Yes I did set it up correctly. I used the original Titan skin in the past and I am quite familiar with the skin. Clicking right also takes me to the widgets and the sub-menus then overlays the widgets. This is a bit counter-intuitive to me but if you say it is okay like that, then who am I to complain?
Thanks for your response
I also posted this a while back but didn't get a response. Its definitely warnings within this skin as it doesn't occur with other skins. Do you know if you're going to fix them and when there could be a new release ?
(2023-07-05, 11:48)sunlollyking Wrote: [ -> ]I also posted this a while back but didn't get a response. Its definitely warnings within this skin as it doesn't occur with other skins. Do you know if you're going to fix them and when there could be a new release ?
I don't play games with the skin. It's used for movies and tv shows. I will not fix it. Someone that plays games can.
I also never played games on Kodi. You have to give a little more detail. Which game, emulator, whatever you use. I downloaded an emulator from net that has a bunch of games and works normally. Certainly this skin will always have a focus on movies and tv shows.
Cool and yeah thats why i was saying it was strange it wasn't working any longer because i'm sure i've ran some games through this skin before.
I'm just running the Alpha 2 LE12 build and i tried a couple emulators (bsnes + PSCX Rearmed) both pointed the same error in the logs that the gamesOSD.xml is missing and the exact same run through in the default skin played all the games fine with those same emulators.
My post above about the warnings was in reference to these libraries that are deprecated that spit out all over logs currently. It didn't get answered but i just wanted to highlight it for you on the next release if you didn't know already.
2023-04-24 11:28:05.873 T:2133 warning <general>: "resumetime" in ListItem.setProperty() is deprecated and might be removed in future Kodi versions. Please use InfoTagVideo.setResumePoint().
2023-04-24 11:28:05.873 T:2133 warning <general>: "totaltime" in ListItem.setProperty() is deprecated and might be removed in future Kodi versions. Please use InfoTagVideo.setResumePoint().
2023-04-24 11:28:05.873 T:2133 warning <general>: ListItem.addStreamInfo() is deprecated and might be removed in future Kodi versions. Please use InfoTagVideo.addVideoStream(), InfoTagVideo.addAudioStream() and InfoTagVideo.addSubtitleStream().
2023-04-24 11:28:05.873 T:2133 info <general>: Skipped 2 duplicate messages..
2023-04-24 11:28:05.873 T:2133 warning <general>: Setting most video properties through ListItem.setInfo() is deprecated and might be removed in future Kodi versions. Please use the respective setter in InfoTagVideo.
(2023-07-06, 14:36)sunlollyking Wrote: [ -> ]Cool and yeah thats why i was saying it was strange it wasn't working any longer because i'm sure i've ran some games through this skin before.
Wait, you're using kodi 21 alpha 2? If that's the case, I can't help you because the skin has not yet been tested for Omega, and it won't be until it enters the stable version.
No problems - Thanks for the update.
Outside of the very occasional crash and these warnings the skin is fairly stable on Kodi 21. Hopefully not much work for you when it happens!
Still enjoying this skin a lot. I only have one small request. Can you please add an option to completely disable the splash screen? Right now I am manually editing the Custom_1103_StartUpMask.xml file to remove it, but I think many people would appreciate a simpler way to do it.
Keep up the good work
(2023-07-10, 17:13)AchillesPunks Wrote: [ -> ] (2023-07-10, 15:58)SoulReaver Wrote: [ -> ] (2023-07-10, 15:27)AchillesPunks Wrote: [ -> ]You can already do that with the skin. There's an option to disable splash screen. You shouldn't have to edit any xml files.
I changed mine to this. You can change to whatever you want. Roaming/Kodi/addons/skin.titan.bingie.mod/extras/media and change the splash image to whatever you like if you don't want the default Netflix image.
Thank you for your quick response.
I am aware of this option you refer to which lets you use an image for the splash screen, but I do not wish to have any kind of splash screen at all which is why I edit the .xml file at the moment.
Then just put a black image for it it's there to let the skin load the widgets
Okay, I guess I just prefer no image and actually see it loading the widgets instantly instead of just staring at a black image for a while, but I’ll try and see if there is any speed difference between using an image or not.
It would still be more simple and user friendly with an off switch instead of the user having to find a black image somewhere to use for this.
Thanks again for your work on this cool skin
Hi, All and AchillesPunks . Great skin! have been using it for some time. Just got a new laptop running windows 11, will this skin run in Kodi 20.1?
(2023-07-10, 18:33)Roadrunners Wrote: [ -> ]Hi, All and AchillesPunks . Great skin! have been using it for some time. Just got a new laptop running windows 11, will this skin run in Kodi 20.1?
Yes and it works great also on Kodi 20.2
Thanks. Any advice on procedures for installing this skin, i.e. does and don’ts
