasure. I noticed some problems with the "Rated" world everywhere. I've put my own translation in the different plugins settings that permit that, I've translated Rated in strings.po; despite there are a lots of "Rated" that appear on the widgets and in the movies view, I don't know the reason. (Rated U, rated R, rated 10 etc). And for some movies, without any valueable reason, Rated is correctly shown in the language ! It's not severe at all, but it illustrates the problem of translations everywhere in the files.
In extras/categories, extras/widgetplaylists and in playlists, I suspect translation is incomplete either.
(2023-01-06, 14:17)roitheoden Wrote: [ -> ] (2023-01-06, 12:23)matke Wrote: [ -> ] (2023-01-06, 11:06)roitheoden Wrote: [ -> ]@AchillePunks
Hello.
</variable>
</variable>
It's not up to the skins. Mostly scrapers do that. Also in the tmdb helper you have the option to edit that.
It seems that there is a problem with up-next in VOD ! There's an error due to no next item detected. UP-Next (v1.1.8+matrix.1) is working with local media library (but throws errors in kodi.log), but doesn't work anymore on Netflix, Disney and so on since updating skin titan bingie.
With 2.0.3 release, and same addons release, it was working a week ago ! Arghhhh
In kodi.log, there are a lots of lines like this one :
Loading skin file: /home/osmc/.kodi/addons/skin.titan.bingie.mod/xml/script-upnext-upnext.xml, load type: LOAD_ON_GUI_INIT
2023-01-06 15:57:47.623 T:2978 ERROR <general>: EXCEPTION: Non-Existent Control 3014
(2023-01-06, 17:03)roitheoden Wrote: [ -> ]It seems that there is a problem with up-next in VOD ! There's an error due to no next item detected. UP-Next (v1.1.8+matrix.1) is working with local media library (but throws errors in kodi.log), but doesn't work anymore on Netflix, Disney and so on since updating skin titan bingie.
Wrong adress. 🙂 Notify the addon author about these errors.
