(2022-10-14, 23:18)awesomebuilder Wrote: [ -> ] (2022-10-09, 02:36)biomecanoid Wrote: [ -> ]All my shortcuts have the same icon which i can not change as the "set icon" does not work does nothing:
There is a little work around to fix this manually but you will have to be able to edit few files preferably on the laptop/pc and you will need to be able to navigate to kodi folders/files.
Both files are located within userdata\addon_data\script.skinshortcuts.
First file to edit will be mainmenu.DATA.xml and look for main menu line <icon>YOUR ICON LOCATION</icon>
Second file to edit will be skin.titan.bingie.mod.properties and look for lines with "icon" words for example ['mainmenu', 'audio', 'icon', 'YOUR ICON LOCATION'],
Both files contains information about main menu items on your Kodi setup and make sure both files matching. Example from my set up.
mainmenu.DATA.xml :
<shortcut>
<defaultID>audio</defaultID>
<label>Audio</label>
<label2 />
<icon>shortcuts/music.png</icon>
<thumb />
<action>ActivateWindow(Programs,"plugin://plugin.program.autowidget/</action>
</shortcut>
skin.titan.bingie.mod.properties:
['mainmenu', 'audio', 'icon', 'shortcuts/music.png'],
and as you can see both files matching icon location/name (shortcuts/music.png)
save and enjoy
Thank you I will try that
Hello everyone,
Is the skin still maintained?
Is there any official support for Kodi Nexus?
I don't see any recent activities in the github repository.
lanzorg
Yes the work is private on the GitHub you can't see it. It will support Nexus when it's more stable.
As @
AchillesPunks said of course he wasn't abandoned. It's still early for kodi nexus. When it enters the stable version, then we will think about it. The menu icons have been fixed and in the next update they will be able to be changed without any problems. And that's just one little thing that comes with the next update... I can't promise anything yet when exactly it will come out, because there is still work to be done with the skin and I have a lot of my work and not enough time. But believe me, it's worth waiting a little longer.
I will wait a little longer, not too much hopefully.
Could anyone point me out where I can find option to change frame colour. Looking to change it from white to red. It is for widgets.
EDIT:
Found it!
For widgets -> Skin settings -> Custom colour settings -> Home border focus colour
For media within addons -> Skin settings -> Custom colour settings -> Media list item border focus colour
Has Anyone figure out, why there is a bootloop when installing this skin Matrix 19.4 on the Mac OSX. It Loads the Netflix video file, then opens an copy of kodi, and keeps repeating this
Hi all I need some help, this morning I put the shield on and my widgets have lost all meta data, If I click on them for information of the movie that is there but just going back to the list my widgets have no detail, I think this has something to do with the skin settings or is my library missing something?
In my library I just have the movies, I don't have software or separate folders for meta, Artwork Beef just gets it and seems to put all the right details into place. but now it wont fix this issue.
Is there a better way I should be setting up my library?
https://drive.google.com/file/d/1jcMdFCa...sp=sharing
Matrix script.skin.helper.service - is incompatible with 19.2 upwards on osx, it Causes a Infinite Restart Loop,
This the root cause, gone by a process of elimination. when I launch the App it keeps opening new instances of Kodi until infinity. I started it and went to get a coffee and when I came back I had 20 instances of Kodi open and my Mac was completely unresponsive, obviously.
https://paste.kodi.tv/ikaqehakuk.kodi
(2022-10-18, 14:51)Ismadder1 Wrote: [ -> ]Matrix script.skin.helper.service - is incompatible with 19.2 upwards on osx, it Causes a Infinite Restart Loop,
Why would you not report it to the relevant Devs ? These guys has nothing to do with skin helper add-on
Because its Automatically download as part of the there Skin, its Dangerous to an add-on that can be harmful to a machine, when its in a infinite loop its hard to get out of it, with out shutting the machine down, then if you machine reboots in the same state as a lot of osx to you have to be real quick to close kodi. Im sure the developer of the skin does not want to include a harmful add-on !!!
Ismadder1
The addon is needed for the skin it doesn't have the issue on windows. I do not have a Mac so I cannot test.
I installed the skin a week ago and it's awesome! The only issue I'm having is it 's not cycling thru the extra fanart in my movie and tv libraries, even though when I go into choose art for a movie I can see Fanart 1 Fanart2 etc. listed as current and local art. I used Artwork Dump to DL them. I don't have extra fanart disabled in any views I'm using. Any ideas or suggestions? I should mention I have 19.4 installed on an Amazon Firecube, so can't access or edit any files. Thanks.
Hi all, new here but have been using Kodi for quite some time now but mostly on it's native skin. I came across this skin and wow it's amazing looking but as an old noob (late 50's) I am having some challenges. It's amazing to see what some of the posters have been able to master.
1st off since I have installed the skin I no longer have access to install addons when I go to settings/addons I get a black screen. Is this normal I'm running Kodi Matrix 19.3 on Google Chrome with Google TV.
I don't know how to add the red bar that shows how far I have watched an episode plus my episode window only shows the episode on the right side with the episode information but nothing on the left side showing seasons (is there a special setting that I should be doing for that?)
How can I make the search look like the Netflix search where as I type it autocompletes and brings up recommendations in the right window.
Also I noticed that there where Category widgets when I loaded the skin but have no Idea how to customize the categories to reference my addons.
Is there an Indepth tutorial to show how to navigate and take advantage of all this skin has to offer?
When checking Youtube all I found was a couple of videos in French which although looked amazing did not help in any way.
Also can I set some widget in the home menu some in Panel and 1 in poster because I finally figured out how to add my favorites but the get squished in panel view and I like it more than Poster.
Once again thank you so much for your amazing work you guys are amazing an older guy like me is just in Awe at what you guys can do.
I would also like to know how I can make the spotlight change from one movie to another on it's own so it is not static.
