(2023-06-26, 02:29)miky_boy Wrote: [ -> ]Hi guys,
I installed this Skin on my RPI 4 and I love it, but I have a question. I already searched but didn't found any information about it and I checked all the possible options on the skin config.
Where I can define the start-up screen on my skin? I mean, when the RPI boot, how can I set if I want the Videos, Concerts, Series, etc.. menu as the default one?
Thanks and regards,
Miky
This might help...a Pictorial
(2023-06-27, 15:30)flhthemi Wrote: [ -> ] (2023-06-26, 02:29)miky_boy Wrote: [ -> ]Hi guys,
Thanks and regards,
Miky
Hi my friend,
Thanks for your message, but probably I didn't explained my issue in a proper way, or my skin could have some issues.
I leave in attach my actual order config (
https://pasteboard.co/3qBn5IF61k3b.jpg), but what happens is that the screen at boot is the one where you can find folders (
https://pasteboard.co/EKH9eehhAOwP.jpg). If I exit on my remote, will appear a focus menu, but is not the 1st on the order I have set (
https://pasteboard.co/h6MkASuHgbVy.jpg).
So honestly I don't know how I can make it work as desired. Do you have any idea?
Thanks again and Best Regards
(2023-06-26, 02:29)miky_boy Wrote: [ -> ]how can I set if I want the Videos, Concerts, Series, etc.. menu as the default one?
It's like @
flhthemi explained.
If you want, for example, "Series" as the default focus, then you move it into the third position as shown in the images.
TMM seemed to have made some changes and now report my Dolby Atmos movies codec as TrueHD/Atmos and writes nfo file as
<codec>TrueHD/Atmos</codec>
Before it would just list as “Atmos” and write nfo files as
<codec>Atmos</codec>
Silvo 9.0.1 doesn’t seem to recognize TrueHD/Atmos and leaves flag empty. Older skins based on Aeon Nox still work. Anyone know what I need to edit to make flag show up?
(2023-07-02, 01:28)Karellen Wrote: [ -> ] (2023-06-26, 02:29)miky_boy Wrote: [ -> ]how can I set if I want the Videos, Concerts, Series, etc.. menu as the default one?
It's like @flhthemi explained.
Hi my friend,
Right, but in my case, even choosing any order, I always got the boot screen as this picture ->
https://pasteboard.co/EKH9eehhAOwP.jpg I don't see any reason for that
Any idea?
Best Regards
(2023-07-02, 02:42)DAlba Wrote: [ -> ]TMM seemed to have made some changes and now report my Dolby Atmos movies codec as TrueHD/Atmos and writes nfo file as
I've tried adding duplicate Atmos icon in media folder labeled truehd/atmos.png but doesn't work. Doesnt seem to like the forward slash. IF I edit nfo to <codec>TrueHDAtmos</codec> I can get it to work. I tried adding more label png files replacing forward slash with space and other symbols. Can anyone help point me in right direction please?
Since a recent update of the skin the player OSD shows filename extensions instead of the movie titles in the bottom status line and in the infoscreen, eg. „Avatar.2.2022.mkv“ etc. How do I get rid of the Filename and display the Movie title „Avatar 2“like it was before ?
Is there a way to disable clearart for the on screen display during video playback? I have customer artwork selected in the Settings > Media > Videos selected and only have banner, landscape and clearlogo selected but clearart is still being downloaded and shown. Am I missing anything that could disable this?
Hello,
my Kodi device is a Vero4k running OSMC, and as skin I have Aeon Nox:Silvo.
Until last week the OSMC I was running was based on Kodi v19, now I applied the June update which upgraded Kodi to 20.1.
After the update I noticed that in the Youtube addon, next to the list of the videos it doesn't show anymore their duration.
I also did an upgrade for Aeon Nox from 8.1.0 to to 9.0.1 but it didn't help.
Has something changed in the additional information shown next to titles from Kodi 19 to Kodi 20 (for the 'list' view)?
UPDATE: after further updates, the issue with the YT add-on is solved, but still, it seems to me that e.g.
while listing episodes of a TV show, the 'List View' doesn't report anymore the episode duration.
Other views do carry that information, e.g. 'LowList' (but only for the selected episode).
I'm not entirely sure but the right-side of an entry in List View is now reserved for the rating value?
I think I may have found a bug.
I'm using Showcase with Infopanel on Music>Artists. When hovering over an artist, usually you hit up to open the side panel for settings and "update library". I can't get the the side panel to open unless the artist has a biography. It just "clicks" but does nothing. If I find an artist with a biography, I click up through the biography scrollbar and then opens the side panel when it gets to the top. I don't mind scrolling through the biography, but it's kind of a pain to find an artist with a biography sometimes. Has anyone else experienced this?
Kodi 20.1.0
Nox: Silvo from repo
Windows 10 x64
(2023-07-08, 19:00)bitbanger Wrote: [ -> ]Hello,
I honestly don't remember if I changed anything with this but I did notice the hide ratings in list view setting in Skin settings > Advanced wasn't working for episodes so I added duration as fallback.
(2023-07-03, 06:18)DAlba Wrote: [ -> ] (2023-07-02, 02:42)DAlba Wrote: [ -> ]TMM seemed to have made some changes and now report my Dolby Atmos movies codec as TrueHD/Atmos and writes nfo file as
a "/" usually indicates folder separation. The studio icons resource image puts any with slashes in the name into a folder structure. Example being
Don Simpson/Jerry Bruckheimer Films.png. You can try that and see if it works.
(2023-07-31, 17:39)mikeSiLVO Wrote: [ -> ] (2023-07-02, 17:27)miky_boy Wrote: [ -> ]Hi my friend,
Right, but in my case, even choosing any order, I always got the boot screen as this picture -> https://pasteboard.co/EKH9eehhAOwP.jpg I don't see any reason for that
Any idea?
Best Regards
Maybe you have videos set as your Startup window in Kodi's Interface settings
Hi my friend,
God bless you man!!!
What I searched online about this issue and didn't found nothing.. Now is working properly.
Many thanks and Regards
