I found a problem: when I choose bingie poster (or fanart) layout view, after that I go to all movies, the total count of media appear but if I choose by genre for example comedy or by country ( like France etc ...) The total count media disappear. Can some one fix this ?
(2023-07-19, 08:40)loveart Wrote: [ -> ]I found a problem: when I choose bingie poster (or fanart) layout view, after that I go to all movies, the total count of media appear but if I choose by genre for example comedy or by country ( like France etc ...) The total count media disappear. Can some one fix this ?
Total media count only shows for all movies. If you switch to genre you will not get the media count. It's not a problem it's set this way.
This template is awesome, sham eis it picks all text online in english, can it be configured somehow? I fail to find it, all nfo is in spanish...
I'll happily take on translationfor my languages, where do I sign for?
I love your skin so much but default it does not support full unicode chacracter. so i look at file font.xml inside folder xml and change a little.
the first you must download arial full unicode font at here : download-free-fonts.com/details/88978/arial-unicode-ms and after copy file you download (must be name arial-unicode-ms.ttf) to Kodidata/addons/skin.titan.bingie.mod/fonts
the second, open file font.xml in /Kodidata/addons/skin.titan.bingie.mod/xml/ by any strong text editor and the replace all Netflix-sans-Bold.ttf, Netflix-Sans-Light.ttf, Netflix-Sans-Medium.ttf to arial-unicode-ms.ttf
final open kodi and check for something is china/korean/japan character is show right.
I hope whom develepers of this skin will add full unicode character to default. Thank for your incredible work!
hello
I search for old settings where you can change layout for widget now I can't found this
(2023-07-25, 20:21)Test24 Wrote: [ -> ]search for old settings where you can change layout for widget now I can't found this
Please be aware of our
Forum Rules and
Banned Add-ons (wiki)
Your image shows
Banned Add-ons (wiki) are installed on your system which are banned from this forum.
lol the screen it's not mind I found it on the web. I would like to change layout for widget. If I do this screenshot . I don't ask for add layout widget this option.
(2023-07-26, 17:47)Test24 Wrote: [ -> ]lol the screen it's not mind I found it on the web. I would like to change layout for widget. If I do this screenshot . I don't ask for add layout widget this option.
Layout is set for all widgets now, not individually
Curious, I don't know if this is related to earlier convo about the widgets. But today, for some reason, the TV shows and movie sections are now coming up with a request to set labels. I don't know anything about that but it wasn't like that prior to today. I liked how it was, just preset. I tried to reset the widget info to default as well as the skin Settings. I also, changed the skin back to Estuary and then back to Bingie and it is still all there. Is there a way to just put it back to what it was? Thank you!
(2023-07-27, 06:44)davelee77 Wrote: [ -> ]Curious, I don't know if this is related to earlier convo about the widgets. But today, for some reason, the TV shows and movie sections are now coming up with a request to set labels. I don't know anything about that but it wasn't like that prior to today. I liked how it was, just preset. I tried to reset the widget info to default as well as the skin Settings. I also, changed the skin back to Estuary and then back to Bingie and it is still all there. Is there a way to just put it back to what it was? Thank you!
If it's asking you to set labels then you've checked the setting that allows you to change the label.
I'm at work so I can't tell you what it's called but you'll have to look for that setting before it's fixed.
Ok. That gets me in the right direction. I will be sure to check it in the morning then. Thank you so much. There are tons of options in the skin and the controller I use gets funky sometimes and clicks on things I didn't intend. So I'm not surprised. Thank you!! Otherwise loving it and my daughter and son-in-law do too!
Sorry I didn't get back to you sooner. Always a simple answer. lol Menu>Settings>Skin Settings>Configure Shortcuts>Lock Widgets in Hubs(Toggle) Thanks for pointing me in the right direction!
Hello everyone.
Had been away for a month. Came back to find a situation of no studio logos being displayed across Local media.
Kodi 20.2 , windows ( i am moving towards making my primary Kodi on Shield / Android as windows there are lots of L1 Widevine issues with Official addons )Latest Skin and all updated addons.
All the media have dedicated nfo's with a single studio, metadata & artwork utility with omdb keys are all configured appropriately. I have deleted simplecache.db several times & refreshed the media but still no Luck ? Any idea ?
(2023-08-03, 22:14)shaktoo Wrote: [ -> ]Hello everyone.
Two things come to mind. You haven't turned on studio logo in settings or you haven't installed studio logo resources.
