(2021-04-27, 20:44)lynxstrike Wrote: [ -> ] (2021-04-27, 18:27)ReaLx3m Wrote: [ -> ]some elements lost the transparency
Hi...
GIT ver. has and updated interface that include darker panes. I can't remember if you can have GIT with the old panels. You can try to erase addon install folder. Re-Install from repo and upgrade via ZIP and see if this way you keep the old panels (do not erase textures.xbt).
Hope this helps...
Thanks for the suggestion, though thats basically what i already did. Clean kodi install, install skin from repo, then install the git one on top of it.
I thought it some sort of a bug or setting that can be changed, looked much prettier with transparent panels.
Any other suggestions for a solution are welcomed, unless its set in stone for some reason.
Dear Friends
Great skin, thank you.
1. It would be great, when Aeon Nox: SiLVO would be more flexible, I mean allowing to enable/disable:
a) Media Tags - (Studio, 4K, video codec, audio codec etc.)
b) Movie Title
...visibility on all pages/views for example on Posters. It would be great to have an option to enable, which Tags should be visible, for example I don't like to see the icon of Studio, but I like to have other icons.
2. Why Media Tags recognize Dolby Atmos/DTS:X as Dolby TrueHD 7.1/DTS-HD MA 7.1, there is no coresponding icon to show the proper audio? It would be great to show also HDR10, HDR10+ and Dolby Vision icon.
3. Is there any chance to Background called Live Wallpaper: Random/Recent Movies with our custom background not this black one with circles? For example, show my Recent Movies posters on my wallpaper?
Thank you in advance for your help and support.
Sincerely
(2021-04-28, 20:20)UTAVATU Wrote: [ -> ]Dear Friends
b) Movie Title
Sincerely
https://www.youtube.com/watch?v=e7VmW5k5oXI
2. +1 would be nice to have Hdr icons prob be included V.20 and when Kodi supports Dolby Vision ?
Dear Friends
(2021-04-30, 18:42)kikassridec2 Wrote: [ -> ] (2021-04-28, 20:20)UTAVATU Wrote: [ -> ]Dear Friends
b) Movie Title
Sincerely
kikassridec2
On YT video I see there are DTS:X and Dolby Atmos, how you do it? I have ripped my entire collection of UHD physical discs to .mkv with Dolby Atmos/DTS:X, but it's still recognized as Dolby TrueHD 7.1 and DTS-HD MA 7.1. Is it only in Kodi 19.0? I use ZDMC based on Kodi 18.9, is it a case?
mikeSiLVO
As on:
https://www.youtube.com/watch?v=e7VmW5k5oXI I use the same View. There is a phrase on the bottom "Ends at: <XX:XX>". I use Polish language in Kodi, but this is not translated. Is there any possibility to translate some English phrases in your skin to Polish one? I would be very happy to translate them also in Settings of the Skin. How to do that?
Sincerely
This is MyFlix view from an .iso. Most of the other views show the same stream detail flags. Other file extensions like .mkv display the same stream detail flags. Details are in file name. For example: Zero.Dark.Thirty.2012.2160p.HDR.HEVC.TrueHD.7.1.Atmos.iso
Dear @
brazen1
(2021-05-01, 17:17)brazen1 Wrote: [ -> ]This is MyFlix view from an .iso. Most of the other views show the same stream detail flags. Other file extensions like .mkv display the same stream detail flags. Details are in file name. For example: Zero.Dark.Thirty.2012.2160p.HDR.HEVC.TrueHD.7.1.Atmos.iso
Thank you for your help. I have added ATMOS or DTS-X to the filename and it's recognized correctly. What should I add to the filename to have Dolby TrueHD or DTS-HD Master Audio?
Sincerely
For example: TrueHD.5.1 or DTS-HD.MA.5.1
Dear @
brazen1
(2021-05-01, 20:27)brazen1 Wrote: [ -> ]For example: TrueHD.5.1 or DTS-HD.MA.5.1
Thank you for your information. I don't know why, but when I add to the filename DTS-HD.MA it's not recognized as DTS-HD Master Audio, but as Dolby TrueHD. ATMOS, DTS-X, TRUEHD is fine and it's working. When I delete DTS-HD.MA from the filename it's also OK, strange. May you check one of your files with DTS-HD.MA naming, if it's displayed correctly in Aeon Nox: SiLVO as DTS-HD Master Audio?
Thank you for your time.
Sincerely
Every title and every audio display correctly including DTS-HDMA. The audio doesn't really need to be in the file name. Kodi will pull that info once it's played for a couple seconds. I responded here for missing HDR tags and was suggesting adding HDR to the file name and showing that it works for me that way. Perhaps add 2.0, 5.1, 7.1, etc. to your file name as I exampled. (DTS-HD.MA.5.1) Did you play the movie a bit? Are you using a view that shows all the stream details because some views only show some stream details but not all.
Dear @
brazen1
(2021-05-02, 16:31)brazen1 Wrote: [ -> ]Every title and every audio display correctly including DTS-HDMA. The audio doesn't really need to be in the file name. Kodi will pull that info once it's played for a couple seconds. I responded here for missing HDR tags and was suggesting adding HDR to the file name and showing that it works for me that way. Perhaps add 2.0, 5.1, 7.1, etc. to your file name as I exampled. (DTS-HD.MA.5.1) Did you play the movie a bit? Are you using a view that shows all the stream details because some views only show some stream details but not all.
I will try today once more. Which view do you use to have all stream details? Correct me, if I am wrong, you have HDR tag visible too?
Sincerely
See my post with screenshot. Your answers are there.
Dear @"brazel1"
(2021-05-02, 17:28)brazen1 Wrote: [ -> ]See my post with screenshot. Your answers are there.
HDR is for HDR10 or it's also for HDR10+ and Dolby Vision? I mean, is there icon for HDR10+ and Dolby Vision too?
Sincerely
All flavors of HDR are HDR so an HDR stream detail icon is present no matter the file name addition of HDR10Plus for example. I don't know if Kodi core or skins are coded to distinguish one HDR type from another yet let alone icons? Estuary isn't. Also, Kodi uses the HDR10 metadata present in all HDR flavors except DV I think. DV is proprietary. They want everyone to pay them money to use it and have matching equipment for it to work. If they want to be exclusive, prepare to be excluded as well. Kodi devs are never going to introduce proprietary software requiring specific compatible hardware for an open source project across all the different platforms that will require royalties. Would you? DV ain't all that...
It seems the official version of the skin in Kodi repo is a many months ago version, without many of the upgrades and fixes of the last year. I know you always says to download from github and install manually, but its not possible in my system (Android smart TV with "test" Kodi version as app).
Other skins are regularly updated in official repo and the version there is kind of up to date. Why is this skin not updated for so many time in official repo? Is there any problem with it? Can someone manage and update it or ask it to anyone with that possibility? Its frustrating don't be able to use the REAL skin in Kodi Matrix in my system...
[AEON NOX: SILVO] How to change the default view (Viewtype) on Kodi 19? Everytime after I change it, it reverts back, so annoying! I have poster mode on my series but after few second change automatic to default
