(2021-10-13, 08:33)mazeeff Wrote: [ -> ] (2021-10-13, 08:22)Jeffers24 Wrote: [ -> ] (2021-10-13, 08:20)mazeeff Wrote: [ -> ]That is interesting. I already had the "Switch to visualization on playback", set to off. Radio Paradise (Different from the "Radio" app) still fails! I think that you have it narrowed down, to that Silvo work-around way back when.
Not sure, when the Kodi team introduced the 'Switch to visualisation on playback' setting in Kodi 19, Mike took his setting/workaround out of his skin
Got it! I have no choice but to switch to Estuary, and hope for a Silvo fix. Estuary is so "Plain Jane", but at least I can get Artist Slideshow to work.
I'm not sure AEON Nox SiLVO skin is the cause of the issue.
Hopefully we will find out the cause soon.
A Copy/Paste typo is the cause.
Line #4 in MusicVisualisation.xml should be
xml:
<onload>Skin.SetString(BlurRadius,10)</onload>
It is already fixed on Git.
(2021-10-13, 19:27)mikeSiLVO Wrote: [ -> ]A Copy/Paste typo is the cause.
Line #4 in MusicVisualisation.xml should be xml:
Which folder is MusicVisualisation.xml in?
EDIT
Found it:- addons\skin.aeon.nox.silvo\16x9
Applied the fix on my shield all working well, thanks for quick fix
(2021-10-13, 20:09)Jeffers24 Wrote: [ -> ] (2021-10-13, 19:27)mikeSiLVO Wrote: [ -> ]A Copy/Paste typo is the cause.
Thanks for your quick fix. Now the best Skin for KODI is working great again!
(2021-10-11, 16:31)YellowDog Wrote: [ -> ]I recently needed to do a fresh install LE 10.0.0, hardware change. Did a full backup and restore.
After the restore I can't get the alphabetical scroll to work. I assume I'm using the correct term. When in Movies I press the right arrow, I get full screen fanart, press it again I get the alphabet on the right hand side.
Anyone know how to re-enable this? I looked around and didn't see anything obvious.
Which view? If you have script.embuary.helper installed it will use that but there is a skin based alternative that does not use that add-on but it isn't available in all views.
I noticed RightList wasn't working so there will be a fix for that on Git sometime today.
(2021-10-05, 03:18)shoppedude Wrote: [ -> ]Is there something missing from here? It feels oddly shifted, and I've always wondered if there is a set of icons that I'm missing or something that I need to install.
http://imgur.com/a/dFaRiUI
I'll have a fix for that on Git soon. It is for the Rotten Tomatoes ratings when script.embuary.helper is installed and that info actually exists in your DB.
I don't need to slide it over for episodes since they do not have RT ratings...
(2021-10-14, 00:19)mikeSiLVO Wrote: [ -> ] (2021-10-05, 03:18)shoppedude Wrote: [ -> ]Is there something missing from here? It feels oddly shifted, and I've always wondered if there is a set of icons that I'm missing or something that I need to install.
Would it be possible to populate it with the per-episode ratings on IMDB? Just a thought...
Karellen
Good skin fix from Mike.
To confirm I am still getting the Radio network error I reported here using Estuary skin on my W10 laptop:-
https://forum.kodi.tv/showthread.php?tid...pid3064523
Any help would be appreciated.
My Kodi 18.9 instance of Kodi with Radio addon working okay on same laptop.
Happy to supply any further information required
Jeffers24
Its not something I can help with. Best post in the addons thread so the developer can see it.
Is there any hope that the touch screen issue will be resolved. I had read that it would be in 19.2 but it isn't. But I did notice that the default skins worked with touch screen,
Aeon Nox Silvo loses focus on the main menu bar on my Android tablet and Windows 2 in 1 laptop in Kodi 19.X. I can't stand any other skins so I just can't switch my devices over to 19.X until it works like good old 18.9 does.
(2021-10-14, 16:07)flhthemi Wrote: [ -> ]Is there any hope that the touch screen issue will be resolved. I had read that it would be in 19.2 but it isn't. But I did notice that the default skins worked with touch screen,
After updating to Kodi 19.2 on my android 10 touch phone using AEON Nox SiLVO, the touch screen issue is resolved for me.
(2021-10-15, 15:16)Jeffers24 Wrote: [ -> ] (2021-10-14, 16:07)flhthemi Wrote: [ -> ]Is there any hope that the touch screen issue will be resolved. I had read that it would be in 19.2 but it isn't. But I did notice that the default skins worked with touch screen,
Not so on my Windows 2 in 1...did you use a 19.2 release or a nightly?
(2021-10-15, 15:22)flhthemi Wrote: [ -> ] (2021-10-15, 15:16)Jeffers24 Wrote: [ -> ] (2021-10-14, 16:07)flhthemi Wrote: [ -> ]Is there any hope that the touch screen issue will be resolved. I had read that it would be in 19.2 but it isn't. But I did notice that the default skins worked with touch screen,
Interesting, I should have said my phone is an android phone, it had Kodi 19 installed from the play store, it updated this morning to 19.2 from the playstore.
With you saying your Windows 2 in 1 touch screen wasn't working after upgrading to Kodi 19.2.
I tried my Dell W10 laptop which has a touch screen, and the Kodi touch screen problem is still there.
I didn't notice the touch screen issue was there after updating to 19.2 because on my laptop I use button control rather than touch control.
So for me, 19.2 fixed the touch screen issue on my android 10 touch screen phone, but hasn't fixed the touch screen issue on my Dell W10 touch screen.
