Hi, I have searched the threads and cant find the problem I am having.
I have used this skin on Kodi Jarvis (windows) and its great and the backgrounds I have chosen all work but when I try and transfer it to my android tv all the backgrounds disappear and the link I have created in file manager no longer works can anyone tell me what I am doing wrong?
Many Thanks
(2016-03-01, 12:05)rpw79 Wrote: [ -> ]Hi, I have searched the threads and cant find the problem I am having.
Many Thanks
Put all of your background images in the database>CDDB folder. Then add them from there in the System setup.
I will try that.
Thanks Droidal
Many Thanks
Also check the link for the image in the gui I think it is not sure on Jarvis. If u did it on widow it will have windows location you need change them to special://home.
(2016-02-29, 23:55)Tatts4Life Wrote: [ -> ] (2016-02-29, 18:32)Tatts4Life Wrote: [ -> ]Just loaded Kodi 16 and this skin on a new build and have to say I love the add-on status screen. It makes finding what I need so much easier. Now I just need. Remember all the other add-ons that I use in my old setup.
I do have one question, on my old setup I had a rotating or live background for the weather tab. Can anybody tell me what it is I select to activate that again? Oh also what is the add-on I need to add movie collections into one folder on kodi? It's been forever since I set that up.
So I have everything set up the way I had it before on my old system except for weather. Anyone know how to get it so I can have the conditional weather background? I like to use weather as my starting menu and it looks boring with just the black background.
Is this help?
http://forum.kodi.tv/showthread.php?tid=261808
I don't use the weather menu so I am not sure if this is what you are looking for.
Thanks lfcfan that worked. I don't remember having to do that before. I wonder why I had to for this install?
Glad it worked for you and as you know Mike is constantly improving his Mode, that might be the case.
think its because its square poster view, the option for poster view is not there any longer since updating to Jarvis and latest aeon nox silvo
I to miss the normal poster view I'm hoping it gets added again at some point when the guys have time
(2016-03-01, 12:49)droidal Wrote: [ -> ] (2016-03-01, 12:05)rpw79 Wrote: [ -> ]Hi, I have searched the threads and cant find the problem I am having.
Many Thanks
I tried this and some of the single pictures work and some dont and the multi images dont work at all any ideas anyone?
hi mike
I was wondering if you can help me? Am trying to add a search button for extended info I was talking to quihico an he gave me the piece of code he used. Only issue he used his in a modded version of confluence and obviously the home.xml is not the same as nox 5
Issue I have is I have managed to get the button to show on the home screen if I click with a mouse it will also work. However I can not move on to the button with a remote or the arrows on the keyboard.
I am aware I need a few tags <onup> <ondown> maybe <onleft> <onright> he has told me I need to add these to the buttons before and after mine. Am no skinner so I can not get this right. Please can u help or guard me in making a working button in the home.xml for this skin
(2016-02-29, 06:32)droidal Wrote: [ -> ]I just saw something. When I go to System> Add-Ons, and then search "Aeon Nox" I get 3 repositories, all (5.8.4-3.0.2) and 3 Skins, all (1.0.2). Could this be creating a conflict? I'm going to do a back up before I uninstall the multiples.
Yeah, multiple skin folders can cause problems.
(2016-02-29, 09:06)Halsi Wrote: [ -> ]Hello, I'm new here an write from Germany.
Sorry for my english, I use an auto translator.
I now Kodi Jarvis and Silvo 5.8.4-3.0.2 on Amazon FireTV (1. Gen.)
My settings were all taken.
Another version I have Silvo 5.8.5.-3.0.3. Is this a beta version ??
Both versions have a problem in view of music. Here I only list and symbols (Version 5.8.5 have rightlist, too), all the other missing.
All views are turned on.
Is that right ?
And the sort by rating not do. the star of valuation are not shown in view list.
previously with Kodi Isengard and Silvo 5.7 everything was right.
Please help, thank you
Might be related to some Jarvis music changes, I'll look into it but for now you can try adding the music to your library.
(2016-02-29, 11:57)droidal Wrote: [ -> ]It appears to me my error is because of "ImportError: No module named PIL" Any idea why "PIL" is not there and how do I install it?
Thank you, Ron
That is why I asked if you were using a Fire device a few pages back... I have seen it before where the PIL module is either not available for those devices or you are installing manually without the needed dependencies.
(2016-02-29, 22:38)maxwel Wrote: [ -> ]Hi Everyone,
Can someone please help me. how can i fix this issue.. when i enable 'Replace with Extended Info for Movies and Shows' in the skin settings .. the extended info dialog are not working but when i disable 'Replace with Extended Info for Movies and Shows'.. the standard video info dialog is working fine.
Thanks in advance
Mike
Debug Log (wiki) please.
(2016-03-01, 00:18)morstef4 Wrote: [ -> ]First of all, thank you for this fantastic, very informative and for me THE skin.
I have Milhouse OE7 #226 installed and I have downloaded your master from git yesterday.
Other add-ons were also installed from git such as Script.extendedinfo, script.toolbox, wheater and more...
Everything works GREAT and it is very beautiful, no errors , no glitches.
I like trying new bells and whistles and I recently discovered artwork for sets.
By default your imaginative skin used existing arts showing great stuff when a collection is highlighted.
I really don't want more than that.
The question I have is this :
1 - When I select a collection (using tripanel menu) it opens the movies list and by default Kodi bring the cursor on ".." then the background turn black.
If I open the left menu and select something specific as background, it will be perfect for this collection.
The problem is for the next collection the same background will be displayed.
Am I missing something ?
2 - Is it right to say about the left menu called "download extrafanart" will action command :
kodi-send --action="XBMC.runScript(script.toolbox,info=extrafanartmovie, silent=true)"
3 - This is to cache all extrafanarts right ?
thank you
1) the background settings only set the fallback for the entire section (i.e. movies) not for each set. I might be able to use the new container.set.fanart INFO label but not sure if that is for Jarvis or Krypton till I look into it...
2 & 3) That is just how it is worded but yes it caches the extrafanart but only for movies so you would have to do the same for TV Shows if you want them available there as well.
(2016-03-01, 21:37)rpw79 Wrote: [ -> ]I tried this and some of the single pictures work and some dont and the multi images dont work at all any ideas anyone?
Just set it up on the Droid device independently and add the folder paths to the file manger to be able to select them.
(2016-03-01, 21:41)Madchester312 Wrote: [ -> ]hi mike
I'd say the easiest way, if you do not use the Global Search addon, would be to search for HomeSearchButton in the includes.xml and change it to use Extended Info instead by altering the onclick, then search for the same in home.xml and either change the condition or remove it completely.
First of all, I love the skin. I've had an issue with customised sub menus. They seem to have reverted back to the original sub menus and now when I go in to change them back, the option to do so isn't there. Any idea what could be causing this? I'm on Jarvis 16.0 running on Windows 7 pro.
Thanks in advance!
(2016-03-01, 22:11)Chedz404 Wrote: [ -> ]First of all, I love the skin. I've had an issue with customised sub menus. They seem to have reverted back to the original sub menus and now when I go in to change them back, the option to do so isn't there. Any idea what could be causing this?
Thanks in advance!
Are you updating from a very old version and do have script.skinshortcuts installed?
Debug Log (wiki) would help find the issue.
Thanks Mike that worked sport on. Really appreciate your help.
