(2023-11-29, 08:08)gpmc Wrote: [ -> ]Not fully clear to me which version from Github I should use on my Kodi 20.2: Nexus or Master?
I'm using the same version of Kodi and wasn't completely sure either and just went with the Master and all seems fine to me? I'm sure someone else will confirm.
(2023-11-29, 01:16)Frank512 Wrote: [ -> ]That would be awesome! The "ok" button is technically not necessary since you can just hit a back button IMO. Is it possible to add a delete recording button there, or is that not something you can add on that screen? Thank you, Mike.
I can add a delete button. I would have to close the info dialog to then popup the delete confirmation. Not 100% sure this is needed since you can use the context menu and opening that is just a longpress away. Doesn't seem to be that much more convenient
You can also add it yourself to the buttons in DialogPVRInfo.xml
xml:
<control type="button" id="99">
<description>Delete recording</description>
<width>auto</width>
<label>$LOCALIZE[117]</label>
<onclick>Dialog.Close(pvrrecordinginfo)</onclick>
<onclick>Action(delete,tvrecordings)</onclick>
<visible>Window.IsActive(PVRRecordingInfo)</visible>
</control>
You can always check the
README. It will specify the matching branch for the Kodi version.
(2023-11-29, 15:56)flhthemi Wrote: [ -> ]Started playing with Kodi 21 yesterday and this skin...was wondering if there is a way to enter the color code I want to use in the color picker manually. It takes a lot of time rolling the pointer over each color searching for the exact one I want to use. The old color picker addon used to let you do this. Or am I just missing the obvious?
Not atm, I don't think it would be too hard to add that but I would have to see what I can do in that dialog.
(2023-11-29, 19:36)mikeSiLVO Wrote: [ -> ] (2023-11-29, 01:16)Frank512 Wrote: [ -> ]That would be awesome! The "ok" button is technically not necessary since you can just hit a back button IMO. Is it possible to add a delete recording button there, or is that not something you can add on that screen? Thank you, Mike.
Still new to Kodi and did not know about "long press" being a thing until a couple days ago. I tried it and for whatever reason the long press function does not seem to work with the IR receiver I have plugged into my PC. For now I programmed a button on my remote to press C to get the context menu but I would like to re-gain that button back for something else. I will look into why long press will not work.
Basically I'm just so used to clicking "Ok" on the Recording then choosing play or delete. Old habits die hard, have to retrain my muscle memory so to speak. Thank you for the info!
Hi Mike !
I have a small detail that would like for you to look into if you have the time...
The "Blur" option for information screens it is not working consistently:
- if today a scrape my library, there will be some
titles with the info screen with blur applied and
some not.
- if tomorrow I erase my library and re-scrape it, there will be different titles with blur and different titles without, than the previous library. It is totally random.
Thanks Mike
Mike! Thanks so much! You don't know how much I appreciate you having done that so fast!
Hi Mike . I would like some help because I am confused (as i am newbie)
I use in a modified view list 50 the following code to get from tmdb helper what state a series is in and when is the last episode e.t.c
</label> [COLOR red]• [/COLOR][COLOR $VAR[ThemeLabelColor]]$LOCALIZE[126]: [/COLOR]$INFO[Window(Home).Property(TMDbHelper.ListItem.Status)]
[COLOR red]• [/COLOR][COLOR $VAR[ThemeLabelColor]]$LOCALIZE[31011]: [/COLOR]$INFO[Window(Home).Property(TMDbHelper.ListItem.Last_Aired.Season),S]$INFO[Window(Home).Property(TMDbHelper.ListItem.Last_Aired.Episode),E, -]$INFO[Window(Home).Property(TMDbHelper.ListItem.Last_Aired.Name)]$INFO[Window(Home).Property(TMDbHelper.ListItem.Last_Aired), (,)]
</label>
I can recover this information only by removing the code you have added to the startup.xml and removing from the user data > skin > settings.xml the following
<setting id="TMDbHelper.MonitorContainer" type="string">9143</setting>
But by removing these I lose the rating you have given for tmdb and trakt and possibly something else ....
any help is welcome!
Thanks in advance
Manos
edit: I think this was more psychological post ! :-) I found a solution Thank you very much
(2023-11-30, 16:21)lynxstrike Wrote: [ -> ]Hi Mike !
- if today a scrape my library, there will be some titles with the info screen with blur applied and some not.
Thanks Mike
Likely not random. It should always be an item with a character in it that needs to be escaped like the comma in your second image. Fixed on GitHub if that is, indeed, the reason.
(2023-12-01, 00:51)flhthemi Wrote: [ -> ]Mike! Thanks so much! You don't know how much I appreciate you having done that so fast!
(2023-12-01, 20:38)mikeSiLVO Wrote: [ -> ]It should always be an item with a character in it that needs to be escaped
Hey Mike, missed that detail
Thanks for taking time in fixing this.
A little bit early, but in case I don't have the opportunity later, Happy Hollidays!
Hey guys, have a question.
In Shift View i can see genre on TV Shows, but its missing on Movies. Is this something on my end or intentional?
If intentional, is there a way to enable that piece of information?
Hi Mike...
I found the picture range flags for
SDR, HDR10 and HLG homologated.
Tried them with your skin and they look great. I will try to find Dolby Vision in the same format.
Does anyone know how to change the size of the cursor?
is it easy to add view 503 to the Tv show screen? tried some things to no avail.
Cheers ?
(2023-07-31, 17:09)mikeSiLVO Wrote: [ -> ]Should be fixed on Git
I've noticed that at least your current git now has a problem applying Showcase to TV seasons. It's there, but when you select it in the menu it applies one of the other List views instead. It appears to be fine for movies and music.
(2023-12-01, 21:14)lynxstrike Wrote: [ -> ]A little bit early, but in case I don't have the opportunity later, Happy Hollidays!
(2023-12-02, 00:45)ReaLx3m Wrote: [ -> ]Hey guys, have a question.
Shift view does not currently show Genre for Movies or TV Shows.
(2023-12-02, 17:01)lynxstrike Wrote: [ -> ]Hi Mike...
I found the picture range flags for SDR, HDR10 and HLG homologated.
I already have flags for HDR format...
(2023-12-03, 18:46)Dani78 Wrote: [ -> ]Does anyone know how to change the size of the cursor?
Pointer.xml, doubling the width & height should work for an increase. Not sure why anyone would want it smaller.
xml:
<width>88</width>
<height>100</height>
(2023-12-04, 22:31)maildeamon Wrote: [ -> ]is it easy to add view 503 to the Tv show screen? tried some things to no avail.
Cheers ?
Wall view is already available for TV Shows.
(2023-12-05, 18:51)dkoh Wrote: [ -> ]I've noticed that at least your current git now has a problem applying Showcase to TV seasons. It's there, but when you select it in the menu it applies one of the other List views instead. It appears to be fine for movies and music.
This should also now be fixed on Git
