Version 21 Development build bug:
Installed Skin Info Service from the Recommended menu. When navigation in the library focuses on a Set, an error is thrown. Installing script.skin.info.service-master.zip from GitHub corrects this.
Many new things using v21 (and perhaps others) with the new GitHub build. For example, HDR 10 and Dolby Vision metadata icons now display. The 'Dimmer' for Skin Views is a welcome addition (many times guests get confused which title is focused). Thank you @
mikeSiLVO !
I noticed that since updating to the v20 Nexus release of Kodi I get a hard crash if I navigate to my music downloads folder. The folder does initially open but within a couple of seconds of scrolling through the contents Kodi freezes completely. Is there anything I can do myself to mitigate this issue? I am using the newest build of the skin from github. Thanks in advance @
mikeSiLVO
Just noticed this on the GIT hub....
When pulling up the video on screen display (osd) it seems to always show a certain type of art even when changing it to poster or logo. (Clearart maybe). Not sure if anyone else has noticed this or known issue. Love this skin though. Just updated to 20 and seems extremely quicker on my fire tv stick.
(2023-01-17, 22:25)brazen1 Wrote: [ -> ]Many new things using v21 (and perhaps others) with the new GitHub build. For example, HDR 10 and Dolby Vision metadata icons now display. The 'Dimmer' for Skin Views is a welcome addition (many times guests get confused which title is focused). Thank you @mikeSiLVO !
Is github master v21?
bc i installed the master from github and its still v20
btw im on nexus
(2023-01-19, 20:30)Pienoet Wrote: [ -> ] (2023-01-17, 22:25)brazen1 Wrote: [ -> ]Many new things using v21 (and perhaps others) with the new GitHub build. For example, HDR 10 and Dolby Vision metadata icons now display. The 'Dimmer' for Skin Views is a welcome addition (many times guests get confused which title is focused). Thank you @mikeSiLVO !
btw im on nexus
Maybe I wasn't clear... I'm using Kodi v21 development builds and the latest GitHub master of this skin.
Hi Mike,
In an earlier version I remember that I could disable the OSD auto-hide when playing music, but that seems to be gone now... Now my OSD hides after a couple of seconds, and I would like to keep it on screen.
I found an option for auto-hide delay in the video OSD, but it seems to be gone for music. Would it be possible to add this back?
Much appreciation,
In Kodi Nexus, the progress bar disappears too quickly when using the arrows while playing a video (SmallStepForward/Back, BigStepForward/Back)
(2023-01-20, 01:00)STEELBAS Wrote: [ -> ]Hi Mike,
Much appreciation,
That option has never existed in the skin. Check #5 of the
FAQ
(2023-01-20, 18:07)Pr.Sinister Wrote: [ -> ]In Kodi Nexus, the progress bar disappears too quickly when using the arrows while playing a video (SmallStepForward/Back, BigStepForward/Back)
Did you test the GitHub version of the skin?
How to install from GitHub
Hello,
I often use the OSD menu to go to the subtitles menu and each time the OSD pops up, the button selected by default is "Play"
How and what file do I have to modify to change it to the subtitles button ?
I've looked around the xml files but couldn't get the logic
Thanks in advance
(2023-01-21, 01:58)MickBim Wrote: [ -> ]Hello,
Thanks in advance
Turn OFF the Player Controls setting. The settings that are not Player Controls will remain and focus on the Subtitles setting when you open the OSD.
Error installing from GitHub zip.
CAddonInstaller: installing from zip 'C:\Users\DAN\Downloads\skin.aeon.nox.silvo.zip'
2023-01-20 21:41:28.892 T:4548 debug <CWebserver[8080]>: request received for /jsonrpc
2023-01-20 21:41:28.949 T:536 debug <general>: CAddonInstallJob[skin.aeon.nox.silvo]: requires service.library.data.provider version 0.4.2 which is not available
2023-01-20 21:41:28.949 T:536 error <general>: CAddonInstallJob[skin.aeon.nox.silvo]: The dependency on service.library.data.provider version 0.4.2 could not be satisfied.
Im getting an error with service.library.data.provider once I install the Nexus version of the skin.
Also being reported here:
forum.kodi.tv/showthread.php?tid=210063&page=11
