Has the skin been updated recently? Havent seen anything on the repo yet. I just get all excited when i hear update!
Sad i know.
But when I go to skin it says "Titan Bingie Mod". Oh well. Will try a different skin out. Titan Mod works good enough, will stick with that. At least TV info works on Titan Mod.
Guys, I cannot defeat the black screen. I am attempting to set the skin up using the jellyfin for kodi plugin. Has anyone managed to get this working with that plugin or plexkodiconnect? Running out of ideas
(2021-05-17, 15:35)Littleceezer Wrote: [ -> ]But when I go to skin it says "Titan Bingie Mod". Oh well. Will try a different skin out. Titan Mod works good enough, will stick with that. At least TV info works on Titan Mod.
Then you have the first skin ever made. Your side panel is not even in the skin anymore.
(2021-05-18, 01:00)AchillesPunks Wrote: [ -> ] (2021-05-17, 15:35)Littleceezer Wrote: [ -> ]But when I go to skin it says "Titan Bingie Mod". Oh well. Will try a different skin out. Titan Mod works good enough, will stick with that. At least TV info works on Titan Mod.
I have the the newest skin. The picture I took WAS from Titan Bingie, my apologies, I was switching between different skins and tinkering with settings. BUT! It still happens even on the newest skin. I'll take some screenshots here soon and show you. Same exact thing on TITAN BINGIE "MOD".
It does not show episode info in widget. It just says NEXT EPISODE IN. Is it even possible to see episode info in widget for episodes?
Info for everything else shows. Movies. TV series. Just not Episodes in home widget.
I don't even know how to XML...If I changed the XML it was an accident because I have no clue what XML is.
(2021-05-18, 08:15)Littleceezer Wrote: [ -> ]I don't even know how to XML...If I changed the XML it was an accident because I have no clue what XML is.
Looking at the pictures it has been. You have red lines under all your Hubs. I'll have to look at the episode info on Wednesday.
(2021-05-10, 14:01)Giant_Midget Wrote: [ -> ]Just wondered if there was anything that could be done about this? https://imgur.com/a/gXNhe2T
Probably just me being pedantic but would like it to show the whole word rather than [...]. If not, no big deal 🤷♀️
I'll fix this on Wednesday or Thursday. I still have to upload some things to GitHub.
(2021-05-18, 11:12)AchillesPunks Wrote: [ -> ] (2021-05-10, 14:01)Giant_Midget Wrote: [ -> ]Just wondered if there was anything that could be done about this? https://imgur.com/a/gXNhe2T
Hi, fixes are updated automatically?
(2021-05-18, 11:38)fsurfer Wrote: [ -> ] (2021-05-18, 11:12)AchillesPunks Wrote: [ -> ] (2021-05-10, 14:01)Giant_Midget Wrote: [ -> ]Just wondered if there was anything that could be done about this? https://imgur.com/a/gXNhe2T
You can update through Kodi after I upload to GitHub.
(2021-05-14, 21:57)Sea Wolfe Wrote: [ -> ] (2021-05-14, 21:05)AchillesPunks Wrote: [ -> ] (2021-05-14, 17:45)Sea Wolfe Wrote: [ -> ]This skin is an amazing masterpiece--thanks to @AchillesPunks and others who worked on this!
I am trying to figure out the exact process of getting AutoWidget going with this skin. There is a video on Youtube, by "Blue" showing how to setup AutoWidget with the AuraMod skin. I have followed the steps, and gotten AutoWidget working with THAT skin (the process with that skin is fairly intuitive). But, I prefer this skin "Titan Bingie Mod.". So I am trying to figure out how to accomplish the same setup on this skin. I have the AutoWidget Groups setup. But I can't figure out the steps to get them integrated with this skin. I have made several attempts and end up getting the blank homescreen. There are some "dots" in this process I am not connecting properly.
If anyone has a working AutoWidget setup with this skin, I would appreciate you sharing a step-by-step of the final/last steps of completing the setup. Thanks in advance!
I wish I could help you with this but I have never used auto widgets.
What exactly do they do?
Thanks for the offer! I actually figured it out...and it is actually easier with this skin than with AuraMod!
So the AutoWidget allows you to link a bunch of paths, say to Trakt lists or TMDB genres etc., and can cycle through different lists, and auto refresh--that way you always see fresh content on the Homescreen (since it's not static).
Anyway, once you create the AutoWidget groups, you only have to point one single action with this skin (like from the Home Hub) to the AutoWidget Groups, and from there AutoWidget takes over, does it's magic and does the rest--pretty amazing! (I think with AuraMod you have to link to the groups separately--each group as a widget).
The part I was struggling with, and still am to a certain extent is: It seems this skin requires certain Widgets to remain. When I try to delete all the 8 Widgets, under the Home Hub, that come with the skin by default, then I end up with the blank homescreen. So it seems like certain of those preloaded widgets have to remain? I guess they can be edited and point somewhere else, but not deleted completely?
I am brand new to this skin, and coming back to Kodi after many years, so it's been a steep learning curve getting up to speed. I would be happy to help anyone else figure out this particular issue...because I literally spent days trying to figure this out...and I couldn't find any good walkthrough for this setup anywhere...
Hey, you can also use Auto Widgets in the sub menu. Just add the groups and name them for example, " Original Shows" then go to networks and create a group in AW and add, Netflix, Hulu, Amazon, HBO......and more then merge then so when you click on it it will give you all together then change the view to the Bingie Main Poster view and golden...This way you can have so many more items and not slow down the skin. Remember the more widgets you have loading the slower it will be.
But with AW I'm able to just have 3 widgets loading in the home screen then all others are under sub-menu and load them when you need them. Brilliant...
