Hello I am new here,
New to kodi as well
After installing as per 1st post
Nothing loads here
I am not sure how to configure further
Is there any detailed tutorial for beginners? Video perhaps helps.
Thank you in advance
If someone can DM, it would be great
(2023-03-11, 07:26)a13b10 Wrote: [ -> ]Hello I am new here,
New to kodi as well
Nothing loads here
Have you scanned your media to Kodi yet?
You Kodi profile needs to be setup to receive private messages.
(2023-03-10, 21:42)SoulReaver Wrote: [ -> ] (2023-03-10, 20:44)PrimeDigital Wrote: [ -> ]Hello, I'm using Kodi Matrix 19.5 and when I try to install Titan Bungie MOD I get this message The dependency on script.skinshortcuts version 2.1.0 could not be satisfied. Please help if you can.
Try this.
SoulReaver
You need to delete some of your messages you're inbox is full
I just wanted to say I loved that game Legacy of Kain: Soul Reaver. I really hope they remake it on the PS5
Hey, this is my first time replying to this forum so I want to start of by thanking you for this amazing skin!
Lately I seem to have a problem with the "Play from beginning" button in the info menu. When I press it, it instantly gives the error pop-up "Playback failed". The "Resume" button plays the media but doesn't actually resume from where i left off.
I use Kodi Matrix v19.5 and use the widgets from 'Skin Helper Widgets'. For the media sources I use the Library Integration feature form 'TMDB Helper' and then add them to the media library in 'Kodi media settings' using information provider 'The Movie Database Python" for Movies and 'TMDb TV Shows' for TV shows.
I checked the Log file but it doesn't mention much.
Does anyone know how to fix this?
New to kodi as well
Nothing loads here
Thanks for your reply, skin helper giving me some error. I am going to load it all again, can you please advise me on which version it works best? 19 or 19.5 or any other?
I will install that version and try again
(2023-03-11, 19:37)a13b10 Wrote: [ -> ] (2023-03-11, 07:26)a13b10 Wrote: [ -> ]Hello I am new here,
New to kodi as well
Nothing loads here
Have you scanned your media into Kodi yet?
Yes i did and movies showed up but for continue watching i could not find default widget in skin helper addons
There is no media that has starting and not completed. So there will be nothing in continue watching. Until you play media and don't finish it it will remain empty.
New to kodi as well
Nothing loads here
It works fine on 19 or 20. It looks like skin is set to default, meaning the spotlight and widgets are trying to pull information from your kodi libary and that it has nothing in the libary, hence nothing loads.
(That is why he's asking if you have added the media to your libary yet)
If you are not using library content then you need to go into skin settings and point the spotlight and widgets to a location (like addon) so it can load stuff.
B.t.w, this skin works best and is made more for local content. But can be used with addons.
(2023-03-11, 19:45)a13b10 Wrote: [ -> ]Yes i did and movies showed up but for continue watching i could not find default widget in skin helper addons
1. There is no media that has starting and not completed. So there will be nothing in continue watching. Until you play media and don't finish it it will remain empty.
2. I don't understand what you mean by you can't find the default widget in skin helper.
(2023-03-11, 19:37)Jurassicspark Wrote: [ -> ]Hey, this is my first time replying to this forum so I want to start of by thanking you for this amazing skin!
Sounds like a resume point conflict between the skin,tmdb helper and whatever addon is been used to play it.
Are you sure you have it set to save and load the resume points from the same location?
Also a log would help to pin point it faster.
I'm not too sure from where it gets the resume points... I think this is built inside the skin or from skin helper widgets. I do sync my resume points to Trakt but in trakt i have "Sync movie/episode playback progress to Kodi" disabled.
But i don't think it's a problem of the resume points because it should just play the media from the start instead of giving me an instant error.
(2023-03-11, 20:14)Jurassicspark Wrote: [ -> ]I'm not too sure from where it gets the resume points... I think this is built inside the skin or from skin helper widgets. I do sync my resume points to Trakt but in trakt i have "Sync movie/episode playback progress to Kodi" disabled.
I also use .strm files imported into kodi libary like yourself and get no problems with resuming media or using play from beginning if the media has a resume point. It definitely seems like something isn't set up right as its getting a conflict when you use either.
(2023-03-11, 20:21)childofkorn Wrote: [ -> ] (2023-03-11, 20:14)Jurassicspark Wrote: [ -> ]I'm not too sure from where it gets the resume points... I think this is built inside the skin or from skin helper widgets. I do sync my resume points to Trakt but in trakt i have "Sync movie/episode playback progress to Kodi" disabled.
Mhhh.. I'm starting to feel like it's because I'm using Kodi in portable mode from inside my OneDrive folder... And this is somehow giving Python errors.
Do you have any experience with loading portable Kodi from a Drive folder? (Btw I do have all the files mirrored on my computer, they just sync to the cloud.)
