(2023-02-21, 13:34)gecmali Wrote: [ -> ]Some movies lasts over 3 hours or you just get interrupted with something...
You are constantly looking for something in the wrong place. The skin uses the skin helper widget but I don't maintain that addon. You must ask for such requests on the dedicated page.
(2023-02-21, 13:41)matke Wrote: [ -> ] (2023-02-21, 13:34)gecmali Wrote: [ -> ]Some movies lasts over 3 hours or you just get interrupted with something...
OK, can You just tell me what item from the skin helper widget You are using by default for the first widget Continue watching and also for the bingworthy tv shows ?
Because it's only possible to change the order of the widgets by changing them and when I replace this two I can't put them elsewhere.
(2023-02-21, 17:16)gecmali Wrote: [ -> ] (2023-02-21, 13:41)matke Wrote: [ -> ] (2023-02-21, 13:34)gecmali Wrote: [ -> ]Some movies lasts over 3 hours or you just get interrupted with something...
Continue watching - shs
bingworthy tv shows - playlist
I belive the first home widget by default uses the exact same location as the one you pointed to in the screen shot (continue watching movies and TV shows)
Addon>video addon>skin helper service wizard>mixed media>
Binge worthy tv shows is from the playlists created.
Video libary>playlists>
I think you would need to edit this playlist with a txt editor to remove/change sort order if setting it in the widget dosnt work
gecmali
The continue watching in SHS is the inrogress media. You can see the continue watching and inprogress are the same thing.
Thanks, do You know what's the difference beetween "In Progress TVShows and Movies" and "In Progress Media"?
(2023-02-21, 20:44)gecmali Wrote: [ -> ]Thanks, do You know what's the difference beetween "In Progress TVShows and Movies" and "In Progress Media"?
Progres media also includes music.
What is the prerequisite for Spotlight content to spin automatically?
I tried to link the imdb and tract lists but they are idle after loading the first item... Is it even possible for content outside library?
AchillesPunks & @
matke : Noticed a Bug: Setting up Widget for "my list" On the Home menu the ratings are hidden behind the posters , changed to landscape and were still partially hidden.
As you know there is only 1 Widget available for "My List" and that has this widget & Ratings placement issue.
At present I have removed the widget from My list ( which is the last Home menu) . Instead I am using another widget in the movies menu.
Its no biggie but just wanted you guys to know regards this.. ( I think you guys are probably aware already)
Kindly see the issue in the video.
By the way the Skin & Kodi is Rock solid and after a long time its been so reliable and glitch free & truly just enjoyable !
Hats Off to Achilles P & matke !
(2023-02-25, 20:36)shaktoo Wrote: [ -> ]@AchillesPunks & @matke : Noticed a Bug: Setting up Widget for "my list" On the Home menu the ratings are hidden behind the posters , changed to landscape and were still partially hidden.
The problem is with "Recently added albums" widget. As you can see it is not a poster widget but a square widget. Different widget layouts cannot be mixed except for the last one. And the last one is also intended for widget categories (last is my list hub). But try to put this widget as the last one. It should work.
I feel like I'm missing something simple, so apologies in advance. I have used the function "Edit menu shortcuts" to make it look like this:
But when I navigate back to the home screen, it looks like this:
What am I missing to make the changes take effect on the home screen?
AchillesPunks I think you are missing the Simple PVR view from WatchedIndicatorLayout in IncludesViews.xml. Watched progress indicator was missing in that view but adding the following to the first visible rule fixed it: [Control.IsVisible(10) + Skin.HasSetting(MovieDetailsHome)]
Skin didn't work on our Vero (frequent crashes, laggy..) so I went and bought a Shield TV Pro. Running Nexus nightly and the only problem I've found is that subtitle color setting is not visible in settings. But the workaround was to temporarily revert to another skin to change that setting.
Thanks @
AchillesPunks and everyone else who have contributed!
Or you have young kids and you never ever have that 2 or 3 hours to finish a movie in one go
Which brings to my mind something that I've been wondering a lot. Would it be possible to exclude kids movies and shows from some of the views or widgets by editing the skin? like categories, Surprise me, New & Popular..
We have kids content on separate libraries in Plex and are using PlexKodiConnect so they are automatically tagged with something along the lines "Kids TV" and "Kids movies". I can create smart playlists by using these tags so some of the widgets I can change easily.
I'm not asking for instructions. More like a high level yes/no answer
(2023-02-28, 23:40)gaze Wrote: [ -> ]@AchillesPunks I think you are missing the Simple PVR view from WatchedIndicatorLayout in IncludesViews.xml. Watched progress indicator was missing in that view but adding the following to the first visible rule fixed it: [Control.IsVisible(10) + Skin.HasSetting(MovieDetailsHome)]
Thanks @AchillesPunks and everyone else who have contributed!
It is not clear to me why the watched indicator is needed for pvr view when it is only used for watching live programs.
Kodi crashes on Android because you are using stable nexus 20. To avoid crashing, you have to install the latest nightly version of nexus or wait until 20.1.
(2023-03-01, 01:59)matke Wrote: [ -> ]It is not clear to me why the watched indicator is needed for pvr view when it is only used for watching live programs.
We use PVR mainly for watching recordings so on the recordings list we need the watched percentage
Vero 4K is not Android and only Matrix is available for it. But skin is causing crashes a lot. This device is quite under powered. On Shield TV Pro (Android) the stable was crashing but thanks to this thread I knew to install a nightly. It's very stable now on Shield TV Pro and Nexus nightly.
