Thank you for Help!
But my second question was. How can i get this short colored movie sentence/info. In "AEON Nox" I have the colored info, but when i change the skin to "AEON Nox: Silvo" the colored info disappear.
What is the Problem?
(2016-06-16, 00:34)Skiller1 Wrote: [ -> ]Thank you for Help!
Try this:
Skin Settings
Silvo Mod
Use Colored Icons and Mediaflags
(2016-05-31, 04:19)mikeSiLVO Wrote: [ -> ] (2016-05-29, 22:35)irn|bru Wrote: [ -> ]Mike and/or Mr. V:
Is there any way to change the info text in the widgets? I'm using the Next Aired add-on as my Upcoming Schedule widget for TV programs but it currently only displays the TV show name: Image 1. I know we can just highlight the show in the widget to display more details: Image 2, but I would like it to be able to display more information without having to do that: Image 3 (mock-up). Is there a setting I'm not seeing or where and what do I need to change in an xml file to make it work? If there is a solution?
I am not going to mess with the Widgets for a bit... Mr. V appears to be taking a much deserved break so when I have more time I can look into changing things just remind me in a couple of weeks if I have not mentioned anything about it before then.
Mike, not pushing things... just giving you a couple weeks reminder like you asked.
I looked at the xml code you referred me to but it kinda made me go a wee bit crazy so... as always, huge thanks for the work you guys do!
(2016-06-15, 19:59)mikeSiLVO Wrote: [ -> ] (2016-06-15, 19:40)Hardax Wrote: [ -> ]A feature request if I may?
I noticed a little addition to the Estuary Mod skin that although small I find really useful.
When browsing your movie library and also in the preplay screen would it be possible to add somewhere near the media flags perhaps something that indicates the end time of the movie? Estuary Mod has this while browsing the library and also on the preplay screen in the corner. It shows the duration of the movie and also at what time the movie would be ending.
Its a really nice way to help pick a movie to watch based on when it would be finishing.
Ummm... That has been in the skin since the INFO label went from PVR only to library items. Check the screens in the first post
Would it be possible to get the end time info into the Movie Info / Preplay screen? Nice big text at the top to go with all the other info?
Mike, what happened to the 164? It helped identify you as an individual - now I find it difficult to separate you from the other 160-odd Mike Silvo's
(2016-06-16, 01:38)flhthemi Wrote: [ -> ] (2016-06-16, 00:34)Skiller1 Wrote: [ -> ]Thank you for Help!
Try this:
Skin Settings
Silvo Mod
This Option is already activated. Do you have an other Idea?
Nope. No more ideas here.
I'm trying out the latest jarvis version of the skin from Github on the latest kodi Jarvis 16.1 on both Libreelec and Openelec.
I have been having 2 problems on both setup and I have been unable to resolve them. I've reinstall both OS and skins a few times without success.
I have all the scripts install except for the traks script since I don't use it. My backgrounds are locating on the device itself in a folder label backgrounds located in the kodi userdata folder.
Now the problems I'm have are as such:
1) The backgrounds as well as sometimes the menu bar turns black randomly. The background do it while rotating photos and also while changing menus or entering to settings and when the menu-bar does it, it also turns the whole submenu and its border black where no words can be seen. When this happens my second problem appears..
2) Some of the letters/words turns into white "Blocks".
The only thing that helps to resolve it temporary is restarting or reloading the skin but it happens to often to keep having to do that. I Shold also mention that the "blocks" issue also occurs on the Menu bar, Submenu bar as well as inside System settings menu.
The pictures below will show a sample of the issues that are occurring.
Thanks in advance to anyone that can assist me in resolving these issues.
(2016-06-21, 06:40)vshah24 Wrote: [ -> ] (2016-06-08, 19:47)vshah24 Wrote: [ -> ]
Love this Skin, as well as the updates. Can someone please point out the thread page number where I can customize the Menu bar?
For example, I would like to add a little text to the left of the weather forecast on the Menu Bar.
Any help is much appreciated. Keep up the good work, all!
Anyone?
I found it to be in the skin folder, 1080i, Home.xml file.
Around line 126. (《Control type="label", height, "《label》"this is where u put your text'《/label》").
You could copy from 'control to control' and paste it below it and even remove the id# from what u paste so to not disrupt the original skin settings. You can also change the textcolor eg. Red.
Hope that gives u an idea.
I'm having a problem with setup. Now it's been awhile since I set up Kodi and did any kind of customizing so I might mix some stuff up but I'll try and explain as best as possible until I can get a screen shot. I use logo view and have all kinds of information that displays on the bottom, user ratings, tag lines for the movie, length of the movie, and rating. Well I noticed that on the logo view screen movie ratings will say either NR or fk12 or something else. But when I click the info button it displays the correct mpaa rating 99.9% of the time, there might of been one that was wrong. Anyways, I remember a long time ago in the original Aeon Nox skin someone told me how to fix the ratings. Well I've looked everywhere I can think of and can't find out how to fix it with this skin. Is there a way to fix it?
Oh and one other thing. Not sure if it ever worked with this skin or not, I know it did with Aeon Nox. I use to be able to hit the plus button and bring up Tvtunes and video extras. Now when I do that I only have options to change different artworks for the movie. If I want to view a video extra I need to go into my programs folder to see what movies have extras.
(2016-06-22, 05:19)Tatts4Life Wrote: [ -> ]Oh and one other thing. Not sure if it ever worked with this skin or not, I know it did with Aeon Nox. I use to be able to hit the plus button and bring up Tvtunes and video extras. Now when I do that I only have options to change different artworks for the movie. If I want to view a video extra I need to go into my programs folder to see what movies have extras.
In this skin pressing "i" brings up some extras, so you can try that to see if it's that you are speaking about, but u must have extending info or/and CinemaVision script install, which u can setup in System, Appearance, Skin, Settings, Video info.
Hope that helps.
I just installed the latest git version for Javis and it works very well.
Now tried in include my own widget, for this I have to change the following variables:
<param name="Info1">$VAR[HomeWidget$PARAM[id]Info1Var]</param>
but I did not find in the variables.xml
where I could find this...
thanks
is there a toggle button for turning on and off predictive text on keyboard?
Yes there is in skin settings Extras>Enable Autocomplete
