(2023-01-02, 18:41)loki00 Wrote: [ -> ] (2023-01-02, 18:32)coults79 Wrote: [ -> ]Whats the best way to reinstall the skin on a Shield? I have downloaded the all you need zip from the first page of this thread, put it on a flash stick and added it to a folder on my Shield but every time I go into Add-ons > Install from Repository > Titan BINGIE MOD Repository 1.0.0 > Look & Feel > Skin and click on Titan BINGIE MOD 2.1.0, Kodi closes and I have to start it again.
Have I got the right file?
Im using a Shield. Make sure youre on Kodi 19.5. It wont install otherwise. Itll just crash back to the Nvidia Homescreen. i Had the same issue.
The latest 19.5 update isnt available yet via Google Play so youll have to download whatever version is available on the store and then from within Kodi download Android Installer from the Kodi Repo and install 19.5 that way. Thats what I did.
Also before you install the skin, make sure you go to Settings/Syestem/Add-ons and enable Unkown Sources & - Update official add-ons from - Any repositories
Thanks for the tip, I haven't seen that before! I installed Kodi from the Google Store, then updated to the latest version using Android Installer, enabled unknown sources and Any Repository and tried to install from the same downloaded zip file from the first page of this thread, it got further than it has but failed on loading some dependancies.
What know?
childofkorn
It should not take that long with TV Shows either.. I so many TV shows with each show with 20 to 30 + seasons.. Maybe 3,000 TV shows with Thousands of episodes... should only take about 15 to 20 mins... I just finished doing this yesterday... on 2 systems...
loki00
You are not understanding what I'm say... You can play movies just fine that are not scanned into the library.. Just hold ENTER on the video not scanned into the library and hit info then play...
Thanos
Color themes are a thing of the past.. You don't really use them anymore.
coults79
Install those dependency manually
(2023-01-02, 20:01)coults79 Wrote: [ -> ] (2023-01-02, 18:41)loki00 Wrote: [ -> ] (2023-01-02, 18:32)coults79 Wrote: [ -> ]Whats the best way to reinstall the skin on a Shield? I have downloaded the all you need zip from the first page of this thread, put it on a flash stick and added it to a folder on my Shield but every time I go into Add-ons > Install from Repository > Titan BINGIE MOD Repository 1.0.0 > Look & Feel > Skin and click on Titan BINGIE MOD 2.1.0, Kodi closes and I have to start it again.
What know?
Thats strange. I had problems installing the skin at first but then updated to 19.5 and i was able to install the Repo from the zip file (from the first page). After the update i was able to install the Repo but couldnt install the skin (failed to install dependency error). Enabled the 'Any Repository' option and the skin installed. That was my process. I had to try a few installs of Kodi to get it working. I did power off the Shield/pulled out the power lead for a few seconds in between installs. Thats what i did to get it working. I dont know what else to suggest, im no expert. Just my experience of getting this skin to work on my Shield.
(2023-01-02, 20:07)AchillesPunks Wrote: [ -> ]@childofkorn
Yeah, I think i know what my problem is. Its not my system cause on paper and from looking at the stats it never uses more than 50% cpu usage and always has about 5-6 gig ram left over.
I belive its the hard-drive, nothing much i can do about it 2bh right now. Just have to deal with it and wait 😑
Any ideas why i get an 'error quotaExceeded 403 the request cannot be completed' when using Tubed? I seem to get it when i play trailers via the highlight widget. It doesnt stop the trailer from playing its just an annoying notification. Ive signed into google and increased cache and search sizes within the Tubed app but still getting the error. Is it an API thing? Tried googling but couldnt find anything helpful. Its no big deal just thought id ask.
(2023-01-02, 21:24)loki00 Wrote: [ -> ]Any ideas why i get an 'error quotaExceeded 403 the request cannot be completed' when using Tubed? I seem to get it when i play trailers via the highlight widget. It doesnt stop the trailer from playing its just an annoying notification. Ive signed into google and increased cache and search sizes within the Tubed app but still getting the error. Is it an API thing? Tried googling but couldnt find anything helpful. Its no big deal just thought id ask.
According to your log that you posted, I would say that you have a problem with inputstream adaptive. I see that you tried to load some stream lists, if I'm not mistaken, you get the same error there as well. I tried the skin on xiaomi stick 4k. Everything works as it should, it opens streams, the video addon I use works without problems.
childofkorn
It must be a USB 2.0 if it's the HDD. I make sure to purchase 3.0, 3.1, 3.2
loki00
Yes usually you get the quota error from YouTube. Creating the YouTube api solved my problem a couple of years ago.
(2023-01-02, 21:48)matke Wrote: [ -> ] (2023-01-02, 21:24)loki00 Wrote: [ -> ]Any ideas why i get an 'error quotaExceeded 403 the request cannot be completed' when using Tubed? I seem to get it when i play trailers via the highlight widget. It doesnt stop the trailer from playing its just an annoying notification. Ive signed into google and increased cache and search sizes within the Tubed app but still getting the error. Is it an API thing? Tried googling but couldnt find anything helpful. Its no big deal just thought id ask.
I did another clean install and it solved my problem. Everything seems to be working fine now. Just enjoying the skin and getting all my artwork looking good now. I really appreciate the help. Thankyou!
(2023-01-02, 22:10)loki00 Wrote: [ -> ] (2023-01-02, 21:48)matke Wrote: [ -> ] (2023-01-02, 21:24)loki00 Wrote: [ -> ]Any ideas why i get an 'error quotaExceeded 403 the request cannot be completed' when using Tubed? I seem to get it when i play trailers via the highlight widget. It doesnt stop the trailer from playing its just an annoying notification. Ive signed into google and increased cache and search sizes within the Tubed app but still getting the error. Is it an API thing? Tried googling but couldnt find anything helpful. Its no big deal just thought id ask.
Ohhh that's great news. I'm glad you solved the problem. Enjoy in skin.
Thanks, it took a few tries, but the dependancies installed in the end 👍
(2023-01-02, 22:22)matke Wrote: [ -> ] (2023-01-02, 22:10)loki00 Wrote: [ -> ] (2023-01-02, 21:48)matke Wrote: [ -> ]According to your log that you posted, I would say that you have a problem with inputstream adaptive. I see that you tried to load some stream lists, if I'm not mistaken, you get the same error there as well. I tried the skin on xiaomi stick 4k. Everything works as it should, it opens streams, the video addon I use works without problems.
Unfortunately, i just restarted Kodi and the problem has started again
. Unable to play unscanned content. Something in the skin or one of its dependencies is causing the issue. I can open files with other skins just not this one.
It seems to work again when i uninstall and reinstall the skin.
...but now the skin looks a mess - white borders dont line up with widgets, widgets not evenly spaced out etc
Isnt inputstream adaptive used for streaming content? I have the issue when I try to open files from an external (local) HD.
