(2020-09-20, 19:21)HugoL Wrote: [ -> ] (2020-09-20, 18:59)jonsnow30 Wrote: [ -> ] (2020-09-20, 16:48)HugoL Wrote: [ -> ]I like that a lot. Good job!
What's up with your plot/button configuration? You switched it around? The original Bingie had it like this and I was never that keen on it to be honest.
The current version:
i played alot in the code to make it fit Hebrew, about the plot/button configuration i think i may changed abit the position can't remember honestly...
Cool man. Just keep in mind, I altered the diffuse on the spotlight content screen to be particularly darker around the normal plot area (seen in my picture) so that the plot text is always very visible no matter the background image. This was even more necessary since I removed the text shadow.
Your plot seems to be slightly out of this area but I can see you have text shadow so maybe it doesn’t even matter.
indeed you right, i found my plot code, it goes like this:
from IncludesHomeBingie.xml
<!-- Plot -->
<control type="textbox">
<visible>Skin.HasSetting(ShowPlotInBingieSpotlight) | !$EXP[IsPlayingUnrecognizedContent]</visible>
<animation effect="fade" time="500">VisibleChange</animation>
<include>Default_Visible_Fade</include>
<height min="50" max="138">auto</height>
<width max="620">auto</width>
<align>justify</align>
<font>Reg28</font>
<textcolor>$VAR[BingiePlotTextColor]</textcolor>
<shadowcolor>black</shadowcolor>
<label>$VAR[BingieSpotlightPlot]</label>
</control>
and for the spotlight buttons:
from IncludesBingie.xml
<!-- spotlight buttons -->
<include name="Spotlight_Buttons">
<param name="spotlightid" default="1508"/>
<param name="top" default="0" />
<definition>
<control type="grouplist">
<visible>Control.IsVisible($PARAM[spotlightid]) + Integer.IsGreater(Container($PARAM[spotlightid]).NumItems,0)</visible>
<visible>Control.HasFocus($PARAM[spotlightid]) | String.IsEqual(Container(77777).Position,0)</visible>
<orientation>horizontal</orientation>
<top>$PARAM[top]</top>
<width>800</width>
<height>70</height>
<itemgap>15</itemgap>
<control type="radiobutton">
<description>Play</description>
<height>100%</height>
<width>230</width>
<textoffsetx>75</textoffsetx>
<textwidth>155</textwidth>
<align>left</align>
<textcolor>$VAR[SpotlightPlayTextButtonColor]</textcolor>
<texturenofocus colordiffuse="$VAR[SpotlightPlayButtonColor]" border="5">diffuse/panel.png</texturenofocus>
<textureradiooff colordiffuse="$VAR[SpotlightPlayTextButtonColor]">dialogs/videoinfo/info/play.png</textureradiooff>
<radioposx>35</radioposx>
<radiowidth>25</radiowidth>
<radioheight>35</radioheight>
<font>Reg28</font>
<label>[CAPITALIZE]
$LOCALIZE[208][/CAPITALIZE]</label>
</control>
<control type="button">
<width>auto</width>
<align>center</align>
<textcolor>$VAR[SpotlightInfoTextButtonColor]</textcolor>
<texturenofocus colordiffuse="$VAR[SpotlightInfoButtonColor]" border="5">diffuse/panel.png</texturenofocus>
<font>Reg28</font>
<label>
$LOCALIZE[31838]</label>
</control>
</control>
</definition>
</include>
you probably need also the spotlight clearlogo postion to be changed, i can find it as well if necessary..
