Hey guys, get the message "Installation failed"
Kodi log:
19:16:09 T:10408 ERROR: Previous line repeats 1 times.
19:16:09 T:10408 ERROR: XFILE::CDirectory::GetDirectory - Error getting zip://special%3a%2f%2fhome%2faddons%2fpackages%2fskin.aeon.nox.silvo-5.7.4-2.0.9.zip/
19:16:09 T:10408 ERROR: CAddonInstallJob[skin.aeon.nox.silvo]: invalid package special://home/addons/packages/skin.aeon.nox.silvo-5.7.4-2.0.9.zip
19:16:09 T:5280 NOTICE: Thread BackgroundLoader start, auto delete: false
19:16:29 T:10884 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
Is the server down or something?
Here are the ressource.addons from "Team Kodi" (Author) with a Textures.xbt inside
MusicWidget-selection does not work for me. It gives no Music-Widget name. See screenshot. Every other widget gives a name after selection and works.
http://i.imgur.com/UV1NlrW.png
How about make the options in the channel-EPG equal to the ones in the "Big EPG"?
Options in channel EPG:
http://imgur.com/ZQeW3oj
Options in "Big EPG":
http://i.imgur.com/ZQeW3oj.png
Did I miss something?
My orange colour is now blue and it's not changing.
I saw a setting that said Color customizer, but it does nothing.
Mr. V widgets have been merged into master
You need to install/update skinshortcuts and skin.helper.service from there respective GitHub pages.
If you have already setup widgets previously and they are not appearing re-select your layout.
This addition needs thorough testing and user feedback. Performance is especially important so if you have low end hardware, please add as many widgets as you can and let us know if things slow to a crawl or you notice any bugs.
(2015-12-14, 18:04)Solo0815 Wrote: [ -> ]Here are the ressource.addons from "Team Kodi" (Author) with a Textures.xbt inside
Options in channel EPG: http://imgur.com/ZQeW3oj
Options in "Big EPG": http://i.imgur.com/ZQeW3oj.png
Those addons are for posters not fanart.
Widgets have been completely redone so...
I will take a look at live tv stuff if/when I get a chance. Too much is going on right now to focus on that ATM.
(2015-12-15, 05:28)marhutchy Wrote: [ -> ]Did I miss something?
Need to install script.skin.helper.service.
(2015-12-15, 06:23)Warner306 Wrote: [ -> ]@mike,
Would you be interested in this mod from Aeon MQ6? I would find some use in it. I'm not sure about other users.
Progress Bar Buffer/Cache
There is already a lighter buffer bar to help it standout, or do you mean adding the ability to choose a custom color for it?
(2015-12-15, 11:10)mikesilvo164 Wrote: [ -> ] (2015-12-15, 05:28)marhutchy Wrote: [ -> ]Did I miss something?
Okay, got that now.
I'm changing colours like crazy but not seeing where the respective changes are being reflected.
PS. I'm using the vertical menu.
hey all
after the new update all my backgrounds are black how can i change theme to single background like in the older version
thnx
Tested the new (merged) version with latest skinhelper and skinshortcuts:
I can't get the
upper widgets (widgets1) to work, when "Advanced Widgets" is enabled. They doesn't show up. The lower row (widget2) is working fine. Only in the TV-section, "Recent Recordings" show up in the upper row
Can anyone confirm this?
Things that didn't help:
* renaming userdata -> skinsettings file
* tried lower and middle menu
* Hide widgets that are unfocussed
BTW:
There is an error in the logs:
18:02:49 72959.460938 T:3037868032 INFO: load skin from: /storage/.kodi/addons/skin.aeon.nox.silvo (version: 5.7.4-2.1.0)
18:02:49 72959.484375 T:2682336160 INFO: Python script stopped
18:02:49 72959.484375 T:2682336160 DEBUG: Thread LanguageInvoker 2682336160 terminating
18:02:49 72959.648438 T:3037868032 INFO: load fonts for skin...
18:02:49 72959.656250 T:3037868032 INFO: Loading fonts from /storage/.kodi/addons/skin.aeon.nox.silvo/1080i/Font.xml
18:02:49 72959.773438 T:3037868032 ERROR: POParser: missing msgstr line in entry. Failed entry:
msgctxt "#31128"
msgid "Channels View"
msgstr "Kanal Ansicht"
msgctxt "#31140"
msgid "Sideblade Options"
msgstr "Sideblade Optionen"
18:02:49 72959.781250 T:3037868032 DEBUG: POParser: loaded 359 strings from file /storage/.kodi/addons/skin.aeon.nox.silvo/language/German/strings.po
18:02:49 72959.781250 T:3037868032 DEBUG: POParser: id:31128 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
18:02:49 72959.789062 T:3037868032 DEBUG: POParser: id:31177 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
18:02:49 72959.789062 T:3037868032 DEBUG: POParser: id:31200 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
18:02:49 72959.789062 T:3037868032 DEBUG: POParser: loaded 8 strings from file /storage/.kodi/addons/skin.aeon.nox.silvo/language/English/strings.po
18:02:49 72959.789062 T:3037868032 INFO: Loading skin includes from /storage/.kodi/addons/skin.aeon.nox.silvo/1080i/includes.xml
(2015-12-15, 19:06)vivo Wrote: [ -> ]hey all
thnx
Second post please read FAQ
Mike few bugs on the latest isengard release on github.
1. Autoplay music full screen doesn't work, it just stays on the track selection window.
2. None of the music widgets seems to work.
3. When chosing a custom colour for text it doesnt save even though the colour appears. I'm trying to add the old orange colour fff0a510. When i put the hex in it resolves it but then vanishes when i click save.
4. Still the issue with playing a video from an add on like youtube when pressing ok once doesn't display a play button and deselects current selection, pressing ok again then plays the video. (video below)
Hi Mike,
I updated today from your master branch and I noticed that all the TV Studio and Movie Studio icons are gone from all the views and the info pages.
Is this known?
Cheers
(2015-12-15, 19:11)Solo0815 Wrote: [ -> ]Tested the new (merged) version with latest skinhelper and skinshortcuts:
I can't get the upper widgets (widgets1) to work, when "Advanced Widgets" is enabled. They doesn't show up. The lower row (widget2) is working fine. Only in the TV-section, "Recent Recordings" show up in the upper row
Seems to be working fine this end.
Possibly could be an issue to do with left over information from before the merger. Just to be sure.
Could you post a copy of your script-skinshortcuts-includes.xml. (that's where the widget and home menu settings are stored)
It is located in the 1080i folder within the aeon nox silvo skin folder.
(2015-12-15, 21:56)CaptainHero Wrote: [ -> ]Hi Mike,
Is this known?
Cheers
You must download the new resources addon!!
You find it under look and feel!!
