Hello,
Not sure how to fix this problem, but my continue watching section displays multiple episodes for the same show just like in the picture.
I'm using trakt for scrobbling.
Is there an option to collapse all the continue watching episodes to one playlist, or for Titan to pick the most recent one and ignore the others?
I've been searching quite a while but still cannot figure out how to change the thumbnails/cover art for the Genres widget on the home screen or under Movies > Genre. Any help is appreciated, thanks.
(2023-03-29, 17:21)HisAirness23 Wrote: [ -> ]I've been searching quite a while but still cannot figure out how to change the thumbnails/cover art for the Genres widget on the home screen or under Movies > Genre. Any help is appreciated, thanks.
You will have to decompile Textures.xbt file which is located in the media folder - afterwards you will find things you looking for inside one of the folders
https://kodi.wiki/view/TextureTool
Hey there bubba, your work is amazing! Thank you!
I'm a first time poster here but I've been reading for a few week now and I know I remember seeing the fix somewhere. Sorry in advance.
When I go the Episodes it's showing out of order from release date. I remember there was a guy with the same problem and I've searching for 2 days trying to find it in the thread.
(2023-03-31, 19:24)Zerokool Wrote: [ -> ]Hey there bubba, your work is amazing! Thank you!
While in Episode view hit left and select sort by episode. Everyone needs to try the options in the skin and most of the time you will find your answers.
When I try to play unscanned media it looks like it will start (I see the spinning circle) and then it stops, it only happens with this skin, I searched the forum and saw a few others have experienced this problem but I couldn't find any solutions other than one person did a full re install of kodi and the skin. I uninstalled the skin and deleted all settings, restarted kodi, installed the skin. and with a fresh skin install I was able to play unscanned media, so then I did a skin restore and tested playing the unscanned media and it failed to play. so I ran a debug log, I tried to play the video file "Dan Gable Full Documentary" Line 4144
UPDATE: so others know what I did to solve this promblem
Uninstall the skin.
Restart kodi
install Titan Bingie Mod
Verify you can play unscanned media
reconfigure skin settings
should be good to go now
Oh I know about the options to change the sort and filters on the left hand side but it's completely grayed out and I'm unable to change it it's permanently locked on air date I believe I change something in the setting somewhere and I'm trying to find it there was another person who would asked about wrong order of next up episodes and I'm trying to find that post within this thread because I believe that is my answer
(2023-04-04, 19:23)Zerokool Wrote: [ -> ]Oh I know about the options to change the sort and filters on the left hand side but it's completely grayed out and I'm unable to change it it's permanently locked on air date I believe I change something in the setting somewhere and I'm trying to find it there was another person who would asked about wrong order of next up episodes and I'm trying to find that post within this thread because I believe that is my answer
The important difference is whether you use binge episodes or binge seasons view. I would say you use bingie seasons view. Sorting is not possible there because you are actually in the season level and not in the episode level.
Okay so I had no clue it was depending on The view type you were using I am definitely using the seasons view not episodes I build with the movie database helper and then point to another add-on I've got both of those add-ons set the seasons view I still think there's a setting somewhere in one of these services that I've changed to mess up the view and it may be something to do with my trak history next up settings but I'm dug through both of those and can't find it
(2023-03-30, 15:27)awesomebuilder Wrote: [ -> ]You will have to decompile Textures.xbt file which is located in the media folder - afterwards you will find things you looking for inside one of the folders
I only found a categories folder inside the Bingie folder in the textures file. Changing the png files did nothing though. I cannot find anything related to genre. I just wanted to replace the fan art / background images for the "Movies > Genre" view.
Hey i'm having a issue everytime i install the skin it says the dependency in script.skinshortcuts version 2.1.0 could not be satasfied
(2023-04-06, 18:14)TheDeatCrusher Wrote: [ -> ]Hey i'm having a issue everytime i install the skin it says the dependency in script.skinshortcuts version 2.1.0 could not be satasfied
Try
this.
AchillesPunks Maybe this should be added to the first post? Seems like such a common issue for many, but with a very simple fix.
Hi everyone,
Some friends of mine experience some issues like on the pictures they dont have media information or when they have informations, they dont have focus( the white rectangle) aparently, this happen after updating from kodi 20 to 20.1
Hello guys,
Is the skin compatible with Kodi v20.1 (Nexus) ?
Thank you
Chris
