Hi, your skin is amaizing. But when does version 2.1 will come out? The "coming soon title has been more then 6 monthes. Whats going on with that?
(2023-12-12, 13:40){THE_DASH_ONE} Wrote: [ -> ]Hi, your skin is amaizing. But when does version 2.1 will come out? The "coming soon title has been more then 6 monthes. Whats going on with that?
It's been out for a long time now. Don't know what to tell you but update. No the update doesn't have the B icon like mine.. This is my personal build but it's the latest update
Version 2.1.1 when will be released. And will it be compatible with Kodi v21 Omega - Beta 2 ?
Hi guys. There will be an update soon. I apologize. I really don't have much time lately. To be completely honest, for the last few months I have been working on a custom version of the skin that is optimized more for Android TV because I use my xiaomi tv stick much more than my computer. Of course, the development of tbm will continue.
(2023-12-12, 17:56)etgecata Wrote: [ -> ]Version 2.1.1 when will be released. And will it be compatible with Kodi v21 Omega - Beta 2 ?
Version 2.1.1 is already out. I don't know what everyone is asking for Sorry 2.1.1 is my version but version 2.1.0 is the same
Hello,
I am having problems with the indicator for in progress items. Even though it is enabled in General Skin Settings, it doesn't show on the poster widgets as the others do (like watched items).
Below is the in progress list form TMDB. I have configured trakt as well.
But when I open the same list as library view, the indicators do show. So it means that the skin is able to retrieve them form trakt. The problem is, I suppose with the homescreen configuration or something like that.
And if I activate the Get Resume Point option form TMDB- Trakt settings it will allow the progress to show in the details section while removing all the rest:
Can someone help me to fix this?
(2023-12-12, 21:35)Zann8585 Wrote: [ -> ]Hello,
Did you activate the setting in the Home Screen?
Do you mean Skin Settings - General Skin Settings - Enable indicator for in progress items? If so, the answer is yes.
Otherwise please let me know which setting should I change.
(2023-12-12, 21:59)Zann8585 Wrote: [ -> ]Do you mean Skin Settings - General Skin Settings - Enable indicator for in progress items? If so, the answer is yes.
I mean skin settings / home settings not general. I'm not at a computer
Sorry but I am not able to find any relevant setting for this in the Homescreen Layout. Maybe you can check when it could be possible for you.
It is strange because the indicators for Unwatched Episodes and Watched Items are showing, the progress is the only one not showing form the enabled indicators.
Thanks once again!
(2023-12-13, 01:06)AchillesPunks Wrote: [ -> ] (2023-12-12, 22:24)Zann8585 Wrote: [ -> ]Sorry but I am not able to find any relevant setting for this in the Homescreen Layout. Maybe you can check when it could be possible for you.
Thanks once again!
Home Screen Settings
I have it turned off same as your screenshot. Does it work only on your precreated widget on the home hub? Because I am not using local library but TMDB Helper and the widget is created in the Movies hub.
Thank you very much for this skin. For me the best possible in Kodi by far.
I wanted to ask a question: do you see possible to add the menu option "play something" in the Leia version? (Custom_1118_Something_Hub.xml)
I'm not asking you to tell me how to do it (very old version) but if it's possible or if it's impossible because of the way it's configured and what it uses.
Congratulations for the work and support.
On my shield with fresh kodi 20.2 , it won’t let me install from your repostery , dependicies on skin shortcuts not satisfied, ect’s .
Anything I can do?
