(2021-04-23, 19:55)nazim12 Wrote: [ -> ] (2021-04-23, 19:40)matke Wrote: [ -> ] (2021-04-23, 18:41)nazim12 Wrote: [ -> ]@AchillesPunks One thing I noticed home screen widgets placed very low from middle and whole area from Clear logo to spotlight are bigger then widgets area , can we increase home widgets area a little bit vertically ? and you can see second row almost disappear ? remember its a default setting of current Matrix version.
If I may answer you. You have that much space because you don't have clearlogo and footer turned on. When it’s all on everything fits almost perfectly.
No, May be it is something related Skin Helper widget because i have enabled all settings but same issue .
https://postimg.cc/bGss4QjF
Can you share your screen shot ?
Sorry, you was right about the widgets. They were a little lower than they should be. I compared it to leia and now everything is fine. This version you're using is a pretty old. There are a lot of changes in the new version, so you will see if you have some problems with it. Just a little more patience.
We are done with the skin. I'll post the links on the first page in a little while. You can now just install through Kodi. All updates can be installed through Kodi as well.
Please tell me how to enable extra fanart? It is enabled but it does not rotate the background..
It's working great! Thank you AchillesPunks!
The Link is now live on the first page. The first link that says matrix is the skin only and the second link is the one to add into Kodi for a direct install.
(2021-04-24, 01:15)CollotsSpot Wrote: [ -> ]It's working great! Thank you AchillesPunks!
You can try the repo in kodi now.
Enjoy guys.
There will be an update soon for leia as well. In the meantime use matrix skin and send us your impressions, does everything work, what doesn't work...
(2021-04-24, 01:59)AchillesPunks Wrote: [ -> ] (2021-04-24, 01:15)CollotsSpot Wrote: [ -> ]It's working great! Thank you AchillesPunks!
Thank @matke. I did nothing.
Of course you did. You started this great project and have been working on it for a past year. Without you, there would be no this skin.
I have to mention a man without whom it would not be possible to make any skin for kodi matrix.
He has updated all addons necessary for matrix, skin helper service / widgets, matadatautils, skinbuckup... He also helped @
AchillesPunks and me to solve some problems and fix some bugs.
Angelinas, my brother, thank you for everything.
I must be doing things wrong, I install a repository source, I install skin, it asks me for script.module cherripy .... I install it, I configure the skin (by the way, I change everything but it is intuitive) I see that the hubs have disappeared and they are only widget I configure some and I go to the home screen and here the problem remains black. any solution?
Edit fixed:
I had to do a data wipe in kodi and now it works a thousand thanks
(2021-04-24, 01:16)AchillesPunks Wrote: [ -> ]The Link is now live on the first page. The first link that says matrix is the skin only and the second link is the one to add into Kodi for a direct install.
Hi mate ,
Thank you so much for this great skin.
I installed fresh kodi matrix on firetv 4k, I was successful to add repo and install the zip file.
I installed image collections, rector and marcelveldts beta repo but when I tried installing the titan bingie mod skin it failed with error "the dependency on script.module.simplejson on version 3.3.0 could not be satisfied " what am I missing? Please help thanks
(2021-04-24, 16:30)Kranemoore Wrote: [ -> ] (2021-04-24, 01:16)AchillesPunks Wrote: [ -> ]The Link is now live on the first page. The first link that says matrix is the skin only and the second link is the one to add into Kodi for a direct install.
Hi mate ,
install the missing dependency and reinstall the skin
