(2023-02-13, 08:02)matke Wrote: [ -> ] (2023-02-13, 04:06)shaktoo Wrote: [ -> ]@matke : Great news. Clean install & reconfiguring skin on chromecast with the latest nightly has fixed all crashes.
@AchillesPunks & @matke : TBM pulls ratings via SHS /Metadata utilities OR Tmdb Helper ?
In AH2 skin I am using Amazon VOD addon directly to populate widgets and it displays all the artwork , TBM is unable to !
Is there any way we can have option to utilise either both or select either of the options so thats achievable
The only other addon which I am unable to get artwork from is iPlayer www.
Both.
Generally artwork should be part of addons not skins. I think you should ask the authors of these two addons to implement better support for artworks.
Also, I can't test any of these addons since I don't use them. What is missing from the artwork? I assume a clear logo.
Yes clear logo and no fan art
(2023-02-13, 13:31)shaktoo Wrote: [ -> ] (2023-02-13, 08:02)matke Wrote: [ -> ] (2023-02-13, 04:06)shaktoo Wrote: [ -> ]@matke : Great news. Clean install & reconfiguring skin on chromecast with the latest nightly has fixed all crashes.
Both.
Ohhh. That's a really bad situation with that addons. I really think the authors needs to improve that addons. In principle, maybe something could be done, but it is absolutely not a solution to skin do the monitor artwork. Simply, it will happen that when something is not in focus, it does not show the artwork, when switching between movies there would be a certain delay and slowdown....
(2023-02-10, 21:21)matke Wrote: [ -> ]For better integration with the local library, it is necessary to turn on option in the tmdb helper:
"Get additional details from the local kodi library database".
It's not possible to show a collection in the video info dialog that has been created manually, right? I have an issue that one collection isn't listed on tmdb, unfortunately. People have been complaining about this for a while now as it clearly is a series, but it keeps getting removed from mods over there. The theme is trying to load the collection and shows it's name for a second in the video info section but then disappears. Thanks again
Clear Logos and fanart in AH2 for amazon VOD :
Same Widget in TBM With No Logos:
So As you see its not the addon But rather Skin
Following is an addon issue as its lacking artwork in ANY Skin
(2023-02-13, 22:31)shaktoo Wrote: [ -> ]Clear Logos and fanart in AH2 for amazon VOD :
ok, you obviously don't understand what I'm talking about. in ah2 you have clearlogo because monitoring is done with tmdb helper, that's not a problem, I can add that too. the problem is that tbm works a little differently than ah2. for example, switching to the video info dialog will cause a problem. for a second you will see the title or wrong clearlogo and then corect clearlogo. also if you opened the menu on home, the clearlogo would disappear. if you pay attention, switching between titles in ah2 there is a little delay because the movie title is hidden until the clearlogo appears, sometimes it even appears title for a second. amazon vod must have artwork support integrated into it like other video addons. the skin should only display them, not monitor. it's a completely wrong approach. ask the author for an amazon vod to integrate better artwork support. just look at the posters, horrible. these are not posters it's landscape pictures, which means that the posters are also missing. metadata too, very poor. once again, you are looking for help at the wrong address, amazon vod github is your place.
Hi, why don't I have the same thing in "categories" and tmdb/movies/genres ?
shkop
And who says that they should be the same lists? Those are completely two different things.
I don't know, in "categories" I see the logo "TMDB" I thought it was the same thing, in any case there are a lot of films missing.
(2023-02-14, 11:34)shkop Wrote: [ -> ]I don't know, in "categories" I see the logo "TMDB" I thought it was the same thing, in any case there are a lot of films missing.
It's missing because you turned on option "enable streaming services filter".
I Really like the skin so far, I'm wondering is there a way to activate the 'Snow Animation' and 'Halloween Animation' from the keyboard or from a script?
I use playlist to hide Christmas and Halloween movies outside of their seasons, and during each season I swap out playlist so my top widgets show seasonal movies, It would be nice if I could use my setup to turn on the Snow and Halloween Animation as well.
AchillesPunks
Is there any way to make my widgets reload less often? They clear themselves and load everything again frequently. For example when I switch from TV shows to Movies and back to TV shows in home menu. I'm running on Vero 4K+. Could this be something to do with the limited memory on this device?
Also, is it possible to remove the 8 widgets limit? I would like to have 14 of the on home page and that's all.
(2023-02-16, 23:16)gaze Wrote: [ -> ]@AchillesPunks
gaze
1. You can set the home spotlight to whatever you want and it doesn't reset. I have mine set to Resent media.
2. You shouldn't add more it will slow your system down. If you must just add them under the Home..
Add the widget to surprise me. You can see they added to the home
