(2024-02-06, 10:01)syndrome Wrote: [ -> ] (2024-02-05, 23:57)fr24 Wrote: [ -> ] (2024-02-05, 20:51)AchillesPunks Wrote: [ -> ]I don't speak Spanish so I wouldn't know how to translate. Someone who does would need to translate
I have already created it. all ready. thank you
Good morning
great that !
it would be good to explain the procedure and point to the files in question
it could be useful for the community
THANKS & HAVE FUN
Editing the language file. The only way I have found is to edit it with notepad, since the file is so large I have only translated the most important menus for me. editing the entire file with notepad would take hours. I know there are better ways because all skins include many languages. except BENGIE who only brings English. It would be good to know how to use a quick translator for these cases.
all the best
Help!!
Just installed this skin. Don't know what I've done, but the 'settings' button has disappeared from the left toolbar! Is there another way of getting to settings?
(2024-02-06, 15:45)Chalklands Wrote: [ -> ]Help!!
I m note alone !
This « disable shortcut » function for the settings parameter shouldn’t exist :-)
(2024-02-06, 13:28)fr24 Wrote: [ -> ] (2024-02-06, 10:01)syndrome Wrote: [ -> ] (2024-02-05, 23:57)fr24 Wrote: [ -> ]I have already created it. all ready. thank you
Good morning
great that !
THANKS & HAVE FUN
all the best
Perfect . Thks for your reply
Good morning
great that !
THANKS & HAVE FUN
all the best
Are you using Notepad or Notepad++. If not using Notepad++ you should and it makes it easier.
(2024-02-06, 18:05)fr24 Wrote: [ -> ] (2024-02-06, 16:49)AchillesPunks Wrote: [ -> ] (2024-02-06, 13:28)fr24 Wrote: [ -> ]Editing the language file. The only way I have found is to edit it with notepad, since the file is so large I have only translated the most important menus for me. editing the entire file with notepad would take hours. I know there are better ways because all skins include many languages. except BENGIE who only brings English. It would be good to know how to use a quick translator for these cases.
all the best
NOTEPAD++
Another one I like using is Github Desktop
(2024-02-06, 19:29)fr24 Wrote: [ -> ] (2024-02-06, 19:09)AchillesPunks Wrote: [ -> ] (2024-02-06, 18:05)fr24 Wrote: [ -> ]NOTEPAD++
I don't know how to do it any other way, it can be done here but I don't understand it...https://kodi.weblate.cloud/about/ Thinking about it, I came up with this way of editing and it has worked, since I don't know English, I have to translate and then copy and paste, it is a long time to edit the strings.po file I have asked for help in several places but I have not had success.
What is this for? I know how it works I just can't translate.
(2024-02-06, 19:35)AchillesPunks Wrote: [ -> ] (2024-02-06, 19:29)fr24 Wrote: [ -> ] (2024-02-06, 19:09)AchillesPunks Wrote: [ -> ]Another one I like using is Github Desktop
to translate all the skin
(2024-02-06, 16:02)AchillesPunks Wrote: [ -> ] (2024-02-06, 15:45)Chalklands Wrote: [ -> ]Help!!
This is a very simple fix... Just go to your media as in where you have all your movies. Hit left like you are going to change view and scroll to the bottom you will see skin settings... Then go over and enable the setting Icon..
Thanks. Managed to get to settings as you suggested. However, if I go into 'customize power menu' and go back to the skin, the settings button (or any other buttons) don't display in the side bar. I think when I initially installed the skin there was an option to import settings from other skins (can't be precise because I can't find the option anymore) and I imported from Arctic fuse. So maybe that is my problem? The side bar (where settings used to be) is showing: Favourites, File manager, Add-ons, Add-on Browser and Quit.
I've tried uninstalling and re-installing to no avail. Any ideas? Sorry to be a pain. Great skin though apart from that!
How to make to make it work with screen touch
