When I get home in the morning I'll upload all files to GitHub. My mistake I thought I did but I guess I just the changed the settings and uploaded only that.
After this I will not be on for a while. Many things going on right now.
(2020-09-13, 04:37)AchillesPunks Wrote: [ -> ]When I get home in the morning I'll upload all files to GitHub. My mistake I thought I did but I guess I just the changed the settings and uploaded only that.
would it be possible to implement the changes from @
HugoL ? especially the big logo looking text labels (if clear logos are disabled), that would be nice
(2020-09-13, 05:23)daking1512 Wrote: [ -> ] (2020-09-13, 04:37)AchillesPunks Wrote: [ -> ]When I get home in the morning I'll upload all files to GitHub. My mistake I thought I did but I guess I just the changed the settings and uploaded only that.
would it be possible to implement the changes from @HugoL ? especially the big logo looking text labels (if clear logos are disabled), that would be nice
Yes whenever he's ready me or him can upload it to the GitHub. I will not be on the forums for a while after today. So it will most likely be him.
XML has been fixed for the diffuse issue. You no longer need them in the extra folder.
(2020-09-13, 13:42)AchillesPunks Wrote: [ -> ]XML has been fixed for the diffuse issue. You no longer need them in the extra folder.
Thanks friend, have you read the private ones, greetings
Hi - my widget headers scroll with the plot. Any way to fix this please (without just disabling plot scroll)? Thanks!
I like the new diffuse a lot nice work still hoping someone adds a skin option for the grey US MPAA ratings.
AchillesPunks You are really going close to professional Netflix native app , its great , one thing i think is still missing when we hit back while watching video in Netflix it doesn't go to home page but go to Resume option , Can you add in Bingie .
(2020-09-13, 17:16)spinecho Wrote: [ -> ] (2020-09-13, 13:42)AchillesPunks Wrote: [ -> ]XML has been fixed for the diffuse issue. You no longer need them in the extra folder.
Great work, thank you
I’m just making some buttons for the details row as I type this, don’t worry.
I prefer the New diffuse too. The only thing I’m not quite happy with is that it doesn’t blend as well from diffuse to transparent as the previous one did.
This is fine for the most part but for light fanart (especially when a solid colour) really makes the diffuse apparent so it’s lost it’s subtlety.
The trade-off is you get a nice bright image all the way to the edges while still hiding the edges so it will do for now. I’ll revisit it at some point I’m sure!
(2020-09-13, 22:55)HugoL Wrote: [ -> ] (2020-09-13, 17:16)spinecho Wrote: [ -> ] (2020-09-13, 13:42)AchillesPunks Wrote: [ -> ]XML has been fixed for the diffuse issue. You no longer need them in the extra folder.
What buttons are you making?
(2020-09-14, 02:07)cscott1 Wrote: [ -> ] (2020-09-13, 22:55)HugoL Wrote: [ -> ] (2020-09-13, 17:16)spinecho Wrote: [ -> ]Great work, thank you
Buttons to switch between UK icons and classic text/flag MPAA. Option to add audiocodec to details row (to get the ATMOS icons etc). Obviously only works if you have audio codec info in your library or your addon.
Since a few people were asking, I added a button to try out my personal edit with with IMBD/RT ratings Replacing % liked on details row.
Going to update the text titles too and provide a full change log.
But I’m heading to bed and will provide the update in the morning.
(2020-09-10, 18:19)HugoL Wrote: [ -> ]I can send you something to test.
No rush but any updates on this?
(2020-09-14, 10:40)ronnel Wrote: [ -> ] (2020-09-10, 18:19)HugoL Wrote: [ -> ]I can send you something to test.
It’s coming on the update which is happening today. I reverted that section close to original so I’m guessing it fixed it but you’ll have to let me know since I can’t test the progress bar.
(2020-09-14, 11:30)HugoL Wrote: [ -> ] (2020-09-14, 10:40)ronnel Wrote: [ -> ] (2020-09-10, 18:19)HugoL Wrote: [ -> ]I can send you something to test.
Alright, got it.
May I know which part of xml was changed so I would have an idea where it went wrong?
