(2015-06-27, 20:16)mikesilvo164 Wrote: [ -> ]There are instructions for all operating systems in the first post of that thread. After you select your PHP path add the prefix Rated with a space after Rated for movies under the MPAA settings also activate the first option and select yes for the last option.
Yeah, I actually just figured it out, I had thought that this would enable the extended MPAA image but i see that it just adds a description on the bottom of the screen. Is there anyway to actually enable the extended MPAA image?
(2015-06-27, 20:29)Xero Wrote: [ -> ]Yeah, I actually just figured it out, I had thought that this would enable the extended MPAA image but i see that it just adds a description on the bottom of the screen. Is there anyway to actually enable the extended MPAA image?
What image is that? I am not sure what you mean.
(2015-06-27, 20:33)mikesilvo164 Wrote: [ -> ]What image is that? I am not sure what you mean.
The one from ShadowTek's mod
http://forum.kodi.tv/showthread.php?tid=...pid1781904 the extended rating image at the top of the video info. I think Shednox actually has this feature as well, but I'm not entirely sure.
(2015-06-27, 13:54)Mario S. Wrote: [ -> ]Sorry Mike same as before !!!
I actually had no idea how to fix this since on my machine it does not happen. I asked phil65 for some help and he explained that this function is tied to CPU power so depending on the hardware it may take extra time to render. He suggested adding some things and altering the animations. Can you try replacing
this file to see if it helps? I can adjust things further but let me know if it lessens the problem or solves it completely.
Thanks Mario
(2015-06-27, 20:42)Xero Wrote: [ -> ]The one from ShadowTek's mod http://forum.kodi.tv/showthread.php?tid=...pid1781904 the extended rating image at the top of the video info. I think Shednox actually has this feature as well, but I'm not entirely sure.
Ok, I see what you mean now. I have added it to my list.
(2015-06-27, 20:44)mikesilvo164 Wrote: [ -> ] (2015-06-27, 13:54)Mario S. Wrote: [ -> ]Sorry Mike same as before !!!
I actually had no idea how to fix this since on my machine it does not happen. I asked phil65 for some help and he explained that this function is tied to CPU power so depending on the hardware it may take extra time to render. He suggested adding some things and altering the animations. Can you try replacing this file to see if it helps? I can adjust things further but let me know if it lessens the problem or solves it completely.
Thanks Mario
ok i test it !!! hmm cpu power is not so less i think (zotac zbox c520 nano plus , Intel Core i3 4020Y (dual-core, 1.5 GHz) )
Hi.
Great skin but I am struggling tonget backgrounds to work on the main menu.
Any ideas where I am going wrong.
I add random movie fan art but it fails to pull through
N
Nick w, I had the same problem. Try running artwork organizer. I needed to use that for Aeon MQ5, but seemed to fix the issue in Aeon 5 too.
(2015-06-27, 23:14)Mario S. Wrote: [ -> ] (2015-06-27, 20:44)mikesilvo164 Wrote: [ -> ] (2015-06-27, 13:54)Mario S. Wrote: [ -> ]Sorry Mike same as before !!!
Thanks Mario
much better Mike but not perfect
a couple of items:
I tried the VideoDialogInfo update, and I too , also had a transparant background when I went into the Movie Info screen.
Another item, ... on a possible enhancement, ... I like the theme music playing when one displays the Movie Info page, ... but I wonder if it would be possible to have an option for also playing the theme music, when using the Showcase view, maybe play the theme when the info panel is displayed. ... so, if a person turns on the infopanel, then he would also have the option to play the theme music as well.
thanks again
Legion
Hi Mike,
Did you end up making any more progress with displaying the time remaining? The quick mockup you'd made looked really good.
(2015-06-28, 05:31)meesham Wrote: [ -> ]Hi Mike,
I put it off to the side but will resume working on adding it.
