(2023-05-22, 00:13)Maximo88 Wrote: [ -> ]I got what's you told me, I wonder why I'm not getting contents in that widget beacuse I could get contents on it before. Titles like The walking dead, Breaking bad, GOT, How I meet your mother, Stranger things all of those titles were showing on that widget.
Can you give me a few titles that are showing at you end?
They are not displayed because, if I'm not mistaken, the condition for that widget is that the content is no older than one year (one year since it was created on the computer). When you insert a new tv show it should be displayed. I'm telling you again, replace the widget. That particular widget does not have to be in that place.
Does anyone know where to change the "Seasons" and "Ended" expression? Cannot find it in the .po file. Season (singular, msgctxt "#320003") translates fine, but "Seasons" (plural) doesn't.
Do you have any updates from all of the warnings that keep appearing in my logs ? Is this to do with titan bingie mod or is it one of the helper service dependencies?
Is there a possibility to show the left Menu (if selected) not in Big White rather in Big Black, or inother color
(2023-05-24, 16:47)hanniball Wrote: [ -> ]Is there a possibility to show the left Menu (if selected) not in Big White rather in Big Black, or inother color
You would need to edit Includesbingie.xml about halfway down and look for side icons.
(2023-05-22, 00:40)childofkorn Wrote: [ -> ]Have you tried pointing that widget to another location/list? One you know has items on it that otherwise load normally.
Thanks, trying to another location works for some reason in my NAS didn't work but locally does.
(2023-05-22, 07:02)matke Wrote: [ -> ]replace the widget. That particular widget does not have to be in that place.
That's work, I was focus in Bingeworthy TV Shows. I pointed it to another place and works local or NAS.
TVM @
matke and @
childofkorn
Hi all,
sorry for the noob question, but I've added a menu item "Kids TV Shows", and what I'd like for it to do would be to behave just like the original Home/TV/Movies menu items where I get the dynamic Netflix interface. On my Kids TV Show page, it's just Bingie Main Poster view but just behaves like a list. How can I change this behavior to better reflect the Netflix style w/ the spotlight and everything? Also, I can't seem to actually access the main menu from Kids TV Shows unless I hit ESC and return to Home. How can I change that? Thanks for your help!
pic of the Kids TV Shows page
https://ibb.co/pWcVwyn
Can't access menu from Kids TV Show page, only the Options menu
https://ibb.co/kxQ4Ggx
(2023-05-28, 19:04)solidsnack Wrote: [ -> ]Hi all,
Maybe someone like @
matke or @
AchillesPunks can chime in on how to create extra hubs but that is what you want in this case.
Settings>skin settings>configure shortcuts>edit menu shortcuts
Add a new hub
Common>new hub
Then deactivate "lock widget hubs" inside the configure shortcuts menu.
Now go back to home and you will see your new hub, click this to open the hub and you can customise the spotlight and widgets for inside that hub.
To hide the customise menu, go back to configure shortcuts and re enable "lock widgets in hubs"
Refresh the skin and Enjoy 😉
(2023-05-22, 20:34)HisAirness23 Wrote: [ -> ]Does anyone know where to change the "Seasons" and "Ended" expression? Cannot find it in the .po file. Season (singular, msgctxt "#320003") translates fine, but "Seasons" (plural) doesn't.
It's inside the Includesbingie.xml
First picture is the Season & Second is the Status of show
thanks for the reply. I can't simply translate the "ended" with other caractere ex : "Terminée"
(2023-06-04, 17:13)Test24 Wrote: [ -> ]thanks for the reply. I can't simply translate the "ended" with other caractere ex : "Terminée"
Of course you can't, it's tmdb data.
I think you can with a replace line php but i don't say in xml
I think it's the same "Â Â Â Â <!-- FR -->
    <value condition="String.Contains(ListItem.mpaa,France:U) | String.Contains(ListItem.mpaa,partir de 3 ans) | String.Contains(ListItem.mpaa,partir de 6 ans)">CSAU</value>"
