Was wishing that you could just upgrade the mod, but Had to uninstall kodi completely to do a full fresh install. Apart from that all is looking sooo good ๐ thank you guys ๐
Loving the screensaver (one of the things I've been wanting for ages) I have only set up the screensaver/home hub and a few widgets to an addon for the time been, to see what its all like (while my libary is re-added) but the ratings e.c.t are all look realy good.
One question, as I couldn't seem to find it anywhere. Does the clearlogo in home hub not shrink (hiding the description/details e.c.t)any more once idle? I've notice things have been resized and moved a bit so maby not.
Now just a 3 day wait for my tv and movie libary to be re added and I can set the rest up ๐
Edit: 10% through my tv shows and I forgot to set up a advanced settings to import watch state ๐ฅฒ nooooooooo SMH ๐คฆโโ๏ธ
Thanks again and happy new year!
(2023-01-01, 16:32)childofkorn Wrote: [ -> ]One question, as I couldn't seem to find it anywhere. Does the clearlogo in home hub not shrink (hiding the description/details e.c.t)any more once idle? I've notice things have been resized and moved a bit so maby not.
It hides when watching trailer, that's how it is in Netflix. But I think I will add an option to hide it even during idle mode.
(2023-01-01, 18:14)matke Wrote: [ -> ] (2023-01-01, 16:32)childofkorn Wrote: [ -> ]One question, as I couldn't seem to find it anywhere. Does the clearlogo in home hub not shrink (hiding the description/details e.c.t)any more once idle? I've notice things have been resized and moved a bit so maby not.
Having it have an option to shrink/hide the description/genre e.c t in the spotlight widget on the home hub when idle and just have the clearlogo and play and more information button(how it use to be in the previous version) would be really nice, but no biggie if not.
Can anyone help? Keep on getting a 'Failed to install dependency' error. Uninstalled Kodi 19.4 and did a new install of 19.5 before tried applying skin. Deleted data/org.xbmc.kodi folder too but still getting same error. Seems to fail when trying to install TVDB API v2. Any suggestions? Thanks.
(2023-01-01, 19:08)loki00 Wrote: [ -> ]Can anyone help? Keep on getting a 'Failed to install dependency' error. Uninstalled Kodi 19.4 and did a new install of 19.5 before tried applying skin. Deleted data/org.xbmc.kodi folder too but still getting same error. Seems to fail when trying to install TVDB API v2. Any suggestions? Thanks.
Did you turn on Kodi option?
Update official add-ons from: Any repository
(2023-01-01, 19:22)matke Wrote: [ -> ] (2023-01-01, 19:08)loki00 Wrote: [ -> ]Can anyone help? Keep on getting a 'Failed to install dependency' error. Uninstalled Kodi 19.4 and did a new install of 19.5 before tried applying skin. Deleted data/org.xbmc.kodi folder too but still getting same error. Seems to fail when trying to install TVDB API v2. Any suggestions? Thanks.
Turn on 'Kodi Option'? Im not sure what you mean?
'Update official add-ons from: Any repository' - I let Kodi Auto Update when it first booted up after fresh install.
I tried individually installing dependencies but it seems to fails at Metadata and Artwork module.
(2023-01-01, 19:31)loki00 Wrote: [ -> ] (2023-01-01, 19:22)matke Wrote: [ -> ] (2023-01-01, 19:08)loki00 Wrote: [ -> ]Can anyone help? Keep on getting a 'Failed to install dependency' error. Uninstalled Kodi 19.4 and did a new install of 19.5 before tried applying skin. Deleted data/org.xbmc.kodi folder too but still getting same error. Seems to fail when trying to install TVDB API v2. Any suggestions? Thanks.
You have an option in Kodi "Update official add-ons from". Set to "Any repository".
(2023-01-01, 20:05)matke Wrote: [ -> ] (2023-01-01, 19:31)loki00 Wrote: [ -> ] (2023-01-01, 19:22)matke Wrote: [ -> ]Did you turn on Kodi option?
HAHA. I was looking at that option and thinking wether to change it or not but thought it had nothing to do with the installation process. But, yeah its obvious when you think about it!ย
Thanks for the help! I tried so many installs! Can confirm it now installs!
Hello! Happy New Year to everybody!
Apologies in advance for the message, I'm writing with the help of a translator.. Wanted to thank you so much for this incredible update!ย Thank you so much for this Christmas present! The only thing I noticed is that for some reason the "Categories" tab in the main menu does not work for me. Everywhere it shows that "No items in this Category" I think that this is due to the fact that the content genres are written in Russian. I tried to somehow do something with this so that it would also display Russian genres .. But to no avail. Could you please help with this problem?
And yet, so as not to get you once again, I have a request at will! The fact is that I sorely lack a button in the OSD Menu that would allow me to switch the next and previous episodes without leaving the OSD Menu .. I really really miss this opportunity! (Many thanks to you again for this Christmas present
The new update is already
I cant seem to play any video file directly from an external HD when i have this skin enabled? Files play fine if i have them scanned into the library, but wont play via settings>Media Settings>Videos...>HD. It tries to play and then nothing happens. When i try to do the same thing with Kodi's default skin (Estuary) they play just fine. Is there a setting that needs to be disabled/enabled that im missing? Thanks
I have the same problem. I can't play any video file directly from external HD. Before I updated the skin, I had no problems with an external HD.
scan your media in again and select the HDD they the movies are on...
