For the record, your Youtube videos seems not working for me. the link and the embedded Video show me "Not available"
Currently, I have Netflix ant a test account for Disney+. Both work on my Raspberry Pi with Libreelec 11.0.3 (current version) for my FullHD TV.
It need's alot of time to integrate Netflix and Disney+, But now It's far better usable as befor.
Despite my problems, your Addon Is now way better than the kodi standard theme or the lame Netflix integration of our old SmartTV. And Disney+ only worked on Laptop.
- Menu Item
- New Menu Menu item seems not appearing in the Menu on the left.
- Smart Menu like PVR Reccordings does. Smart Menu like a Favorit entry vor Disney Plus does not.
- I tried to add the watched list of two netflix profile as widget to main, but one of the profile watchlist appear twice. Both widget shows the same profile instead the content of two diferent profile.
- Submenu have no graphical sign that I switch from Mainmenu to the submenu. after presing the Right button
- We have PVR with replay TV
- PVR Recordings in a widget not Work, because the Image shows nonsence and is not helpful. And no Information about the content is on the Image.
- The Mainmenu vor Recording works nice ( square panel with info ) but:
- The recorded length not appear some where
- Some panel shows Subtititle and Episodenumber, and some panel the TV station an recording date. (at least the title should be shown. but none of them does)
- Starting a Replay from EPG not work on klick Enter because the menu entry for showing the whole recordingappear only on pressing the Menu button
- In life TV the skip step is not showing even I activated this in the Menu settings. (because cec somtimes not work I need to see on what skip step I am)
- Search does not search in Netflix or Disney+
Hi just wondering if someone could help
I have a short cut for tv and another one for movies. I have widgets set up for both. On the home screen it shows widgets for all of them. I want to be able to click on the movies short cut and only see my movies widgets and vice versia with the tv short cut. Thanks
Thank you for the reply got it working.
As far as trailers go I've added my YouTube api to the YouTube add on and I get the following content is not available on this app any suggestions?
(2023-10-09, 19:59)Quangtungnguyen Wrote: [ -> ]Thank you for the reply got it working.
Youtube addon bug. Download this version.
https://github.com/anxdpanic/plugin.vide...g/v7.0.2.2
Does anyone know what setting can change the following behaviour.
When i press enter onto a TV Show item on a widget - I get a dialog no video information available.
Movies are fine and load me into the movie info panel but tv shows seem to blank out.
Trying to remember if this has previously worked but it'd be great if the behaviour would load me into the TV show info panel.
I have the same problem, android tv os, kodi v21 Alpha 3
This is not a skin for kodi 21 but for kodi 20. You use kodi alpha version and expect everything to work.
I have to use it because dolby vision is not working on nexus and I don't expect everything to work, just asking is it a matter of some setting(like sunlollyking before me, don't know if he uses nexus version), btw everything else is working fine...
As i said this is kodi nexus version. There is no special setting for dialog info to work in movies but not in tv shows. I don't use omega, I don't plan to use until the release of the final version so I don't know what the problem is. The same for skin, there will be no support for Kodi 21 until the release of the final version.
OK, thanks, as I said before, everything else is working very well as I can see, this is maybe only issue with new kodi release.
The search option on my Skin is not working. When I type, no movie appears. I can write any word that doesn't find any movie.
(2023-10-22, 02:54)Rafilsky Wrote: [ -> ]The search option on my Skin is not working. When I type, no movie appears. I can write any word that doesn't find any movie.
Do you have media scanned into your library? Or do you have search addons turned on in the skin?
I'd like to know how to display the collection tab as it appears in the image. Mine isn't showing.
