Thanks for your reply.
Actually I've switched all devices to 21 nightly, as it is running perfectly for all of my use-cases already.
I'm looking for an alternative to Confluence (which seems to reach EoL), your skin really looks promising to me.
Will wait for your adaption and install once ready and available for 21.
For the moment Confluence is still fine for me with the small change in the addon.xml
Cheers
Just installed on Kodi 21 beta 2 with flatpak on Linux Mint
"More Info" button on spotlight widget works right, with film added to the library (in setting set custom content spotlight with libray film)
You are telling me the third time now, that you installed it to your device.
How can this information help me?
Have you seen, that the skin is not showing up in the repo in my installation?
And the manual installation from zip is failing, due to other missing elements.
However, I will just wait for the updated version of the skin :-)
Wrote all steps yesterday
Just read it int my reply
This discussion is meaningless.
I will step out at this point.
Hello, I am currently running through an issue downloading the mod:
The dependency on script.module.jurialmunkey 0.1.14 could not be satisfied.
Here are my logs if you want (I use Kodi Nexus):
https://paste.kodi.tv/nuweqavago.kodi
Sorry if this was already answered somewhere, but I don't have the strength to go through all 400 pages.
Have a great day,
- ICaPiCo
You must have the strong to make a search with google
search for that repo, you'll find the beta version
I don't know why, but in the end I just had to change my setting of update add-ons from official ones to everything and it worked.
But still, thanks for the advice.
God bless you
- ICaPiCo
(2024-01-15, 17:10)paololuke77 Wrote: [ -> ]You must have the strong to make a search with google
There is no BETA version.... If you find a BETA version then it's not this skin. I know what's on my GitHub
(2024-01-15, 18:24)ICaPiCo Wrote: [ -> ]I don't know why, but in the end I just had to change my setting of update add-ons from official ones to everything and it worked.
God bless you
- ICaPiCo
Yeah the second post of the skin has this info..
https://forum.kodi.tv/showthread.php?tid...pid3125629
Good morning
first of all, thank you for this fabulous skin, I love it!
I have a question, because I am still a beginner:
Is it possible to have an entire fan art in the background like in the spotlight view, when you select a film?
Thanks a lot
I mean about that journalmonkey mentioned by user
I know there's only one Titan Bingie Mod
p.s.: in the last my reply i written to able updates fron any repository to make easy install the skin, it's a "common trouble" (in my opinion, and sorry for my english)
(2024-01-16, 13:41)syndrome Wrote: [ -> ]Good morning
Thanks a lot
That would only be possible of you edit the xml.
Hi ,
Thank you for your very quick reply !
I don’t think I know how to do that !? (even if the script already exists in the xml, because it is the case for the background on the spotlight page / more info ) but I don’t know if it’s simple and I don't want it to cause errors in the skin
You think it's possible that this is in an update ?
A new parameter for view types ?
Thanks for your job
(2024-01-17, 08:50)syndrome Wrote: [ -> ]Hi ,
Thanks for your job
Don't see this happening.
