(2021-04-05, 02:58)Karellen Wrote: [ -> ] (2021-04-05, 02:47)Nordo Wrote: [ -> ]But my main concern is that when checking the skin's version in Matrix, it appear to still be v 9.7.6.
This is the Matrix repository version of the skin... https://mirrors.kodi.tv/addons/matrix/sk...nox.silvo/
Thanks Karellen.
Interesting though that the matrix version in the repository is called v7.9.6 and is 49.4Mb.
The Silvo version that I was on before I upgraded to Kodi Matrix was v7.9.6.
The version I downloaded from Silvo's GitHub doesn't have a version number in it's file name, and it is 55.6Mb.
I would have thought that any Matrix compatible release of Aeon Nox Silvo would have had a new version number - say v8.0.1.
I just thought that going direct to GitHub, I would be getting the latest version with any corrections and updates that Mike had added.
Is anyone else having freezing problems when using fast reverse?
(2021-04-06, 04:35)Nordo Wrote: [ -> ]Is anyone else having freezing problems when using fast reverse?
Have you switched back to Estuary and checked if it still freezes? If it does, then it is Kodi core, not a skin issue.
Thanks Karellen, will do.
BTW, I am on a Windows 10 pc.
EDIT - you're right. The freezing after fast forwarding or reversing is happening when using Estuary as well.
I'll report it in the Windows sub-forum (is this the correct place to report the problem?).
However, I'm still not sure if I am on the current Aeon Nox Silvo or not.
(2021-04-06, 06:02)Nordo Wrote: [ -> ]However, I'm still not sure if I am on the current Aeon Nox Silvo or not.
If you installed the skin from the Kodi repo you will have the latest released version. If you installed the build you downloaded from the github you have the unreleased build with all the latest changes. Version numbers normally are only given when a build is released.
(2021-04-06, 14:56)BZwart Wrote: [ -> ] (2021-04-06, 06:02)Nordo Wrote: [ -> ]However, I'm still not sure if I am on the current Aeon Nox Silvo or not.
I know Mike is constantly (when he has time) updating his Matrix compatible Silvo as bugs are reported.
And he has posted that the most bug free update can be downloaded direct from GitHub.
i.e the latest version from GitHub is the same version as in the repository, but with several bugs removed.
I guess Mike is treating his Matrix compatible build as a
beta release, until he is happy enough to release it as a final - when it will get a new version number.
i don't know if it is intentional or not, but MyFlix view doesn't show watched indicators
(2021-04-07, 09:59)VelvetKevorkian Wrote: [ -> ]i don't know if it is intentional or not, but MyFlix view doesn't show watched indicators
Check that they are enabled in the view you are using.
For some views, in my case info wall, they are disabled.
Also need to enable them in skin settings>advanced>watched indicators
Can I ask you to add here that the movie has been watched?
(2021-04-07, 13:00)FloydKulis Wrote: [ -> ]Can I ask you to add here that the movie has been watched?
Cont in trakttv...device and addons video.
hi everybody,
i'm newbee in kodi,
i'm use aeon nox silvo directly install from kodi 19. i'm using logo view for movie and movies set display title off movieset on logo and it's very uggly.
and another things rating logo are display but no logo for imdb and tmdb.
xml:
<ratings>
      <rating name="imdb" max="10" default="false">
         <value>6.8</value>
         <votes>350205</votes>
      </rating>
      <rating name="themoviedb" max="10" default="false">
         <value>6.9</value>
         <votes>7250</votes>
      </rating>
      <rating name="metacritic" max="10" default="false">
         <value>5.8</value>
         <votes>0</votes>
      </rating>
      <rating name="tomatometerallaudience" max="10" default="false">
         <value>5.3</value>
         <votes>0</votes>
      </rating>
      <rating name="tomatometerallcritics" max="10" default="false">
         <value>5.3</value>
         <votes>0</votes>
      </rating>
      <rating name="trakt" max="10" default="true">
         <value>7.9</value>
         <votes>883</votes>
      </rating>
   </ratings>
You posted in the wrong skin thread, so I have moved you to the correct thread.
(2021-04-09, 22:00)irhosky Wrote: [ -> ]and movies set display title off movieset on logo and it's very uggly.
I don't quite understand what you mean here. Maybe post a screenshot to help explain.
(2021-04-09, 23:07)Karellen Wrote: [ -> ]You posted in the wrong skin thread, so I have moved you to the correct thread.
il's ok clearlogo is not present so when i check illustration I have change clearart and it's ok
thanks you.
juste french MPAA "tous public" not reconized and tmdb et imdb rating logo.
Hey all,
I cannot switch to blur background on video information or change the faded background on matrix. What do I miss?
Every addon installed from the required list, I miss artwork beef from recommended and cinemavision metadata editor and script grab fanart.
After changing the "View List" to VIEW OPTION it will not be saved.
After I go back to check it it has gone back to its default setting "LIST" while I have it set to "Myflix". Â
Am I doing something wrong or is this an error in Kodi Matrix.
