2021-11-08, 20:02
Dear @mikeSiLVO
Sincerely
(2021-11-08, 19:36)mikeSiLVO Wrote: [ -> ]Yep I think there might be also a problem with code in the same .xml for Dimmer:(2021-11-08, 18:45)UTAVATU Wrote: [ -> ]Dear @mikeSiLVO
(2021-11-07, 22:14)mikeSiLVO Wrote: [ -> ]I had a feeling there was gonna be one more bug so I waited until the next one before submitting to Kodi repo.Hmm, thank you for your fix, but it has still with bug. Try to go to AutoHide in OSD settings and choose option: 7 seconds, it will return Inactive instead of 7 seconds. Other second options are fine, it's only problem with 7.
UTAVATU was the "winner"
v8.0.1 submitted.
Sincerely
I missed the bit about inactive. It should be fixed on Git.
Quote: <include name="SelectDialogInfoDimmer">When you try to set Default 85%, it will return and show always 90%, not 85%.
<item>
<label>90%</label>
<onclick>Dialog.Close(1129)</onclick>
<onclick>Skin.SetString(DialogInfo.Dimmer,90%)</onclick>
</item>
<item>
<label>85% - $LOCALIZE[571]</label>
<onclick>Skin.Reset(DialogInfo.Dimmer)</onclick>
</item>
Sincerely
