(2023-03-11, 20:29)Jurassicspark Wrote: [ -> ] (2023-03-11, 20:21)childofkorn Wrote: [ -> ] (2023-03-11, 20:14)Jurassicspark Wrote: [ -> ]I'm not too sure from where it gets the resume points... I think this is built inside the skin or from skin helper widgets. I do sync my resume points to Trakt but in trakt i have "Sync movie/episode playback progress to Kodi" disabled.
But i don't think it's a problem of the resume points because it should just play the media from the start instead of giving me an instant error.
I also use .strm files imported into kodi libary like yourself and get no problems with resuming media or using play from beginning if the media has a resume point. It definitely seems like something isn't set up right as its getting a conflict when you use either.
Mhhh.. I'm starting to feel like it's because I'm using Kodi in portable mode from inside my OneDrive folder... And this is somehow giving Python errors.
Do you have any experience with loading portable Kodi from a Drive folder? (Btw I do have all the files mirrored on my computer, they just sync to the cloud.)
I dont, but if you provide a kodi log then people can help you try and fix the problem faster.
(2023-03-11, 20:34)childofkorn Wrote: [ -> ] (2023-03-11, 20:29)Jurassicspark Wrote: [ -> ] (2023-03-11, 20:21)childofkorn Wrote: [ -> ]I also use .strm files imported into kodi libary like yourself and get no problems with resuming media or using play from beginning if the media has a resume point. It definitely seems like something isn't set up right as its getting a conflict when you use either.
sure thing. First time doing this so hope this is correct:
https://paste.kodi.tv/ikokijolab.kodi
(2023-03-11, 20:57)Jurassicspark Wrote: [ -> ]First time doing this so hope this is correct:
Hmm.. Not entirely. Somehow the name of a known and banned add-on has been edited in your log. Not sure if the add-on itself has done this or that this is the result of your own 'handywork'. In any case, Kodi setups with one or more add-ons that facilitate video piracy in any way, are not welcome.
So either cleanup your Kodi setup and reproduce the error(s), or find your support elsewhere. The choice is yours.
(2023-03-11, 15:30)AchillesPunks Wrote: [ -> ] (2023-03-10, 21:42)SoulReaver Wrote: [ -> ] (2023-03-10, 20:44)PrimeDigital Wrote: [ -> ]Hello, I'm using Kodi Matrix 19.5 and when I try to install Titan Bungie MOD I get this message The dependency on script.skinshortcuts version 2.1.0 could not be satisfied. Please help if you can.
Try this.
@SoulReaver
You need to delete some of your messages you're inbox is full
I just wanted to say I loved that game Legacy of Kain: Soul Reaver. I really hope they remake it on the PS5
Thank you for the heads up! Done.
Yeah me too man! That would be a dream come true. Loved the writing, acting and story and it would really be the best it can be with some better gameplay and graphics on the PS5
Nice to have a kindred spirit on this matter!
I am using Advanced Kodi Launcher which is a great game management plugin. How would I go about adjusting your skin so that when I click on a game it goes to the same extended info screen that both tvshows and films do. The plugin gives these example expressions for skinning.
https://github.com/chrisism/plugin.progr...ns-for-AKL At present the games open what I believe is an estuary window. Are you able to add these expressions to the skin, as they support a large chunk of the game plugins available. Your skin looks great with games.
Couple quick questions:
1) When setting up actions for menu items when i try to point to a playlist my playlist section seems to be completely empty. This only affects this skin and not any of the other i use.
2) Is it possible to have any views that support both TV Shows and Movies or does this skin also segregate them similar to other skins. I've seen that widgets can support both but i'm unsure of actions.
(2023-03-13, 18:29)sunlollyking Wrote: [ -> ]Couple quick questions:
1) what playlist are you trying to point it to? Strange that it will load in other places...
2) kodi treats tv shows and films separately which is why addons also follow this and you can't create smart playlist e.c.t with both, but you can use skin helper service widget which has mixed media content (not sure how it does it)
Cool so on 1) It's generally just my normal smart playlists. They show as blank when trying to point one of the elements in the taskbar to an action which would display a playlist. I have seen this drop in as an intermittent issue. I'm currently running the LibreELEC 11 build.
Hi there,
thank you so much for this fantastic skin, I've been using it since day 1, just love it!
little question, is there a plane to add an adjusted moving frame to the highlight widget?
AchillesPunks Would adding more custom hubs make the skin more laggy? I am thinking of adding about 4-8 new custom hubs by editing xml where it's needed.
So I did a fresh install of LibreElec Kodi 19.5 but cannot do an install of the skin 2.0. I get Dependicy doesn't meet the minimum version.
(2023-03-14, 23:41)jlusco Wrote: [ -> ]So I did a fresh install of LibreElec Kodi 19.5 but cannot do an install of the skin 2.0. I get Dependicy doesn't meet the minimum version.
Check a few messages back for solution
gaze
Yes & No but that really depends on your system... If you have a really fast system then the skin will not be able to slow it down.. Now if your system is medium to lower your system may slow down/lag.
This is a very heavy skin for most people.
Is the theme able to show "HDR" or "Dolby Vision" codec labels? I have fake codec disabled but it's showing "Ultra HD 4k" for all media no matter if it's HDR or DV or only 4k. Thanks again
