(2015-02-24, 09:41)Warner306 Wrote: [ -> ] (2015-02-24, 04:01)leejk Wrote: [ -> ]Just installed the updated skin and loving the new view. Just one question tho: in Mike's screen mockups the movie title looks to be orange and the watched flag is blue in the alternate layout. On mine, they're both yellow. How to change that?
Change the theme in Appearance settings.
I had tried different themes, but the trick was to change only the color setting and leave the rest alone.
(2015-02-24, 18:39)neurosis13 Wrote: [ -> ]@mikeSiLVO
i mad a pack of flags for you:
http://www.mediafire.com/download/b7a7a9...o+Pack.zip
included are some new studio flags in colored and white and the files are corrected to meet the naming conventions in openelec.
i included also some mpaa flags like rated x and as some movies are rated like some TV-Shows i also included them, here are some examples:
Thank you very much neurosis13, I will add them today
Just a minor thing: The disc art animation is off center from the disc case... it wobbles when spun.
(2015-02-24, 20:35)leejk Wrote: [ -> ]Just a minor thing: The disc art animation is off center from the disc case... it wobbles when spun.
the disc is off center or the spinning looks wobbly? If it is the latter are you using a different display resolution than 1920 x 1080 or something that is not 16:9?
(2015-02-24, 20:33)Warner306 Wrote: [ -> ] (2015-02-24, 10:52)martinconroy Wrote: [ -> ]Thanks for this. Yes, you are right regarding (1). I was pointed to the fact that this is a toggle which is preserved between appearances of this screen so as long as I don't remove it. I was just having difficulties because I was using a remote to control an OpenElec MX2 box so the mapping wasn't clear. Fixed that now.
I see your thinking re (2). I tend to use albums so I can review this. I'm sure I can work something out. It may be best (assuming I can work it out) to remove numbers completely, but gradually reduce the opacity so the order is defined that way.
Much appreciated!
I don't think you can change the opacity of text. What you can do is use the [COLOR] tags and define a list of colors for each track. There are different shades of blue that can be used in Defaults.xml for this purpose.
You can change the opacity of almost anything including text colors. If you check the colors folder and each color xml you can see a theme transparent color which changes the opacity using the first 2 characters in the hex color code.
(2015-02-24, 20:41)mikesilvo164 Wrote: [ -> ] (2015-02-24, 20:35)leejk Wrote: [ -> ]Just a minor thing: The disc art animation is off center from the disc case... it wobbles when spun.
I had this same thing when running on a 16:10 display (2560x1600 resolution). It is perfect on a normal 16:9 (1920x1080, etc) display.
Does the TV Tunes add-on work with Aeon Nox-Silvio?
If so (or potentially so), is there any tweaking (non-technical, end-user) needed?
(2015-02-24, 21:55)Don Grimme Wrote: [ -> ]Does the TV Tunes add-on work with Aeon Nox-Silvio?
Yes, activate it in skin settings > extras. Then check the settings of the tvtunes addon if it does not work.
(2015-02-24, 20:33)mikesilvo164 Wrote: [ -> ][quote='monisriz' pid='1937182' dateline='1424730354']
I am using this skin and really liking the mods made to the original Aeon Nox.
I haven't gone through all 60+ pages of this thread so I apologize in advance if this has already been asked/answered before. Is there a way to enable IMDB Top 250 logo/ranking in other views besides "Logo" view? I usually use "Low List" or "Big Fan".
Not available as of now but I can add it... any suggestions as to where?
Thanks - it will be awesome if you can add it. I think for those of us with Top250 playlists, it would be a good idea to have the flag/rank enabled in all views. I personally stick to the views which give the most screen real estate to the fanart e.g. Low List, Big Fan or Showcase. This is even more important as the skin doesn't have any numerical serial numbers so you cannot see how far down/up the list you are..
As for the "where" part of your question.. right top in my opinion works well in most instances..
(2015-02-24, 22:31)monisriz Wrote: [ -> ]Thanks - it will be awesome if you can add it. I think for those of us with Top250 playlists, it would be a good idea to have the flag/rank enabled in all views. I personally stick to the views which give the most screen real estate to the fanart e.g. Low List, Big Fan or Showcase. This is even more important as the skin doesn't have any numerical serial numbers so you cannot see how far down/up the list you are..
I'll play around with it sometime in the next few days to see how it looks and get back to you. Regarding the numbers you can see page numbers in the top bar if you do not disable it. Also the total amount of items can be seen when opening up the side menu, I know that doesn't help with where you are in the list but selecting the scrollbar is a way to determine how close you are to reaching the end.
(2015-02-24, 22:38)mikesilvo164 Wrote: [ -> ]I'll play around with it sometime in the next few days to see how it looks and get back to you. Regarding the numbers you can see page numbers in the top bar if you do not disable it. Also the total amount of items can be seen when opening up the side menu, I know that doesn't help with where you are in the list but selecting the scrollbar is a way to determine how close you are to reaching the end.
Thanks! Oh and I meant knowing the position of a particular movie in the 250-list.
Mike:
Just downloaded from GIT. I like what you did with view selection, it makes it faster to go to the view you want. Have you thought about adding a drop down where you can select what views you want to toggle on daily basis?
Are you done modifying rightlistview? You have the option that doesn't show the year that doesn't highlight the movie / year / rating etc and you have the option that shows the year and highlights rating/minutes etc. Not sure this is the way you vision this view.
(2015-02-25, 04:48)Edworld Wrote: [ -> ]Mike:
I am trying to keep it as much Nox 5 as I can other than adding views, some mods, and tweaks here and there. What your talking about sounds like what Aeon MQ does.
The alternate layout is "my vision" I personally like how that came out and do not like the year, lines or highlight bar... having both options appeases many.
