(2023-08-13, 09:51)davelee77 Wrote: [ -> ]I DO need to get better about sharing pics and logs when posting.
https://postimg.cc/gallery/dq2H7rW
So just do a print screen for the image and use this icon to post them into Kodi
(2023-08-12, 22:29)SoulReaver Wrote: [ -> ] (2023-08-12, 15:11)Critical457 Wrote: [ -> ]How to use voice search?
If you go to the skin settings and change the keyboard to full size you should be able to voice search by clicking and holding the select button on any key.
Thanks, works like a charm.
Maybe you can also help me with this:
If I have two version of the movie(1080p and 4K) can they be displayed as one item with the indicator of available versions? Just like the series show the number of episodes.
(2023-08-13, 11:24)Critical457 Wrote: [ -> ] (2023-08-12, 22:29)SoulReaver Wrote: [ -> ] (2023-08-12, 15:11)Critical457 Wrote: [ -> ]How to use voice search?
That will show up in Kodi as two different movies if the format is not the same... Lets say if the 1080P is mp4 and the 4K is mkv. I don't see a way to display them as one item.. I could be wrong though.
Example of Train to Busan... I'll delete the 720P version now that I just found it...
Hey! Sorry to say but I'm back. Running into a couple of snags here. BUT I did get my initial concern resolved! And it was with all your help.
I am curious about this and don't know if it's related to Titan Bingie, the Nightwing and Mad Titan addon's or a little of both. I'm seeing the info in the log and it appears I need to make some changes, IF possible, but don't know where to go to find them.
From an end-user perspective, and let me clarify the setup here, since I have more than 1. This is Kodi 20.2, Xbox One S with the Titan Bingie Mod(Netflix). I setup Mad Titan and Nightwing last night. Got a lot of links to work then.
But today, for some reason, I'm getting a lot of errors and not sure why. I'm either getting a spinning wheel on the screen for 15 seconds and then nothing happens OR the error message, playback failed. (This is happening on both the Xbox and my android tv box.)
Potentially related, when I try to select a movie or show that is locally stored and set up through Embry Server, it plays for 2 seconds and then goes back to the main screen. I don't know what I've done but I've flubbed something up.(this is only happening on the Xbox. It worked fine prior to today. Videos are working on my android tv box and from emby server directly)
Please help or point me in the right direction? Thank you!!
Xbox log here:
https://paste.kodi.tv/uvuyasigod
(2023-08-14, 05:25)davelee77 Wrote: [ -> ]if it's related to Titan Bingie, the Nightwing and Mad Titan addon's
Given the latter two are
banned addons (wiki), you're on your own here. We offer no support to systems containing such (any addon or repo listed in orange in the posted logs), as per our
forum rules (wiki).
The forum moderators have determined that
banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
I had NO IDEA. 😔😔😔 ok. I'll be working on this immediately. How can I determine if something is banned or not? I'll tey and get the log back to you ASAP. Thank you for letting me know. If I would have know I certainly would not have done this. Kind Regards. Do I post the log here? When you say a clean log, do I just remove those and the repo files and then send a log? I never dealt with this before. 😔😔😔
(2023-08-14, 17:20)davelee77 Wrote: [ -> ]Ok. Not sure what I'm supposed to do with all this. I removed everything that, as far as I know is, banned content?? 🤷🏼♂️🤷🏼♂️ I had some trouble with the logs. I attempted to enable debugging but kept getting an error message that it was too large of a file? But here is everything I got. PLEASE let me know as it was never my KNOWN intention to have anything banned on my system. Thank you.
https://paste.kodi.tv/inafiwoyoz
https://postimg.cc/gallery/xLHxqQr
https://paste.kodi.tv/ihixosoxot
@SoulReaver
@AchillesPunks
Sorry guys. I didn't know. 😔😔
Still banned add-ons present. Please remove them. Please look at the banned add-ons that @
DarrenHill gave you a link for.
I'm just gonna scrap the whole thing and start over then. I don't know what else to do. I tried to remove everything I could possibly find and couldn't find anything else that I could tell was related
?? 😔 I removed and deleted the addons mentioned. I don't see anything in the system or in the skin that is part of what I downloaded. I could send screenshots but I know you guys want the log which I'm having trouble with as seen in the screenshots I sent. AND there are a few things in addons that I don't recognize but it doesn't give me an option to delete them. Just enable or disable. 😫😫
DarrenHill
AchillesPunks
SoulReaver
Ok. I found a couple other things that may have been related. I reset the skin and I've gone through the addons and file manager and removed any and all repositories that are banned, so far as I'm familiar with, based on feedback given. This is my last attempt before just wiping it completely and putting it all back to original kodi skin and not even messing with all this extra crap.
In my attempts to be fully honest and transparent, I've included screenshots of the add-ons and file manager as well.
Please let me know if anything is still present or if it's resolved. Thanks.
https://paste.kodi.tv/ububuxolud
https://postimg.cc/gallery/JJW0L11
(2023-08-14, 18:31)davelee77 Wrote: [ -> ]Please let me know if anything is still present
M3U line read: 'plugin://plugin.video.madtitansports
Weird cause the addons and repos, are technically removed. How do you get rid of "lingering" things like that when you've technically gone through the removal and deletion process?
(2023-08-14, 18:48)davelee77 Wrote: [ -> ]Weird cause the addons and repos, are technically removed. How do you get rid of "lingering" things like that when you've technically gone through the removal and deletion process?
It seems like the "lingering" stuff in your log comes from the IPTV Simple Client addon loading a channels list/EPG from the addon not welcome on this forum shown in orange colored text in your log so you need to remove those, reproduce the issue and post the new log.
Ok. Thank you. Heading back home and can get this finished. I'm really sorry guys. 😕 thanks for your help. A learning experience indeed. Read more of the kodi forum as well and understand where I eer'd.
(2023-08-15, 00:01)davelee77 Wrote: [ -> ]Ok. Thank you. Heading back home and can get this finished. I'm really sorry guys. 😕 thanks for your help. A learning experience indeed. Read more of the kodi forum as well and understand where I eer'd.
Best thing is legal add-ons or local content. You should never use banned add-ons going forward. Just make sure to follow the forum rules
