I'm trying to add a power button (like the star button) to replace the power menu in the main menu bar, but can't find any information on how to do this. Is it a widget, do I have to modify xml files, all info is appreciated!
Also, I would like to modify the list view so that it doesn't show date stamps. Now it looks like this:
watch gallery
Only 7 episodes are shown above the fold, I had another build that also used the list view but without date stamps and it showed 14 episodes, that looks much better. Aeon Nox Silvo's FanArtList comes very close, but the left panel is not aligned with the right one, which disturbs me :p
(2017-04-14, 14:36)freekdl Wrote: [ -> ]I'm trying to add a power button (like the star button) to replace the power menu in the main menu bar, but can't find any information on how to do this. Is it a widget, do I have to modify xml files, all info is appreciated!
Funny this was the last post in the thread as I came in here to search for the very same thing.
I am trying to figure out a way to use icons instead of text on the main menu.
Specifically I want to replace the text link "POWER" on the main menu with a icon. I would be happy with using an image that i made myself or with web based icons such as Font Awesome if possible.
I do not use any of the other power options or see a need to since I run kodi on my pc. As of now my "POWER" link in the menu is set to quit which of course just shuts down and closes Kodi. I would settle for a single image however I would really like to use 3 images. One image for unfocused, one for focused and one for onclick or mousedown.
Detailed instructions would be great but I would settle for just knowing which files I would need to make changes in to achieve this.
As a side note, I love the Aeon Nox 5 Silvo skin and I think it would be an awesome addition to add the ability to choose either an image or text when creating a menu item.
Any help in this would be greatly appreciated.
EDIT: I forgot to add that I am using Kodi Krypton 17.1 and Aeon Nox 5 Silvo 6.0.5
(2017-04-14, 14:36)freekdl Wrote: [ -> ]Also, I would like to modify the list view so that it doesn't show date stamps. Now it looks like this:
watch gallery
In kodi you have to go to Skin Settings > Advanced > List view layout and change the setting to Slim List. This setting changes the default view for all list.
(2017-04-10, 06:15)sniferx1 Wrote: [ -> ]Can someone please help with below issue?
Kodi Version: 17.1
Skin Version: V6.0.5
KODI OS: OSMC
I got AEON NOX 5: SiLVO skin on 5x KODI (2x VERO4K and 3x Pi2) boxes around house and all connected via MYSQL server. Problem is when I scan new movies via one BOX, the home screen "Recently Added Movies" Widget updating on the same box but on other 4x Boxes I must restart to get the movies I just scanned.
On the other hand post scan If I go to the "Recently Added Movies" window, I can see the new movies.
What I can do trigger "Recently Added Movies" Widget update on other boxes? coz with default confluence Skin soon as I add via one box all other boxes will show up the new movies within 1 - 2 min.
AEON NOX 5: SiLVO is a very beautiful skin which I was using over 2 - 3 years and I can't go back to any other skin.
Can anyone help with this issue please? Or try to include this issue as fix in to next release....
Hi!
Can anyone help me to setup "Conditional Weather" background on aeon nox silvo skin.
(2017-04-18, 08:34)shuvro Wrote: [ -> ]Hi!
you have to have a Image Source , Click on Add-ons than Click Look and Feel , you will see Image Collections, Scroll down till you locate Weather Fanart, I use Prarie. Than you have to go to the Weather on Main menu tab click it than it will show backgrounds, icons click backgrounds select which you want and you can click get more and retrieve more. than set it
I have a problem with my Tvshows Playlist in the dynamic Home background. On Jarvis or Krypton Too
The Cd case won't appears for TvShows and it's ok for Movies or Musics
Thank a lot
Can someone help me. I have set up a profile for the Kids, but can't change the Menu Colors. I can on the main profile but not the addition profile
For the life of me I can't figure out how to disable a menu item in Jarvis. There's no blue dot to disable like in regular Aeon Nox.
For example, if I wanted to not show POWER as an menu item, how would I disable it from showing on the menu without actually deleting it.
(2017-04-18, 21:50)#1Guru Wrote: [ -> ]Can someone help me. I have set up a profile for the Kids, but can't change the Menu Colors. I can on the main profile but not the addition profile
While you are setting lable text, insert the following [COLOR XXX] insert you text here [/COLOR]
Where XXX you select the colour you want. For example [COLOR red] insert you text here[/COLOR]
Color chart will be in the below link
http://forum.kodi.tv/showthread.php?tid=210837
Here's some more colors names and codes but no nice samples
and it includes Silvo Orange :BSEG:
HERE
(2017-04-09, 20:41)solamnic Wrote: [ -> ]@mike
in bannerplex view while browsing a tv show the all seasons poster is gone?? (it shows only a folder icon)...
Same here but in Icons view.
There's a fix?
(2017-04-19, 03:28)comhen Wrote: [ -> ] (2017-04-18, 21:50)#1Guru Wrote: [ -> ]Can someone help me. I have set up a profile for the Kids, but can't change the Menu Colors. I can on the main profile but not the addition profile
This isn't for Label Text its for Menu Bar Color
Hi
Sorry to ask that but where is the vertical option menu ?
I couldnt find it since yesterday... I think I'm blind...
Thanks for your lights
Awesome skin,
I posted an idea for New skin
http://forum.kodi.tv/showthread.php?tid=312720
If someone is interesting to make it..
