Quote:(04-05-2018, 10:24 AM)flhthemi Wrote: #1 Fixed! Thanks!
#2 Got ya! It does, just seemed to me that before if I had a source set in File Manager I could get it to show.
Now...here's what I found today after the git update I just did:
If you change the widgets transparency setting and come back to the Main menu this is what you see. Reloading the skin will fix it:
When the Info Box appears for ANY reason it never makes it to the middle of any screen as it used to:
Also noticed that if I use the shutdown menu "reload skin" more than once kodi closes. Log indicates it's having an issue finding "skin.aeon.nox.silvo" folder in addons folder. Might be something here messing up but I didn't see this happen on V6.1.3 so thought I would point it out. EDIT: Doesn't do it every time. Right now I can't reproduce it at all. So it's probably something on this end.
EDIT#2
I did a fresh install (portable) ALL the same stuff above except I now have a log file (No Debug ON) HERE It looks to me as if the Reload Skin item in the shutdown menu isn't working. I had created a new Music widget with random songs. At exit of creating the widget the skin acted like it went through a reset but no widget showed. Reload Skin wouldn't display it either. Exited Kodi and re-started and widget appeared.
Here is a debug log. I turned on debug, stopped Kodi, then started Kodi, then I click Reload Skin, Kodi closed.
Also noticed background images for sub-menu items are not being displayed they ARE set.
EDIT:3
Screen shot after Starting Kodi and waiting about 2 minutes and then clicking Reload Skin from the shutdown menu.
Now on 18.0-ALPHA2 Git:20180404-6f9435a042
Boy is this forum software frustrating! I can't figure out how to edit out quotes when quoting a message. So I did what I could figure out. Guess I'm an idiot.
#2 Should I change it? Your call cause no one else seems to have an opinion on the matter.
Yes *I* think it's very handy!
Widget transparency seems like a Kodi bug. Please try latest master of both Kodi and the skin to see if it still exists.
Updated to Kodi 18.0-ALPHA2 Git:20180416-992b39364f and latest git of the skin. Still there. Guess it'll be fixed one day
Notifications (Info Box) were in the middle of some changes. The latest version is different so hope it looks and works well for you
I like the new look for it!
Lastly the reload skin stuff again seems like a Kodi bug. Kodi v18 is Alpha still so it is to be expected.
Yeah that's still there too. If you need it here's a Debug Log using the updated Kodi and skin. Seems now anytime I reload the skin it force closes Kodi.
Well, now I'll go cut the grass and get over this stupid forum editor thing! Thanks Mike!
Hello, after putting the widget of the movies in a section. I would like to know if it is possible that in addition to appearing the covers that have movement as in the skin eminence and not remain static Thank you very much for this great work
I have that problem, too. Whenever I set the library view to low list it switches to tri panel.
I would love an answer to this question.
Small question, what I need to change in order to enlarge the Clearart view, the Icons are too small...
I want them too look more like Madnox because I can't Install Madnox on my Minix it runs too slow.
Quote:(2018-04-14, 14:42)fred76 Wrote: I have an issue with artist slideshow: I can see artist pictures in the main menu of Aeon nox 5: SiLVO, but not in the music window (anyway this was working before updating Kodi + Aeon Nox SiLVO some time ago). Any help on this issue is very appreciated. Thanks in advance fred.
Did you enable Artist Slideshow as the background of Fullscreen Music playback or...?
Thanks for your reply ... Artist Slideshow as the background of Fullscreen Music playback is enabled. I also can seen the artist pictures in main menu but not in the music window. Any hints? Thanks and best regards fred.
I love the customisation option in this skin and hence why I use it as my daily skin but can we have more font options please, fonts are small and the code needed to add them is also relatively small but as someone with an android device adding the fonts and the code takes an extraordinary amount of time, it took me about 3 hours just to add one font, copy and pasting and then correcting the code into the font.xml, maybe it would be beneficial for people to upload the relevant files they have amended with any added fonts for those of us that want a bit of an extra special look to this already beautiful skin?
I recently downloaded this skin and love the options. Whenever I have troubles with anything 'kodi' I do a search first to try and resolve the issue myself. This one I can't seem to find an answer for.
What I want to do - When viewing my movie collection, using the 'Showcase' view, and while looking at a Movie set/collection (before clicking 'into' the collection), have the clearlogo displayed at the bottom of the set/collection.
What I have done - After my latest movie update & customizing, I did an export to individual folders with all the options chosen. All movies are in their own respective folders, with NFO files, all artwork files (including clearlogos and clearart), and an extrafanart folder. Clearlogos and clearart are all working on all individual movies and look sharp as hell!!
Found the answer - Artwork Beef. Thought it was skin specific.
(2018-04-19, 15:49)flhthemi Wrote: [ -> ]Yes *I* think it's very handy!
I reverted the image start location so it will work exactly like it did before.
I reload the skin about a million times a day
without any crashes and I even tried using the shutdown menu button and I do not experience any crashes. If Kodi is crashing every time then something is amiss with your setup. Maybe with your widgets or if you have a frankenskin that needs to be completely deleted and reinstall the latest from Git.
For the forum issue:
I don't like the default look myself so I change it to show the source in User CP or you can click the source button toggle on/off underneath the Italic/Underline buttons. Maybe that will work for you also
(2018-04-20, 12:29)parkata Wrote: [ -> ]Hello, after putting the widget of the movies in a section. I would like to know if it is possible that in addition to appearing the covers that have movement as in the skin eminence and not remain static Thank you very much for this great work
The panel widgets don't autoscroll. It doesn't really make sense to me to do that. The list widgets will scroll if you enable it in Skin settings > Widgets.
(2018-04-21, 05:56)guandms Wrote: [ -> ]Hi,
You need to change the skin version to the latest master on Git for Leia cause I just made them bigger
(2018-04-21, 16:14)fred76 Wrote: [ -> ]Thanks for your reply ... Artist Slideshow as the background of Fullscreen Music playback is enabled. I also can seen the artist pictures in main menu but not in the music window. Any hints? Thanks and best regards fred.
I feel like we are talking about 2 separate things here... What does the menu have to do with the Artist Slideshow addon?
Check your settings for Artist Slideshow and post a
debug log (wiki).
(2018-04-21, 16:24)1jester Wrote: [ -> ]I love the customisation option in this skin and hence why I use it as my daily skin but can we have more font options please, fonts are small and the code needed to add them is also relatively small but as someone with an android device adding the fonts and the code takes an extraordinary amount of time, it took me about 3 hours just to add one font, copy and pasting and then correcting the code into the font.xml, maybe it would be beneficial for people to upload the relevant files they have amended with any added fonts for those of us that want a bit of an extra special look to this already beautiful skin?
Well, it takes time to add fonts. I feel like your saying it takes you so much time to add a font that you don't want to add any.
I kinda feel the same way...
Anyhoo, I added about 6 new fonts to Leia version on GitHub. Def needs testing though
(2018-04-23, 21:30)mikeSiLVO Wrote: [ -> ] (2018-04-19, 15:49)flhthemi Wrote: [ -> ]Yes *I* think it's very handy!Updated to Kodi 18.0-ALPHA2 Git:20180416-992b39364f and latest git of the skin. Still there. Guess it'll be fixed one day
I reload the skin about a million times a day without any crashes and I even tried using the shutdown menu button and I do not experience any crashes. If Kodi is crashing every time then something is amiss with your setup. Maybe with your widgets or if you have a frankenskin that needs to be completely deleted and reinstall the latest from Git.
Oh man! That Source button did the trick for quoting messgaes! Still, this forum software is like no other I use..but you wanna see messed up, look at WD's Support Community! What a mess.
Well I'll go do a fresh install and see what gives on the reloading issue....Good thing about being retired, I have plenty of time on a rainy day to tinker!
Ok, I was running Kodi v17.6 on android boxes. Everything was working as it should. I updated one of the boxes to v18 Alpha. I went to the default skin, installed Kodi update, then installed skin update, changed back to Sylvo skin, it rebuilt and looks correct.
Since doing so I have encountered 2 problems so far:
1. I had a couple smart playlists as sub-menu items, had them set to play, such as playing some random cartoons or crime shows (actual files of mine, not streaming). They worked fine in v17.6. In v18 I just get a "One or more items failed to play, check log". I even tried to create new playlists with same issue. That brought me to second problem
2. The log viewer just opens up blank.
I have tried installing the latest skin version from GIT, as well as trying the latest nightly of Kodi v18. (after installing the nightly of kodi, I no longer got the error, but it would crash kodi after a minute or so)
Anyone have any ideas or suggestions or know of similiar issues before I wipe it all out and spend hours rebuilding everything fresh again.
I am trying to get v18 to work to use with voice.
UPDATE:
I took the plunge and started from scratch sorta. I installed a re-branded fork of Kodi v18 Alpha for testing. The log viewer is now working correctly.
I am still not able to get my playlists to auto-play when using them as a sub-menu. When I navigate to playlists in kodi (using the list view), they all appear correctly, I can add them to queue and they will play correctly. But when I set them up as a sub-menu item or even a menu item and set it to play I get the "One or more items failed to play. Check the log for more information about this message."
If I select DISPLAY instead of PLAY when create the menu item it works as expected.
Here is part of the log it's creating when I get the error:
06:11:56.744 T:18446744073191557408 NOTICE: VideoPlayer::OpenFile: special://profile/playlists/video/Crime.xsp
06:11:56.746 T:18446744072808577312 NOTICE: Creating InputStream
06:11:56.766 T:18446744072808577312 NOTICE: Creating Demuxer
06:11:56.773 T:18446744072808577312 ERROR: Open - error probing input format, special://profile/playlists/video/Crime.xsp
06:11:56.773 T:18446744072808577312 ERROR: OpenDemuxStream - Error creating demuxer
06:11:56.774 T:18446744072808577312 NOTICE: CVideoPlayer::OnExit()
Quick question. Been using Kodi for years aeon nox specifically and never came across this issue before. Usually I can figure things out but I'm stumped on this one hence why I just signed up here.
Anyway. Just updated to Leia nox silvo skin, mostly I use the list view option and I'm always using the filter under Misc option in the sidebar. It's no longer there since updating to Leia from Krypton, it's driving me crazy not being able to filter through lists with hundreds and sometimes thousands of items.
Please help. 😩
Is there a way to move the video osd to the top? awesome skin btw thanks.
I reload the skin about a million times a day [emoji14] without any crashes and I even tried using the shutdown menu button and I do not experience any crashes. If Kodi is crashing every time then something is amiss with your setup. Maybe with your widgets or if you have a frankenskin that needs to be completely deleted and reinstall the latest from Git.
Check your settings for Artist Slideshow and post a debug log (wiki).
Ah, I'll try that out on my xbox1, it has leia as the only version available, I did add a font but like I said it took me an absolute age to do it, thanks for adding some new fonts, I'll look forward to trying them out
I feel a bit dump posting this, but i cannot find the info on how i change this
My guess its part of the skin?
I want to change the items that appear on my "Favorites Widget" and "Programs Widget" , i have done this in the past, i.e selected which items i want to appear on these widgets, but cannot figure out where i go in and customize these widgets.
Any help would be very appriciated
Best Regards
Patric
(2018-04-28, 14:36)mrpg Wrote: [ -> ]Hi,
Best Regards
Patric
Skin settings, customise home screen, on the right side there is an option for each main menu item to add a widget
