Another Issue I have. After the youtube addon plays a trailer of a movie that is selected, if I move to another movie, Kodi crashes.
is there any solutions to this?
happens after a clean install on 19.5 with only fen and youtube addon installed...
(2023-01-18, 17:22)Sharon1122 Wrote: [ -> ]Another Issue I have.
We have 2 issues...
1) Do not double/triple post the same question on this forum. There are restrictions in place for newcomers posting any type of internet links. So some delay is possible.
2) Do not come to this forum when your Kodi setup has one of more add-ons installed that facilitate any type of video piracy. As per our
forum rules (wiki) and
piracy policy (wiki), this "problem" will be addressed by the moderators.
im new in this forum and accidently didnt quote the original message didn't think it was a big deal.. anyway, sorry didn't mean any trouble.
Edit :
i ended up reinstalling the skin for the 3-4 time and i dont have that issue anymore somehow..
only thing changed was i installed the youtube addon through zip before installing titan bingie & i was making sure that im installing every dependency through the titan repo and not the kodi one. seems to work perfectly so far!
also forgot to thank dev for this incredible skin i really love it!
I would like to enable auto rotation to one specific widget (Channels widget under PVR Hub), can anyone guide me on how to do that? and which xml file to modify? Thanks
(2023-01-18, 17:01)matke Wrote: [ -> ] (2023-01-18, 15:54)loki00 Wrote: [ -> ]Any idea why the skin keeps reseting back to default settings? Just started up Kodi and it showed the theme setup page. It has happened twice now? Just wondered if anybody has experienced similar problem..
Which platform is (PC, Android...)? What is the kodi version? Please leave a log file when the settings in the skin are reset. I can't help you otherwise.
Im still on Matrix 19.5. Using Android on a Shield Pro. Ill just see how things go. Its no big deal. I just had to set my widgets up again and other various settings. Shouldve made a back up of my settings really. But i forgot! If it happens again ill upload my log. Thanks!
(2023-01-19, 15:35)loki00 Wrote: [ -> ] (2023-01-18, 17:01)matke Wrote: [ -> ] (2023-01-18, 15:54)loki00 Wrote: [ -> ]Any idea why the skin keeps reseting back to default settings? Just started up Kodi and it showed the theme setup page. It has happened twice now? Just wondered if anybody has experienced similar problem..
How turn off shield? I ask because if you turn off shield while Kodi is on, this can happen. It is very important to turn off Kodi and then shield.
Hello...
First i need to say: i love your skin
I had to reinstall and now i miss something:
1. Before on the top left corner i had the MPAA or german FSK rating. now it doesn't show
2. I see only TMDB and only on some movies the Trakt and Metacritic ratings, but never the Rotten and IMDB ratings.
How can i enable it?
Repo down? I've tried from the official repository
https://achillespunks.github.io/reposito...ingie.mod/
Clean install of Kodi 19.5 I can add it as a source, but when I try to install from zip file it just hangs and does nothing. Same thing with clean install of 20. Literally all I've done is turn off gui sounds, enable unknown sources, and allow updates from any repos.
your skin is great ! can you add seek (backward, forward) to bingie osd video layout?
thank you
The link is on the first page. No need to search through the GitHub
Is it possible to make “tap and hold to voice search” work on the small keyboard in the Search hub? It works right now only when switching to the full keyboard.
Still really enjoying this skin btw. Great work! :-)
Hi guys
Just came here to say thank you for this brilliant update! Just spent today setting up the skin and the integration with TheMovieDB Helper is just pure genius!!
Hi, again, when update the libraries with news films and tvshows I can see the collection s and another info like cast, crew, etc. Then when I close my conn to internet (I just use it to scrape films and tvshows and get artworks) I can't see anymore those info, cast crew, collections in the dialog video info. There is a way to get that. Thanxs
