(2023-01-02, 14:24)loki00 Wrote: [ -> ] (2023-01-02, 06:15)AchillesPunks Wrote: [ -> ]scan your media in again and select the HDD they the movies are on...
Also noticed that streaming video from Video-add ons also do not work with this skin enabled. Seems im not the only person with this same problem. Thanks for the reply!
Can anyone else confirm this? Streaming from addons is the only thing I use and would love to switch over and try the new update but it would be completely useless to me if it doesn't play streams from addons.
Thats what ive done for the majority of my media i.e TV Shows and Movies and they play fine. Its just if i wanted to watch a video file direct from external HD without adding it to the library you now cant with this skin enabled. Its not a Kodi problem it is a problem with this skin as files play fine from an external HD when this skin is disabled. Also noticed that streaming video from Video-add ons also do not work with this skin enabled. Seems im not the only person with this same problem. Thanks for the reply!
Just tell me, did you install everything from scratch, I mean both kodi and skin? Very big changes have been made to the skin, and that's probably why you're having a problem. I left you a video in the previous post, with a fresh installation everything works as it should. Movies from an external device and video addons.
(2023-01-02, 14:42)cscott1 Wrote: [ -> ] (2023-01-02, 14:24)loki00 Wrote: [ -> ] (2023-01-02, 06:15)AchillesPunks Wrote: [ -> ]scan your media in again and select the HDD they the movies are on...
I don't have these problems on a fresh install. Everything works as it should. As I said, considering that there are huge changes in the skin, there may have been some problems if an update was made. That's why I recommended doing the installation from scratch.
(2023-01-02, 14:50)matke Wrote: [ -> ] (2023-01-02, 14:42)cscott1 Wrote: [ -> ] (2023-01-02, 14:24)loki00 Wrote: [ -> ]Also noticed that streaming video from Video-add ons also do not work with this skin enabled. Seems im not the only person with this same problem. Thanks for the reply!
ok Thanks Ill give it a go on one of my devices tonight thanks for the update. It will probably take a week to rescrape everything but hopefully following updates that wont be necessary. Ill report back in about a week if I have any issues.
(2023-01-02, 12:01)roitheoden Wrote: [ -> ]Hi everybody and happy new year.
Thanks to the creator for this new release. I've been using skin titan bingie since the very first release with great pleasure.
Here is the context (@AchillesPunks).
Yesterday, my systems have been updated with the 2.1.0 titan skin. I've got one system on a Vero, and another independant system on a Windows machine. Both are working very well (Kodi 19.4 on Vero and Kodi 19.5 under Windows) and everything is uptodate.
I Can't afford reinstalling from scratch easily on my Vero, and it's not necessary, and very slow as it's a small machine like a raspberry. My system has a lots of personalization, and it would take days and days to get the same configuration. So this is excluded, except for a major disaster.
Before updating, I've verified all dependencies. I've set another skin, removed the titan bingie skin and appropriate other addons linked to titan from the addons and the settings in userdata.
I've installed with success the new skin (2.1.0 release, I was using 2.0.3 with some modifications by myself before, without any problems), no problems with dependencies, scripts and modules.
After spending 6 or 7 hours to configure the skin from scratch and make the look and feel I wanted (the same as before in fact), I noticed one thing : The white borders for the highlighted TV shows in Home page, and for the info menu for a movie or TV show (info button / Netflix like Video Bingie, not extended one), are not showing at all. Eveywhere else the borders are showing (I've disabled the circular navigation, I'm using the frame border with zoom effect in movies and TV shows). The pictures joined on page 363 of this topic show the white borders I should have, but I can't see them. I had them with 2.0.3 of course. The problem is for the movies info menu, I don't see what I'm clicking on and I must count the entries to click... This behaviour is the same on both machines (Vero and Windows), and each of them has been configured manually after installation of the skin. Any idea of what I missed ou forgot ? Please help. Thanks in advance.
Try again to delete only settings from user data.
It shouldn't create any issues if I do a fresh install of kodi and the skin then copy and paste a streaming addon from my current builds addon and userdata files into the new setup correct? It takes just as long to to set that addon up with all my Trakt lists as it does to scrape my library.
(2023-01-02, 12:54)sunlollyking Wrote: [ -> ]Hi team aware there's a ton of messages on here but i'm starting from the top here. Weirdly i get a can't connect to the repository error on Kodi. I've manually installed the repo by sshing the Zip over to storage, it installs fine however i then can't seem to enter it at all? Running V20 RC1 has anyone else seen the same ?
This is a skin for kodi matrix. Not ready for kodi nexus yet.
(2023-01-02, 15:03)cscott1 Wrote: [ -> ]It shouldn't create any issues if I do a fresh install of kodi and the skin then copy and paste a streaming addon from my current builds addon and userdata files into the new setup correct? It takes just as long to to set that addon up with all my Trakt lists as it does to scrape my library.
I really don't know. You won't know until you try.
(2023-01-02, 15:09)matke Wrote: [ -> ] (2023-01-02, 15:03)cscott1 Wrote: [ -> ]It shouldn't create any issues if I do a fresh install of kodi and the skin then copy and paste a streaming addon from my current builds addon and userdata files into the new setup correct? It takes just as long to to set that addon up with all my Trakt lists as it does to scrape my library.
I have done it before on previous skin updates I think as long as you dont mess with any of the skins addons everything copies fine. You had just mentioned radical change to to the skins code so I was unsure.
(2023-01-02, 12:06)roitheoden Wrote: [ -> ]One more thing: you should ask help for the translations. The French translation is very incorrect and I must rewrite a lots of things for myself. Don't know for other languages... Many strings have been modified or rewritten (sometimes only one uppercase letter in the string), so it's a bit tricky to correct, and I'll have to spend many and many days in order to make all that ok. It can't be a google translation, some words or sentences depend on the context and where they are used.
Translations are a problem. With this version, I tried to convert all the translations that were put directly into the code into a string. But it is a very difficult job. This skin is a fork of the titan bingie skin and it is a fork of the original titan skin. There are a lot of unnecessary strings. I will try to sort it out a bit, but it will be very difficult. When I get a little more organized, I will inform everyone that whoever wants to translate can do so with a specific file.
Thanks. You're right, it's a big bazar ! Perhaps if you need help for French, let's keep in touch.
Already done. Twice. I've removed all directories from userdata !
No white borders on movie info (the most important thing for me)
(2023-01-02, 15:02)matke Wrote: [ -> ] (2023-01-02, 12:01)roitheoden Wrote: [ -> ]Hi everybody and happy new year.
No white borders on movie info (the most important thing for me).
Sorry for the double post...
I turned on my Kodi this morning and it's automatically updated the theme, I have set the widgets up for the home screen as I want them but I can't save the label name to something else, it just doesn't seem to save when changed, just stays as the default. Also, the icons for the menu can't be changed either when adding new menu items and clicking the Set Icon link, nothing happens.
Is anyone else having this problem?
