(2017-09-17, 12:56)heula Wrote: [ -> ]Is there a way to set the automatic scroll speed of the video plot and review?
You'd have to change it in the xml but if you tell me where and why I might change in the skin...
(2017-09-17, 21:53)meowmoo Wrote: [ -> ]because the sun is standing to low....how in hell should anybody know why your kodi crash, without any info/log at all...
It has to be the sun or maybe it is the rash on my kids ass (Kid does not actually have a rash, I'm a good DAD
). No scratch that, it most definitely is gremlins (Or ass-rash)
I'm just gonna have to ignore posts like those from now on. Not worth our time
(2017-09-17, 22:02)Alyy Wrote: [ -> ]Here:
http://www.cjoint.com/doc/17_09/GIrubhzN...di.old.log
Now I can not choose the skin in the interface, it no longer appears.
That's not a
debug log (wiki) and you just mentioned above that you removed the skin so that could be a real good reason why it "no longer appears".
I suggest you use my repo and stop doing things manually
EDIT: IIRC this is now the umpteenth time I have recommended you to just use the easy way of installing and updating this skin. Most of our previous interaction has, to me at least, not been the most pleasant experience...
(2017-09-18, 00:14)snijdelwijk Wrote: [ -> ]i had a clean install today but now i have a little problem.
in my previous version of nox silvo i had movie info in my widgets.
now i cant find the option to have movie info when i scroll thru movies
can someone help me?\
I will probably, eventually, move most if not all Widget options from the Skin settings > Widgets section to the actual Widget setting in the Main Menu customizer. Go to your menu items Widget and enable Panel Widget info, that is where the setting is now located.
(2017-09-18, 00:46)mikeSiLVO Wrote: [ -> ] (2017-09-17, 12:56)heula Wrote: [ -> ]Is there a way to set the automatic scroll speed of the video plot and review?
It has to be the the sun or maybe it is the rash on my kids ass, no scratch that it is gremlins [emoji14]
That's not a debug log (wiki) and you just mentioned above that you removed the skin so that could be a real good reason why it "no longer appears".
thx! now it works fine!
Thanks for all your hard work!
Verstuurd vanaf mijn SM-G955F met Tapatalk
there is something else I can't find.
I can't see my watched movies etc they are not marked as watched.
how can I add this to my widgets ?
(2017-09-18, 01:08)snijdelwijk Wrote: [ -> ]thx! now it works fine!
Please do not quote any of my multiple reply posts. If you cannot figure out how to separate them and respond to just your own...
Then just be aware that I can figure out who and what your talking about with just a simple @me or if you mention me in any way shape or form.
In other words DO NOT just hit quote on one of my long replying other users posts, OK?
I reply to many cause I want you all to read what I say to others cause you never know when that knowledge will become useful to your situation
(2017-09-18, 01:55)snijdelwijk Wrote: [ -> ]there is something else I can't find.
You can use options in either the addons responsible for the Widget and/or create a playlist to exclude watched items but there is not a way to show your watched items mixed with your unwatched until I have time to want to add such a feature. In other words show what you want and if you want all to be shown enter your library instead of using a Widget, cause unless I redesign the entire skin... that is what said library is for
EDIT: As a side note... If you watched it you should definitely remember doing so or what is the point of watching or even knowing that you watched something if you can't remember watching it in the first place
If you do not know or remember then just watch it again over and over until you do
mikeSiLVO, How it's not a debug log ?
Where do I say that ? after installation and refresh of the skin, the folder has been removed from itself.
Because I never had a problem with the skin itself, this is the first time. thx !
There is no scroll bar in Aeon Nox 5: SiLVO for Leia in list view when pressing right cursor key. However, in Aeon Nox 5: SiLVO for Krypton I don't have this issue. Is where a way to get the scroll bar in list view for Leia? Thanks in advance and best regards fred76
(2017-09-18, 10:42)Alyy Wrote: [ -> ]mikeSiLVO, How it's not a debug log ?
It's not a debug log because you didn't turn on debug log mode in System settings.
1) Click on System
2) Click on System again in the menu that appears with the icon on it
3) Go to Logging
4) Turn on Debug Logging
Now you can close Kodi and then restart Kodi and repeat whatever it is that causes your problem. If it's a skin issue then you need to have the skin installed so if you have uninstalled Aeon Nox Silvo you need to install it again prior to turning on debug logging. Once the issue has been reproduced close Kodi (Unless it's a crashing issue) and paste the "kodi.log" file without restarting Kodi. So you need to know how to find the kodi.log file.
[/quote]
i am so sorry that i spam the forum. i never used it before and I wanted to try what you said about reply. but I did wrong and do not know how to delete post.
(2017-09-18, 12:32)fred76 Wrote: [ -> ]There is no scroll bar in Aeon Nox 5: SiLVO for Leia in list view when pressing right cursor key. However, in Aeon Nox 5: SiLVO for Krypton I don't have this issue. Is where a way to get the scroll bar in list view for Leia? Thanks in advance and best regards fred76
Working fine for me in both movies and TV. Just an fyi.
(2017-09-18, 15:30)flhthemi Wrote: [ -> ] (2017-09-18, 10:42)Alyy Wrote: [ -> ]mikeSiLVO, How it's not a debug log ?
1) Click on System
3) Go to Logging
Like I could not change my skin. I installed my backup osmc. I wanted to do as you say to recover the log, but then the skin has installed correctly.
I would not be what happened.
(2017-09-19, 16:31)bobrap Wrote: [ -> ] (2017-09-18, 12:32)fred76 Wrote: [ -> ]There is no scroll bar in Aeon Nox 5: SiLVO for Leia in list view when pressing right cursor key. However, in Aeon Nox 5: SiLVO for Krypton I don't have this issue. Is where a way to get the scroll bar in list view for Leia? Thanks in advance and best regards fred76
Thank you very much for your reply. Unfortunately, I have the scroll bar with right cursor key in Krypton but not in Leia. Interestingly, I get the scroll bar in Leia's TriPanel View but not in the simple list view (which I use for music). Any hints? Thanks in advance fred76
(2017-09-19, 21:34)fred76 Wrote: [ -> ] (2017-09-18, 12:32)fred76 Wrote: [ -> ]There is no scroll bar in Aeon Nox 5: SiLVO for Leia in list view when pressing right cursor key. However, in Aeon Nox 5: SiLVO for Krypton I don't have this issue. Is where a way to get the scroll bar in list view for Leia? Thanks in advance and best regards fred76
Always try to provide as much info as possible when reporting issues... The music part is kind of important
Fixed on
GitHub for now.
(2017-09-20, 10:20)mikeSiLVO Wrote: [ -> ] (2017-09-19, 21:34)fred76 Wrote: [ -> ] (2017-09-18, 12:32)fred76 Wrote: [ -> ]There is no scroll bar in Aeon Nox 5: SiLVO for Leia in list view when pressing right cursor key. However, in Aeon Nox 5: SiLVO for Krypton I don't have this issue. Is where a way to get the scroll bar in list view for Leia? Thanks in advance and best regards fred76
Fixed on GitHub for now.
Dear mikeSiLVO,
thank you very much for taking care of my scroll bar problem. Unfortunately, the fix does not work for me. I have no scroll bar in list view in music AND movies section. Scroll bars appear in movies tripanel (which i use as a workaround for me for movies) but not in list view. In music section there is a scroll bar in right view, but not in list view or tripanel view. That's what i observed. As mentioned, this is only on Leia, on Krypton everything works well.
Thank you very much for your help. fred76
