Hey all, question,... Are Video Extras supported in Aeon Silvo??
I tried installing the addon today, and adding some extras for Prometheus, but got nowhere.
thanks for any help
Legion
(2015-07-08, 02:11)Legion455 Wrote: [ -> ]Hey all, question,... Are Video Extras supported in Aeon Silvo??
thanks for any help
Legion
It is supported, If you have extras available and the addon installed select + and choose videoextras.
Still on vaca for a bit but but since I have been using the skin myself and noticed some issues with the time remaining option while also having a few moments to update it. It is now more accurate and works independently from the plot and cast option. I needed to make a crazy Var though
You still need to press "I" until I think adding it on pause is a good option.
Enjoy
And in case I don't see ya, good afternoon, good evening, and good night!
Kinda like adding movie quotes... might make it a thing... you know cause I'm weird
Take care of your family Mike.
Happy vacation
Thanks again.
(2015-07-07, 16:58)kizzer31 Wrote: [ -> ]Mike Doc when u pressed the i button pal, did it show you movie info too as here it only shows the cast side of it sorry to pester you about it
Hi kizzer, I believe it did, there was plot info on the left, clearart in the middle and cast on the right all on the bottom of the screen. I'll see it something is needed for the plot side.
(2015-07-08, 09:29)Mike_Doc Wrote: [ -> ] (2015-07-07, 16:58)kizzer31 Wrote: [ -> ]Mike Doc when u pressed the i button pal, did it show you movie info too as here it only shows the cast side of it sorry to pester you about it
Cheers Mike as i'm getting it all just not the movie info on the left
Thanks for your help
I can't see anything at the moment, sorry kizzer.
I should attempt to use the plotoutline and if this is empty then use the full plot. So unless your movie has a plot outline which is actually null then it should use whatever is in it otherwise use the full plot
I presume your not getting it to display on any movie?
Hi ya Mike thanks for the constant help
I think i had it on plot outline cant check right now missus watching tv lol
Will change it to full plot and report back tomorrow thanks again pal for all your help
I'm running Isengard, Silvo, etc ... and have a question about how the artwork gets added.
I installed a movie, used EMM, to make the nfo, poster and fanart,... then had Kodi add it to my library.
The poster/fanart/thumbnail showed up, .. but no clearart, disc, banner, logo or landscape.
I went into the Movie Info, .. did a rescan, tried both 'use local', and retrieve from the net,... still no disc, clear, etc ... I even went into "+", ... had Artwork Downloader automatically find artwork, still no Disc, clear, etc..
Finally I had to go into "Choose art" , then browse "item folder" , select the correct artwork in order for it to show up. I also had previously removed the movie from my library, then rescanned, thinking it might bring all artwork in then,... nope.
So my question is ... Why isn't all artwork bering loaded 'automatically' into the movie information? (I also have AD set correctly as well)
thanks for any help. I imagine I'm doing something wrong, or midding a sequence somewhere.
(2015-07-09, 02:01)Legion455 Wrote: [ -> ]I'm running Isengard, Silvo, etc ... and have a question about how the artwork gets added.
You've been on this forum from 2009, so I'm assuming you know how AD works.
I have a similar setup as you, but I don't experience this problem.
When you ran AD, did it notify you that x amount of artworks were downloaded?
Did you select use local files?
(2015-07-09, 02:09)marhutchy Wrote: [ -> ]You've been on this forum from 2009, so I'm assuming you know how AD works.
Yes, I have "use local" selected. and when I ran AD, for the movie, it said 10 downloaded, etc ... but whats baffling to me, .is that they're not immediately showing up. Maybe I have to exit Kodi, then restart? Or is Kodi/AD supposed to immediately start showing the new artwork?
Edit: I just reran AD, from the APPS section, and it found logos, etc ... and those logos automatically showed up on the Movie Wall.,... so hmmmm, I'll have to reinvestigate this one ...
Remember that AD will scan your whole movie collection so if there is no local artwork and you have a large movie collection this will take ages.
Local artwork will only show once AD has been run. I've found I need to go into go into my movie view and back out a few times for the refresh to take place and switch to the artwork.
The first time I used AD it took absolutely ages, I set this to run in the background so I didnt know it was still running so I'd end up launching again thinking it wasnt working. Maybe for the first time set so you can see progress then hide there after.
Hope this clears up a few things for you.
(2015-07-09, 10:00)GTunney Wrote: [ -> ]Remember that AD will scan your whole movie collection so if there is no local artwork and you have a large movie collection this will take ages.
Yes, thank you! I think that was my problem as well,... I have 1500 Movies, and it also runs in the background ...
I had the exact same thing happen, ... go in and out of movie info, nothing ... then after awhile it would finally come in.
Hey all, does anyone know if any of the Movie/Video Info panel mods are compatible with SILVO? I'd like to have the Movie Info panel show the cast photos across the panel instead of having to click on Cast.
It looks like Warner306 has a nice one, and also Neurosis13 has an excellent mod.
Thanks for any help, as I dont want to just try and install if they're gonna muck up the skin, causing me to have to start all over
I'm using Isengard, latest nightly & Silvo 2.04
I was not planning on implementing extrafanart but I did anyway since it is a recurring request. I chose to use phil65s implementation that requires his great script.toolbox addon that can add extrafanart to the Kodi database. It is a global view setting and will only be a selectable option if you have that script installed. You must run the script first and choose add extrafanart for the sections you want (ie. Movies and TV Shows). I chose this method because it is the only way I have found that does not require hard drives/servers/nas boxes to spin up just to display the fanart. I added some other things as well and it all needs some testing, let me know if you have any issues. I am not completely back yet but will be popping in to check for bug reports and pushing any fixes to Git.
I have come here to chew bubblegum and kick ass... and I'm all out of bubblegum.
If you recognize where the quote is from let me know, no cheating though!
