(2021-05-29, 18:59)DROIDshield Wrote: [ -> ]I'm trying to change the colour of this text when any word and icon is highlighted as it's very hard to tell sometimes but I can't find in the settings which one changes the colour. I've been though most and no change. Could it be pointed out please thanks.
https://drive.google.com/file/d/18STXzkq...p=drivesdk
There is no setting to change those colors. Xml change only
Configure shortcuts > Edit menu shortcuts > Home > Widgets
Im sure there was an option to change layout for widgets before eg, Landscape, Poster etc
I just did a fresh install of Kodi and this skin and before i was able to set 'Continue Watching for You' on the Homescreen to Landscape. Cant seem to do that now. What am i missing?
https://imgur.com/a/emH6gzS
Thanks for any help.
I see there are different ways to install this mod
Quote: . . . . I added the Titan Bingie old repository (https://cartmandos.github.io/repository....ry.bingie/),
and then installed Bingie 1.0.3 by downloading it from the github master branch (https://github.com/cartmandos/skin.titan.bingie).
Please note that the Bingie old repository is needed for the dependencies. I've manually installed the 1.0.3 version because the repository is pointing to the previous 1.0.2 version.
With this setup, I obtained the same behaviour as the latest kod/bingie-mod, with the exception that by selecting an homescreen layout, the issue is fixed.
I think that this strange behaviour is strictly correlated with the issue exposed above with the new versions freshly installed.
and so far - had a Black screen, a blank on-screen keyboard or the install has frozen
As part of the development team, which is the correct way to install with Leia 18.9?
Hello,
first of all thanks for this wonderful skin! And sorry if my english is not perfect,
come from Germany!
I am currently using the skin on Windows 10 - Kodi 19.1!
2 problems are currently causing me concern!
The first is a language problem - when I put it in English it says "Play" but I don't necessarily want the whole system in English.
Have not yet found out which skin xml is responsible for it
https://i.imgur.com/D7CUxQM.png
The second problem!
When starting the film from the widget, this window appears first
https://i.imgur.com/9SS42hF.png
the same when the film is stopped - does not go back to the widget, only with return or exit!
This only happens with an external source (add-on).
Movies/ series from hard drive / NAS work perfectly!
I would appreciate an answer
greetings from Germany
Daniel
(2021-05-30, 22:28)fsurfer Wrote: [ -> ]Hi,
On the black screen, press the "S" key to activate the power menu, then follow my previous post:
https://forum.kodi.tv/showthread.php?tid...pid3039632
I think that the same issue in the new versions it's strictly correlated.
Comparing to a third installation on a Vero 4K, I've seen that on Mac, some of the option fields remains blank instead of showing the default value.
(2021-06-01, 12:39)EdoFede Wrote: [ -> ] (2021-05-30, 22:28)fsurfer Wrote: [ -> ]Hi,
thanks for reply, all good
Greetings,
pleased to say mod now works for me.
Settings:-I have plot enabled on pause, how do I make it scroll?
Sorted, setting in General skin settings>> General Artwork & Details Options
Hi everyone, I have an issue with the widgets. None of my widgets are displayed in the Movies menu even though they are well configured.
In the Home menu, everything works correctly even though I have configured the exact same widgets.
On the other hand, still in the Movies menu, I have "recommended movies", "because you've watched ..." and "Crime" that are always displayed even if I remove all my widgets... How can I completely remove them ?
Here are my widgets in Movies :
Thanks for your help
(2021-06-03, 10:31)thibaudbrg Wrote: [ -> ]Hi everyone, I have an issue with the widgets. None of my widgets are displayed in the Movies menu even though they are well configured.
Widgets only work on the Home Hub. It's a problem that has been present ever since the OG Titan Bingie mod, and has never been fixed. To add things to movie and tv shows hubs, you need to 'unlock' them in the settings, and add them manually while browsing the hubs, not with widgets.
I experienced the following issues :
1. I have another skin installed and Titan binge mod is rather slow to show recently watched page in comparison. Is there a solution to speed things up to complete the task?
2. Settings option (eg skins settings) have a few blank lines if I perform a reboot. I manage to solve it by choosing Kodi's default skin then go back.
3. Icons are frequently missing or reset on sidebar if any shorcut being edited. Sometimes even go to home shorcut settings cause the icons to crash and I have to manually set the icons again.
4. Is there a way to add personal icons manually to skin folder?
Appreciate any solutions provided. Anyway, this skin is beautiful and I don't feel the need to give other skin a try.
How on earth do i disable the clearlogo overlay of landscape widgets on the homescreen?
See here for illustration
It doesnt do it for In progress TV Shows only Movies. Ive disabled every clearlogo option in settings that i could find but it still shows. On a previous installation of this exact skin it just showed the tag without any clearlogo.
Id be really grateful for any advice!
(2021-06-03, 21:21)je1992 Wrote: [ -> ] (2021-06-03, 10:31)thibaudbrg Wrote: [ -> ]Hi everyone, I have an issue with the widgets. None of my widgets are displayed in the Movies menu even though they are well configured.
Ok Thanks I understand, is the problem going to be fixed ? And how can I 'unlock' what you said ? I mean, where is it in the settings ?
(2021-05-24, 23:26)Majin01 Wrote: [ -> ] (2021-05-23, 17:24)Shinobi_Wan Wrote: [ -> ] (2021-05-19, 20:42)shaktoo Wrote: [ -> ]@AchillesPunks : Does the skin uses TheMovieDb Helper addon for additional ratings ?
I used Arctic Horizon by Jurialmunkey who also wrote the TheMovieDb Helper & Skin variables scripts. Out of the box without any modification of nfo's or using any specific scraper it pulled additional ratings ( MC/Trakt/RT/Tvdb etc ) and displayed instantaneously.
I went back to TBM and still no Joy Just the imdb & sometimes the tmdb ratings.
So I think TBM is not utilising the "TheMovieDb Helper" script . I think it utilizes the scraped info directly into Kodi library ( As on my Matrix test where I did not use any nfo files & got all artwork from UMS) or maybe via the local nfo ( as scraped by TMM ... Still not available on ember ).
Another great idea implemented in Arctic Horizon skin (which I had proposed to MiKe Silvo as well but didn't got heard )was to have a button to access Music Video ( Youtube Button )from the Audio source directly .
Could our beloved skin be configured to use these resources ? get additional ratings directly from TheMovieDb Helper / Skin variables ?
Also Is there anyway to have Netflix style Screensaver incorporated . Netflix currently has Fanart / landscape images with logo superimposed & pan scan effect with sound track as screensaver. The multi screensaver addon in kodi does not even come close to it .
This was something I wanted to address as well. Im only getting IMDB ratings for my movies in this skin but if I go to Arctic Horizon skin, its pulling every media rating I could ask for. I have my OMDBapi keys in the right place too.
I have it working and I'm only using 3rd party addons + TMDBHelper at the moment, you just have to put your OMDB Apis in the right places. I added Fanart and OMDB to Metadata and Artwork Module in Supported Addons in Skin Settings. Then add the OMDB to all your addons you're using as well as TMDB Helper. Then close Kodi and delete simplecache.db in kodi/userdata/script.module.simplecache. Reopen Kodi and it should start to pull the ratings, a lot of the time you have to stay on the movie you're on and then move off and come back. Generally I load a page in an addon scroll completely from one end to the other and then start singling out widgets and letting the ratings load. I found I've gotten complete ratings: IMDB, TMDB, RT (only critics though), and MC. on Shows I get: IMDB, TMDB, TVDB.
https://imgur.com/a/SgUhdfm
Hello. i tried all your things.
But i still get no Media/Codec-Info, no IMDB and RT ratings. just only on some movies i get the TMDB rating.
With the Titan MOD i have all the Ratings and Media/Codec-Info
Can anyone help me with it?
