Hi thanks for your replies
Ok so basically I had 2 versions both helix as far as am aware. The ski shortcut folder in userdata must have some how been conflicting. Anyway I have removed it an now I have the option to manage sub menu
Maybe whoever modded the skin on top of your mod messed it up. If u have a few versions of the nox 5 skin do they all share the skin-shortcut folder in user data.
Sorry for any waisted time
Oh am yeh I read you had said you don't support helix no more I will be updating over the Christmas period.
Thank you for your time and help. Obviously your continued dedication to this skin
Be careful jarvis is not in final stage.
Yeh won't be touching Jarvis I wasn't keen. I have isenguard on my laptop but still helix on my t8. Cheers
Noddyrams, wanna be really safe? Copy the entire Kodi folder to a safe place then install the updates. If it goes wrong you can delete the kodi folder and copy your backup back in it's place.
Hey there are so many posts here, and i really could not find anything, really..
So my question...how do i create one more entry in the main menu? Which file do i have to edit? i want add some entrys
Thank You
(2015-12-04, 18:29)Shinoby92 Wrote: [ -> ]Hey there are so many posts here, and i really could not find anything, really..
Thank You
Skin settings > Set up the Aeon Nox main menu > scroll down and select add then choose all the settings you want.
Still loving your skin Mike. Thanks for all the great work!
Today I updated to the latest skin version from the repo. Had to recreate my own menu and backgrounds, but that was no problem.
However, I did find a bug. When I selected the infoline "TV Show library statistics" it did not show. I changed Kodi to English and there it was! Changed back to Dutch and it disappeared again... Could you look in to this?
(2015-12-04, 18:59)NLVince Wrote: [ -> ]Still loving your skin Mike. Thanks for all the great work!
Looks like there is a mistake in the translated string from Transifex...
In the skins language/Dutch folder open the strings.po file and search for
msgctxt "#31053"
msgid "TV Show library statistics"
msgstr "TV-seriebibliotheek statistieken "
and remove the extra space after statistieken and restart Kodi.
Thanks for your fast reply. That fixed it!
I also updated the translation on Transifex
(2015-12-04, 16:21)flhthemi Wrote: [ -> ]Noddyrams, wanna be really safe? Copy the entire Kodi folder to a safe place then install the updates. If it goes wrong you can delete the kodi folder and copy your backup back in it's place.
thanks for the reply, ended up starting from scratch though.
(2015-12-01, 21:57)mikesilvo164 Wrote: [ -> ]I just pushed an update for the widgets. Those that have issues please try the latest from GitHub and report if everything is A-OK. If it is not try to post as many details as possible so I can get em all fixed.
Testing the new widgets but still notice its only 6 items on the panel view and not 7 like before therefore causing stretch coverarts plus no duration and rating info included?
thanks
small bug movie sets, under movie title collection:
(2015-12-05, 01:51)Edworld Wrote: [ -> ]small bug movie sets, under movie title collection:
I have the same issue, but hadn't had the chance to get a screenshot yet.
Cheers, Carl.
on this view, doesnt display tv station:
