(2015-10-24, 20:10)wilmans2m Wrote: [ -> ]really ? well so how to activate ? Don't see any option. Do i need to reset all settings ?
thanks
Not sure exactly AFK... but it's something like Main Menu layout... It's where you choose between 5,3,or 1 items just keep cycling till it says vertical menu.
OK Know where to find it thanks
I LOVE the vertical menu layout Mike!
It's going to take a while to acclimate myself to it though.
(2015-10-22, 17:32)mikesilvo164 Wrote: [ -> ]You need the latest skin.shortcuts from its GitHub page...
It seems like this could be a reason I miss my update day target.
I probably shouldn't push a skin update to the repo if the required script version needs to be installed manually from Git.
I have the same problems, in my raspberry it's impossible change the menu and impossible put new backgrounds.
thanks
Not sure if this is skin related. But when I go to any addons I have installed. I only get a list of movies that I have already watched.
Not sure what I did to make this happen.
(2015-10-25, 02:55)AL8782 Wrote: [ -> ]Not sure if this is skin related. But when I go to any addons I have installed. I only get a list of movies that I have already watched.
Change the watched status in the sidebar. If that doesn't work, contact the addon creator. Support for piracy addons is not provided in the Kodi forums.
(2015-10-24, 23:21)mikesilvo164 Wrote: [ -> ] (2015-10-24, 23:11)emiralles Wrote: [ -> ]I have the same problems, in my raspberry it's impossible change the menu and impossible put new backgrounds.
thanks
Post a debug log (wiki)
Solved, thanks a lot, check my kodi.log and my problem was in userdata/addon_data/script.skinshortcuts. Remove it and start again, and everything it's ok.
I have the same problem, watched movies are hidden. Just did the update to 15.2.
Any hiding of watched movies is not skin related. It will most likely be an activated setting somewhere. Check for the option Warner explained above.
There is nothing as Hide Watched in the side bar... Well not in your skin... When in Confluence it is visible and activated...
(2015-10-25, 21:15)moravec Wrote: [ -> ]There is nothing as Hide Watched in the side bar... Well not in your skin... When in Confluence it is visible and activated...
If it is not in my skin then why do I see it?
Sorry, I see now... It is a toggle button... In Confluence it is "Hide watched" On/Off.
Tks.
(2015-10-25, 13:03)moravec Wrote: [ -> ]I have the same problem, watched movies are hidden. Just did the update to 15.2.
My problem is the opposite. Watched movies are the only movies that show up. Movies I've never watched don't show up.
So as of now I can only watch movies I've already seen
I actually thought all videos was for something else. Thx fixes it.
