Hi Mike I downloaded the GIT and tried install from zip to replace my old aeon nox silvo skin but get xbmc dependencies of gui version 5.12 ?? Any ideas
Ziggy
(2016-06-04, 17:20)ziggy231 Wrote: [ -> ]Hi Mike I downloaded the GIT and tried install from zip to replace my old aeon nox silvo skin but get xbmc dependencies of gui version 5.12 ?? Any ideas
Ziggy
Ziggy,
The master branch in GitHub is Krypton only. If you are on Jarvis, please use the Jarvis branch.
Regards,
Bart
Ok thanks Bart, didn't realise lol
Just wanted to say thanks for this great skin. It just keeps getting better!
(2016-06-04, 16:52)taylormia Wrote: [ -> ]Hi mikesilvo,
I'm using version 5.8.6-3.0.3 of the skin. When I get to the video info screen of a movie, the selection highlights "Add to List" button automatically. (see screenshot below) I would like for the "Play" button to be highlighted instead. Is this possible? How?
Screenshot
In skin settings under Video Info you need to disable Replace with Extended Info for Movies and Shows
Hello Mike,
Is pvr artwork with skinhelper not supported in your skin?
Cause in skinhelper setting for pvr artwork it says pvr thumbsare disabled or not supported in this skin..
I read the readme.md on github from skinhelper.service and pvr artwork has to be enabled in the skin.
But in this skin i can't enaable it
I really would like to have fanart and posters in my live tv channels.
Am I the only one getting an error on startup for skin.helper.service?
(2015-10-13, 13:17)Mr. V Wrote: [ -> ]Another possible design for the vertical menu using the MediaStream background with the widget centered.
Was this ever implemented in AN Silvo?
Looks very nice, and would make me move away form Modded Estuary theme
Hola mikesilvo164
I want to change the color of the buffering load bar is gray and is not very well light green but do not know how I could help.
SOS--- Android
Aeon Nox 5
Quiero cambiar el color de la barra carga buffering que es de color gris y no se ve muy bien por verde claro pero no se como hacerlo me podrias ayudar.
SOS--- Android
Aeon Nox 5
GRACIAS....................
(2016-05-31, 04:19)mikesilvo164 Wrote: [ -> ] (2016-05-30, 11:44)Maaarv Wrote: [ -> ]Hi,
I'm running the Jarvis version from GutHub and I seem to have a problem with displaying custom artwork for video genres.
I defined the path in the skin settings using NFS.
Unfortunately, the genre backgrounds do not change in the movie genre view. Is this a known issue? I know this worked in the past for me.
Another problem I have is that when I play music in fullscreen mode and have enabled "Artist Slideshow" I always have my original local artist fanart blended in the foreground.
The artwork from Artist Slideshow is only showing behind. But I only want to see the artwork from Artist Slideshow here. How do I manage this?
Are you manually adding it or selecting the path in Skin settings? What does it say in your debug log (wiki)? I am not familiar with NFS or any of the file system/sharing protocols. I think wilmans2m had a similar issue with NFS stuff but I am not sure if he was able to solve them
Sorry that it took so long.
Here is my latest log.
http://sprunge.us/eiYU
I'm using the latest LibreELEC stable build 7.0.1 and the latest Jarvis version from GitHub.
I also tried using the LibreELEC home folder as a location for the genre backgrounds but this did not work aswell.
(2016-06-06, 09:49)nick w Wrote: [ -> ] (2015-10-13, 13:17)Mr. V Wrote: [ -> ]Another possible design for the vertical menu using the MediaStream background with the widget centered.
Anyone know if this was added to the current Aeon Nox GIT build?
thanks
I followed the guide to install :
Fresh new LibreElec kodi install (latest build) on Asus Chromebox
I installed all the required scripts/addons (tried both manually and by letting the skin install them) : Skin shortcuts, fanart grabber, library data provider and skin info service
I downloaded the latest build (zip) from the github (master) and renamed the top folder to "skin.aeon.nox.silvo"
## I have tried from repository and there is no Krypton compatible version ##
Installed the skin using the zip file, everything went fine, addon/skin enabled
I activate the skin, when going back to main menu, skin asks to install another addon, I let it
Addon installed
Kodi menu showing (skinned to silvo), I can enjoy it play with it change its settings
Everything is perfect...
Until I reboot and my Kodi gets stuck on a Kodi animated (with sound) logo
The only way out I found was removing the guisettings.xml through SSH to be able to reboot into default skin
Please help !!!
Mike would it be at all possible to get a Shuffle Icon on the full music screen? Would be great to see if Shuffle is enabled / disabled without having to go into the OSD every time.
(2016-06-07, 13:33)jeffjoker Wrote: [ -> ]Hi,
Addon installed
Please help !!!
i just installed the skin by downloading the .zip and installing it via the add-ons page > install from .zip
