AchillesPunks & @
matke WoW what an update ! a massive upgrade and I have just started to set it up again. the Skin feels rejuvinated, snappy , responsive and just a plain delight. So far Everything seems to be working.
the New highlights widget looks and functions amazing just like the Orginial & same for the Play Something for me. Makes me wish if I can have these Viewtypes available for all my home menu widgets.
One thing I do miss but its just asking for a lot.. is the ability to have all different wodget Types individually .. like Poster / landscape / square etc etc.I understand that it will be tough as hell to line up everything but the poster widget just does not work for music.
Maybe like before you could set the 8th Widget to be changeable to landscape etc.
For selection of icons Just keep a simple black & white icon set when choosing for Sub menu etc ( like in Arctic Horizon2 ). Mix of coloured and various sizes & shapes icons just throws things off balance.
for The Music menu.. & especially the youtube videos I would suggest renaming to just youtube and instead of font use the youtube logo icon .
Oh and the screensaver is missing !
I gues all good things will come for the ones who patiently wait !
loki00 @
etgecata
I don't have this problem. There are no special settings. But it certainly doesn't make sense to play a movie directly from hdd with this skin because any visual experience is lost.
https://youtu.be/3UN77gSckg8
(2023-01-02, 06:19)shaktoo Wrote: [ -> ]@AchillesPunks & @matke WoW what an update ! a massive upgrade and I have just started to set it up again. the Skin feels rejuvinated, snappy , responsive and just a plain delight. So far Everything seems to be working.
This skin is primarily intended for playing movies and tv shows. Music is there just to be there. The poster view is not adapted for music. But that's why there are some other views.
As for widgets, if you want the last widget to look different, you can do that by going to my list hub and setting that widget.
Screensaver install from tbm repository.
First my conn is very slow, my bad. When update from repo nothing happen, and screen turn black, I restart kodi and go to addon, install from repo,and update again the screen turn black again. Some help please
(2023-01-02, 08:15)ksc1 Wrote: [ -> ]First my conn is very slow, my bad. When update from repo nothing happen, and screen turn black, I restart kodi and go to addon, install from repo,and update again the screen turn black again. Some help please
It might be best to install kodi from scratch and then install skin.
I uninstall the skin and nothing, don't let me install
(2023-01-02, 08:47)ksc1 Wrote: [ -> ]I uninstall the skin and nothing, don't let me install
Let's start from the beginning. Uninstall kodi, delete everything, install kodi, install skin.
All done, uninstall kodi, and still when install skin from repo : failed to install dependency.
I don't know what else to do
(2023-01-02, 09:42)ksc1 Wrote: [ -> ]All done, uninstall kodi, and still when install skin from repo : failed to install dependency.
You have an option in Kodi "Update official add-ons from". Set to "Any repository".
Thank a lot!!!! At lost installed. Thank again.
Hi everybody and happy new year.
Thanks to the creator for this new release. I've been using skin titan bingie since the very first release with great pleasure.
Here is the context (@AchillesPunks).
Yesterday, my systems have been updated with the 2.1.0 titan skin. I've got one system on a Vero, and another independant system on a Windows machine. Both are working very well (Kodi 19.4 on Vero and Kodi 19.5 under Windows) and everything is uptodate.
I Can't afford reinstalling from scratch easily on my Vero, and it's not necessary, and very slow as it's a small machine like a raspberry. My system has a lots of personalization, and it would take days and days to get the same configuration. So this is excluded, except for a major disaster.
Before updating, I've verified all dependencies. I've set another skin, removed the titan bingie skin and appropriate other addons linked to titan from the addons and the settings in userdata.
I've installed with success the new skin (2.1.0 release, I was using 2.0.3 with some modifications by myself before, without any problems), no problems with dependencies, scripts and modules.
After spending 6 or 7 hours to configure the skin from scratch and make the look and feel I wanted (the same as before in fact), I noticed one thing : The white borders for the highlighted TV shows in Home page, and for the info menu for a movie or TV show (info button / Netflix like Video Bingie, not extended one), are not showing at all. Everywhere else the borders are showing up as expected (I've disabled the circular navigation, I'm using the frame border with zoom effect in movies and TV shows). The pictures joined on page 363 of this topic show the white borders I should have, but I can't see them. I had them with 2.0.3 of course. The problem is for the movies info menu, I don't see what I'm clicking on and I must count the entries to click... This behaviour is the same on both machines (Vero and Windows), and each of them has been configured manually after installation of the skin. Any idea of what I missed ou forgot ? Please help. Thanks in advance.
One more thing: you should ask help for the translations. The French translation is very incorrect and I must rewrite a lots of things for myself. Don't know for other languages... Many strings have been modified or rewritten (sometimes only one uppercase letter in the string), so it's a bit tricky to correct, and I'll have to spend many and many days in order to make all that ok. It can't be a google translation, some words or sentences depend on the context and where they are used.
Hi team aware there's a ton of messages on here but i'm starting from the top here. Weirdly i get a can't connect to the repository error on Kodi. I've manually installed the repo by sshing the Zip over to storage, it installs fine however i then can't seem to enter it at all? Running V20 RC1 has anyone else seen the same ?
(2023-01-02, 06:15)AchillesPunks Wrote: [ -> ]scan your media in again and select the HDD they the movies are on...
Thats what ive done for the majority of my media i.e TV Shows and Movies and they play fine. Its just if i wanted to watch a video file direct from external HD without adding it to the library you now cant with this skin enabled. Its not a Kodi problem it is a problem with this skin as files play fine from an external HD when this skin is disabled. Also noticed that streaming video from Video-add ons also do not work with this skin enabled. Seems im not the only person with this same problem. Thanks for the reply!
