Is there a way to show the progress bar below the episode banner?
(2024-02-27, 20:12)danpagotto Wrote: [ -> ]Is there a way to show the progress bar below the episode banner?
I'm not sure what your asking.
If you are syncing progress with Trakt you could use TMDBHelper widgets after activating the sync Trakt progress feature in the TMDBHelper settings. Then the progress bar should be showing underneath the episode thumbnail in the season and episodes view.
Is it possible to see "now playing" video in background when I'm in e.g. settings?
(2024-03-03, 23:53)Michal6677 Wrote: [ -> ]Is it possible to see "now playing" video in background when I'm in e.g. settings?
Michal6677, I agree with you totally. The lack of that feature (if it is available, I can't find it) is stopping me from using this skin further, although it is potentially a great skin, when you are watching something, if you back out of the now playing window, playback stops.
(2024-03-04, 00:02)Chalklands Wrote: [ -> ] (2024-03-03, 23:53)Michal6677 Wrote: [ -> ]Is it possible to see "now playing" video in background when I'm in e.g. settings?
@Michal6677, I agree with you totally. The lack of that feature (if it is available, I can't find it) is stopping me from using this skin further, although it is potentially a great skin, when you are watching something, if you back out of the now playing window, playback stops.
Well there is a setting to allow the current window to keep playing when you back out
(2024-03-04, 03:02)AchillesPunks Wrote: [ -> ] (2024-03-03, 23:53)Michal6677 Wrote: [ -> ]Is it possible to see "now playing" video in background when I'm in e.g. settings?
Thanks for the reply @
AchillesPunks. Apologies, I should have elaborated more. That works fine, however it doesn't if you're playing a streaming video such as something on Youtube or through Amazon VOD for example. When you back out then the video stops in that case.
1. @AchillesPunks Well, this is not I was asking for. The playback is running when I'm in settings but I do not see it. Most of skins have a possibility to set the playback video as background so you can see it behind settings. In Titan BINGIE MOD I can see the video as background when I'm in main/home menu but not when I'm in addons, setttings etc. There is only sound.
Edit: anyway that setting "Force stop playback when not in fullscreen mode" does not work. I'm streaming videos/movies/tvshows from addons and when I go out of fullscreen the playback is stopped no matter the setting is on or off.
2. And one more question:
can I enable catchup marks for Live TV EPG like it is in default skin? I know which TV channel has archive and I can stream directly from EPG. Currently there is also a "Play programme" button missing when I select an item from EPG.
Images what I mean:
https://ibb.co/9WrBvtS
https://ibb.co/RjT2FZx
(2024-03-04, 08:44)Michal6677 Wrote: [ -> ]1. @AchillesPunks Well, this is not I was asking for. The playback is running when I'm in settings but I do not see it. Most of skins have a possibility to set the playback video as background so you can see it behind settings. In Titan BINGIE MOD I can see the video as background when I'm in main/home menu but not when I'm in addons, setttings etc. There is only sound.
Images what I mean:
Now playing you can only have the info bar. I can not check Live TV
(2024-03-05, 07:06)AchillesPunks Wrote: [ -> ]Now playing you can only have the info bar. I can not check Live TV.
Ok so if I understand it right:
1. it's not possible to set playing video as background (there is only sound but background is black).
2. disabling "Force stop playback when not in fullscreen mode" does not work for all cases (e.g. streaming from plugins I use, when I press back to go to the menu then video is stopped).
3. no catchup marks in EPG
4. no "Play programme" button in programme details window showed from EPG, so no possibility to playback archive of live TV
This is very nice and fast skin but above features are native kodi features which are missing here and it blocks basic functionality (except nr. 1, it's a matter of taste).
Isn't there a plan to add those or to consider adding?
(2024-03-05, 20:55)Michal6677 Wrote: [ -> ] (2024-03-05, 07:06)AchillesPunks Wrote: [ -> ]Now playing you can only have the info bar. I can not check Live TV.
Only if someone that uses Live TV adds the features. The same goes for add-ons because I do not use add-ons. The now playing has only the info bar at top as shown in the picture. Might as well pause the video so you don't miss anything while messing with the settings.
Matke might already be looking at the add-ons play back stop. I'm not sure I haven't talked to him in a about 1 or 2 months.
Hi I've used this link
https://achillespunks.github.io/reposito...ingie.mod/
In file manager in Kodi and installed the Titan BINGE MOD repository gone and installed the add-on and it's done that no errors messages then I went onto look and feel and all their is showing "image collections" & "screen saver" .
I am however running Kodi Omega RC1 edition so do I take it this sadly is definitely not compatible with Kodi Omega build as of yet
I went and looked interface and skins and it's not showing their either ..
please advise...Many Thanks 🤔😕.
On homescreen, when I choose movie and click on play movie on infoshow, it goes back and then the movie starts.
Is it possible to stay on the infoshow when you leave movie ?
(2024-03-09, 01:49)Marcd5123 Wrote: [ -> ]Hi I've used this link https://achillespunks.github.io/reposito...ingie.mod/
I am however running Kodi Omega RC1 edition so do I take it this sadly is definitely not compatible with Kodi Omega build as of yet ..
The skin does work fine on Omega RC1, but until an official Omega update for the skin is released you'll need to manually install the skin files from
here and then edit the addon.xml file inside the skin.titan.bingie.mod folder and change the xbmc.gui version number near the top to 5.17.0 using a text editor and save the file.
This line:
xml:
<import version="5.15.0" addon="xbmc.gui"/>
Needs to be changed to this:
xml:
<import version="5.17.0" addon="xbmc.gui"/>
Now when you restart Kodi the skin should show up in the interface/skin section of Kodi and work fine again
