(2021-08-09, 18:11)LeeH1988 Wrote: [ -> ] (2021-08-09, 17:00)matke Wrote: [ -> ] (2021-08-09, 15:34)LeeH1988 Wrote: [ -> ]
These are what I was referring to. The ratings sit behind the widgets tiles and my context menu is just blank. Thanks again
You can't combine layouts just like that.
You can combine poster and poster details, landscape and landscape details. And I think you can put any layouts like last widget. The problem is that all layouts are different sizes. So they move up and then the ratings go behind the widget.
It's very strange for menu. I don't have this problem. I don't know why everything is empty. No one has complained about this so far. Try reinstalling the skin.
Thanks for your quick response, regarding the context menu I have tried uninstalling then reinstalling the skin a few times but seem to have the same issue. Regarding the widgets, on the previous version of the mod I had installed I had multiple different widget types on my home screen without the issues with seeing the ratings. I am not sure what has changed as the dimensions of the widgets and the back panel seem to have slightly changed between the two versions. I still have the old zip so I might try and see if I can figure out what's changed. Thanks again.
I will explain again what happened with the widgets. In the old skin we had ratings set much higher. This caused the ratings to be at the some height when the spotlight was on, when it was off, when the fixed focus was set... In fact, the margins were really bad. Now we have perfectly done widgets with a fixed focus that are used by almost everyone. In the next update, we will probably leave only the fixed focus since the other is totally buggy and illogical (scrolling goes upside down).
(2021-08-09, 18:40)matke Wrote: [ -> ] (2021-08-09, 18:11)LeeH1988 Wrote: [ -> ] (2021-08-09, 17:00)matke Wrote: [ -> ]You can't combine layouts just like that.
I read in the Change Log the activities re:layout and views, was curious what they were - I would be in your debt if you included a TV by Season view as an alternative to episode
(2021-08-09, 20:07)fsurfer Wrote: [ -> ] (2021-08-09, 18:40)matke Wrote: [ -> ] (2021-08-09, 18:11)LeeH1988 Wrote: [ -> ]Thanks for your quick response, regarding the context menu I have tried uninstalling then reinstalling the skin a few times but seem to have the same issue. Regarding the widgets, on the previous version of the mod I had installed I had multiple different widget types on my home screen without the issues with seeing the ratings. I am not sure what has changed as the dimensions of the widgets and the back panel seem to have slightly changed between the two versions. I still have the old zip so I might try and see if I can figure out what's changed. Thanks again.
Sorry but I don't understand very well what you want?
(2021-08-09, 23:45)matke Wrote: [ -> ] (2021-08-09, 20:07)fsurfer Wrote: [ -> ] (2021-08-09, 18:40)matke Wrote: [ -> ]I will explain again what happened with the widgets. In the old skin we had ratings set much higher. This caused the ratings to be at the some height when the spotlight was on, when it was off, when the fixed focus was set... In fact, the margins were really bad. Now we have perfectly done widgets with a fixed focus that are used by almost everyone. In the next update, we will probably leave only the fixed focus since the other is totally buggy and illogical (scrolling goes upside down).
If you look here
https://forum.kodi.tv/showthread.php?tid...pid3044375 we had this discussion before
I had to reinstall the skin to see if it solved a problem and now I see that when I enter the argument and critics I do not get the number of votes from imdb, why can it be? by the way, is there any way to get the movies already seen in the new releases widget? I have disabled tabs in settings skin helper service widget but I can't get them to come out
Edit: The other time I installed it, I did it from the manual link, I got different popcorn icons and also the number of votes, now they don't come out, I guess it's better to stick with the repository version, right? for updates
(2021-08-10, 18:02)FranSaorin Wrote: [ -> ]I had to reinstall the skin to see if it solved a problem and now I see that when I enter the argument and critics I do not get the number of votes from imdb, why can it be? by the way, is there any way to get the movies already seen in the new releases widget? I have disabled tabs in settings skin helper service widget but I can't get them to come out
Always refer to page one of thread else you'll be out of sequence
When I last tried I installed Bingie from the Repository (Look and Feel) first, before installing this mod
Check with @
matke
I also found it was pointless reinstalling you must do a clean install
I am currently setting everything up in Leia 18.9 Estuary -
take a backup of Kodi folder, then I will add the Repository >> Install Bingie Skin check everything >> Install Titan Bingie Mod
OK, thanks for explaining this to me, sorry if you've mentioned this before, admittedly I didn't throughly check the forum. Regarding the context menu I have managed to work out this issue which was related to the key map editor program which I had configured incorrectly so I was bringing up the global context menu rather than the item one. Thanks for the good work on the skin.
Add to My List does not work for TV Shows...bug? Fresh kodi 19.1 install and fresh bingie install with all dependencies...
(2021-08-16, 10:25)TheLastOfUs Wrote: [ -> ]Add to My List does not work for TV Shows...bug? Fresh kodi 19.1 install and fresh bingie install with all dependencies...
Unfortunately it does not work in the matrix. The problem is with the skin helper service/widgets. @
Angelinas needs to fix this.
(2021-08-16, 16:10)matke Wrote: [ -> ] (2021-08-16, 10:25)TheLastOfUs Wrote: [ -> ]Add to My List does not work for TV Shows...bug? Fresh kodi 19.1 install and fresh bingie install with all dependencies...
Unfortunately it does not work in the matrix. The problem is with the skin helper service/widgets. @Angelinas needs to fix this.
Hey man really appreciate you replying. I thought I was going crazy for a bit...lol.
Also are you experiencing any sort of lag on your end? I only have 21 widgets and it's laggy a bit...
Ok, I am losing my marbles, I thought I knew this, but no longer. How do I change the red color on the home screen that underlines the home icon on the left vertical menu? This skin is nearly perfect, but the color red is not my thing.
It seems to me I used to edit the colors xml file. Now has no effect?!
Thanks in advance anyone who can help...
(2021-08-16, 23:55)thejaffe Wrote: [ -> ]Ok, I am losing my marbles, I thought I knew this, but no longer. How do I change the red color on the home screen that underlines the home icon on the left vertical menu? This skin is nearly perfect, but the color red is not my thing.
There is no way to change the color. We are keeping the colors to match Netflix.
(2021-08-16, 22:50)TheLastOfUs Wrote: [ -> ] (2021-08-16, 16:10)matke Wrote: [ -> ] (2021-08-16, 10:25)TheLastOfUs Wrote: [ -> ]Add to My List does not work for TV Shows...bug? Fresh kodi 19.1 install and fresh bingie install with all dependencies...
The lag really depends on your system it runs on. This is a very heavy skin. You can try to disable views you do not use.
(2021-08-17, 00:40)AchillesPunks Wrote: [ -> ] (2021-08-16, 23:55)thejaffe Wrote: [ -> ]Ok, I am losing my marbles, I thought I knew this, but no longer. How do I change the red color on the home screen that underlines the home icon on the left vertical menu? This skin is nearly perfect, but the color red is not my thing.
As in it's now taken away? I have indeed changed it in the past.
