Guys I don't know which repositories you use since AchillesPunks and me haven't set up a new repo for kodi matrix in public yet. We work as much as we have time. Please be a little more patient. Thanks.
(2021-04-17, 19:50)matke Wrote: [ -> ]Guys I don't know which repositories you use since AchillesPunks and me haven't set up a new repo for kodi matrix in public yet. We work as much as we have time. Please be a little more patient. Thanks.
Thanks, sorry though it was posted...
Thx thx thx
And I hope ready very soon
heya! And we appreciate it! Sorry, I did not mean to be disrespectful. I thought I was doing something wrong.
I went to
https://github.com/AchillesPunks/Bingie.Mod.Matrix.Skin as per direction on the first post which directs to install the Bingie repo and then the skin.
(2021-04-18, 01:58)cezare Wrote: [ -> ] (2021-04-17, 19:50)matke Wrote: [ -> ]Guys I don't know which repositories you use since AchillesPunks and me haven't set up a new repo for kodi matrix in public yet. We work as much as we have time. Please be a little more patient. Thanks.
I went to https://github.com/AchillesPunks/Bingie.Mod.Matrix.Skin as per direction on the first post which directs to install the Bingie repo and then the skin.
I haven't tried the Link on the first post in a while but we are almost done. Patients. I started my work week today so I will not respond until Wednesday.
BUMP
Anyone got a solution for my ratings problem? I've got it set up on my fire tv, filled in omdb api key in tmdb helper, universal movie scraper, metadata and utils and even S@
Ren,,,,
Yet I don't get ratings for most items....
Heck my simplecache.db file even disappeared completely
(2021-04-19, 21:38)Thomiehawk Wrote: [ -> ]BUMP
Anyone got a solution for my ratings problem? I've got it set up on my fire tv, filled in omdb api key in tmdb helper, universal movie scraper, metadata and utils and even S@Ren,,,,
Try:
Settings/skin settings/general skin settings/skin helper settings
Enter your API keys
Enable skin helper artwork lookups
TV Shows Season artwork is not visible, if I switch to default skin than season artwork visible again.
How to resolve this issue?
(2021-04-19, 23:03)matke Wrote: [ -> ] (2021-04-19, 21:38)Thomiehawk Wrote: [ -> ]BUMP
Try:
Enter your API keys
Checked, omdb and fanart.tv credentials were already filled in there... enabled skin helper artwork lookup, still no result.
Perhaps is omdb api key limited to 1 device? Shouldn't be the issue because they're on the same public IP so it should not be a problem.
(2021-04-16, 21:15)nazim12 Wrote: [ -> ]@Achiles How can we resize ''fix focus Frame'' size ? I just want minorly increase the size of Frame.
Any Reply regarding this?
(2021-04-20, 17:06)nazim12 Wrote: [ -> ] (2021-04-16, 21:15)nazim12 Wrote: [ -> ]@Achiles How can we resize ''fix focus Frame'' size ? I just want minorly increase the size of Frame.
Settings/General skin settings/Bordersize for focused thumbs/tiles
(2021-04-20, 19:03)matke Wrote: [ -> ] (2021-04-20, 17:06)nazim12 Wrote: [ -> ] (2021-04-16, 21:15)nazim12 Wrote: [ -> ]@Achiles How can we resize ''fix focus Frame'' size ? I just want minorly increase the size of Frame.
Sorry not what I meant , I have increased Poster size and if I Choose Fix focus Frame Movement then default size of frame doesn't applied on my increased size posters so I need to increase frame size as well to match with poster size .
(2021-04-20, 20:46)nazim12 Wrote: [ -> ] (2021-04-20, 19:03)matke Wrote: [ -> ] (2021-04-20, 17:06)nazim12 Wrote: [ -> ]Any Reply regarding this?
Just woke up and heading to work again. I'll help tomorrow. I thought I had answered this before.
I'll look at this tomorrow
